Go Back   Home Recording > User Forums by Brand > Event Electronics Forum
     Audiofanzine Event-electronics Event-electronics News Event-electronics Medias Event-electronics Tests Event-electronics Articles Event-electronics User Reviews Event-electronics Classifieds Ads
Old 09-15-2007
mark4man's Avatar
mark4man mark4man is offline
MoonMix Studios
mark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond reputemark4man has a reputation beyond repute
Layla 24/96 Question...32-Bit Input ???
Hello...
My old (not really old, but older) Layla 24/96 is being used in a secondary workstation for mastering, primarily to recapture stereo mixes from my primary workstation, post processing. My primary workstation is set up with a Lynx Aurora 8 / AES16 combo...which I recently learned has 32-Bit drivers. My DAWs (SONAR 5 & WaveLab 5) are capable of sending a 32-Bit integer summed stereo output to the audio interface.
So now I'm wondering...can the Layla 24/96 do the same thing? The last 24/96 driver issue prior to going to the 3G...were they 32-Bit drivers; & can the DAC in the 24/96 receive a 32-Bit signal?
If so...what happens at that point? i.e., how is that 32-Bit signal processed internally within the 24/96, prior to being sent to the hardware outputs?
Thanks very much,
mark4man
Old 09-18-2007
Freudian Slip's Avatar
Freudian Slip Freudian Slip is offline
Source Of Confusion
Freudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond reputeFreudian Slip has a reputation beyond repute
You're confusing the driver bit depth and the audio bit depth. They are seperate things.
If 32 bit summed means 16 bits per side of a stereo file then any moden card should handle it.
If you tried to send a 32bit mono audio file through the converters on the layla I'm sure it would have a fit.
So the limitations of the converters are what they are regardless of the sound card driver bit depth.
F.S.
"If Congress can do whatever in their discretion can be done by money, and will promote the General Welfare, the Government is no longer a limited one, possessing enumerated powers, but an indefinite one"
James Madison: the father of the Constitution
Old 09-18-2007
mark4man's Avatar
MoonMix Studios
I'm not confusing anything w/ anything, Freudian. There is no such thing as bit depth as it relates to the drivers...except in the sense that the driver command codes are structured to accept a DAW ouput of a given resolution. My question was asking if the Layla 24/96 accepted 32-Bit at the input (as output by the software); & I received a reply back from Marcel (@ Echo Audio) that it does. I also asked how that signal is then processed within the Layla; & his reply was that it was reconverted to 24-Bit (& I'm assuming that's at a point prior to tha DAC, since there's no such thing as a 32-Bit converter.)
Thanks,
mark4man
Old 09-18-2007
Source Of Confusion
Sorry, I thought when you wrote "can the DAC in the 24/96 receive a 32-Bit signal?" that you maybe thought the d/a converter would play straight 32 bit files because of 32 bit drivers. I should have read further
It would be interesting hear how well the soundcard dithers compared to playing a track dithered by sonar or wavelab.
I was unaware that the layla would dither internaly, but then I never go above 24 bit.
F.S.
Mbox input question Daenn Recording Techniques 17 05-02-2009 10:10
DI Box the solution? TripleJ Newbies 52 09-08-2006 09:52
One question 20 bit layla + ADA 8000 Thekajunpimp The Rack 0 07-13-2006 09:33
Layla 3G / Mackie Mixer question dalley Digital Recording & Computers 0 01-17-2006 04:51
Multiple bit depths in sonar 5 jamie_drum Cakewalk / Sonar Forum 0 11-27-2005 15:15
