Old 09-13-2007
Broken_Hal0 Broken_Hal0 is offline
Newbie
Broken_Hal0 has a reputation beyond reputeBroken_Hal0 has a reputation beyond reputeBroken_Hal0 has a reputation beyond reputeBroken_Hal0 has a reputation beyond reputeBroken_Hal0 has a reputation beyond reputeBroken_Hal0 has a reputation beyond reputeBroken_Hal0 has a reputation beyond reputeBroken_Hal0 has a reputation beyond reputeBroken_Hal0 has a reputation beyond reputeBroken_Hal0 has a reputation beyond reputeBroken_Hal0 has a reputation beyond repute
Miking Techniques For A Jsx 2X12
I just picked up a JSX 2X12 the other day , and holy S!*t i am blown away by its tone and aggression!! I ve been recording for years but mainly acoustic material and so forth so its a little different having to mic up to these monstrosities!! I can get a pretty good clean tone out of it without ease , this amp was built for that , but when it comes to some crunch or distortion , Im not experienced enough to know exactly what to do.
It sounds good and clean going through my monitors (im also using a MINDPRINT ENVOICE MK II tube pre- amp) but I think I just double guess myself , since like I said I am not too experienced when it comes to recording / mixing heavy electric.
So I was wondering what some good techniques are , I have plenty of mics (gear list at the bottom) , I just dont want to be wasting the quality tone this amp is giving. So all input will be well recieved.
Thanks
Neil - The Little Studio -
76’ Ringo Star Replica Luds, 22” kick
L.T.D Deluxe E.C 1000
Dean Exotica FM TBK
Anjo , Hamer guitars
Peavey Millenium 5 string
Peavey JSZ 2X12
Scope Creamware Recording Rig 8 channels 24 channels 48.8khz , 8 channels of 96 khz
Asus mobo , intel duo core 2.66 2 gig ocz ram
Sonar Producer Edition 6.2
Mindprint Envoice II Pres and Comps.
Behringger Comps
Soundcraft Spirit boards
Yamaha Keys
Audio Technica (4033cl) , Studio Projects (c1) , Samson(numerous) , Shure(57s) , Behringer , EV mics (neodynium dynamics)
Akg (271's) and Event(tr6) Monitoring system
Old 09-13-2007
bkkornaker's Avatar
bkkornaker bkkornaker is offline
www.bryankmusic.com
bkkornaker has a reputation beyond reputebkkornaker has a reputation beyond reputebkkornaker has a reputation beyond reputebkkornaker has a reputation beyond reputebkkornaker has a reputation beyond reputebkkornaker has a reputation beyond reputebkkornaker has a reputation beyond reputebkkornaker has a reputation beyond reputebkkornaker has a reputation beyond reputebkkornaker has a reputation beyond reputebkkornaker has a reputation beyond repute
here is the best, most simple soultion to mic'ing an amps cab.........
....and im "shure" chessrock will back me up on this one........
http://www.bryankmusic.com
Old 09-13-2007
metalhead28's Avatar
metalhead28 metalhead28 is offline
Hates Raymond
metalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond reputemetalhead28 has a reputation beyond repute
Just stick a '57 in front of the speaker. It's fizzy in the middle and dark on the edges so just pick the area in between those two extremes that you like the best. Pull it back a little for a slightly brighter sound with less oomph. Stick it right up on the grille for maximum "balls".
Lots of other techniques can sound great too. That's just my 2 cents.
Some of my music
Old 09-13-2007
Track Rat's Avatar
Total Gear Slut
The 4033's would be OK or any of the dynamic mics you have would be worth a shot. As stated, closer to the center of the speaker =more strident, darker as you go to the edge. You just have to play with it to find your sweet spot. We could talk about the virtues of all the mics but it comes down to how the amp actually sounds to you. If it sounds the way you like it while you're playing it, you should be able to capture it.
Mike
Old 09-13-2007
Micter's Avatar
Micter Micter is offline
No Title
Micter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond reputeMicter has a reputation beyond repute
This is a great starting point. I would usually do something like this an put the 4033 back a fe feet and up a few feet to get a bit of the room and more of the sound your ear hears. Be careful of phasing.
Live Clean and Play Dirty
Old 09-13-2007
mrhotapples mrhotapples is offline
Dedicated Member
mrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond repute
Most JSXs I've heard are really bright and fizzy. I'd definitely mic it closer to the outside of the speaker. Trust your monitors though, not your ears hearing the amp. This is the number one reason why a lot of people hate how their recorded guitar/snare/kick/anything close miced sounds; they aren't hearing what the mic hears so you NEED to set it up with a mic on it and listen through a monitoring system. Try micing both speakers with different mics and techniques. Just think logically; if you hear it as too dark, closer to the center and back it off a bit. If it sounds really flat and one-dimensional, ya know, shallow, then back it off or add a second mic and pick some other element of the cabinet off. Micing the back (I assume it's open-back) will probably sound great.
Old 09-13-2007
BushmasterM4's Avatar
BushmasterM4 BushmasterM4 is offline
1K Silver Member
BushmasterM4 has a reputation beyond reputeBushmasterM4 has a reputation beyond reputeBushmasterM4 has a reputation beyond reputeBushmasterM4 has a reputation beyond reputeBushmasterM4 has a reputation beyond reputeBushmasterM4 has a reputation beyond reputeBushmasterM4 has a reputation beyond reputeBushmasterM4 has a reputation beyond reputeBushmasterM4 has a reputation beyond reputeBushmasterM4 has a reputation beyond reputeBushmasterM4 has a reputation beyond repute
Thats were I mic my JSX. I running JSX Head into a XXX 412 cab and Ive tried all the speakers and the sound is the same. Bottoms a little more bass to them (slant cab)
Old 09-15-2007
Newbie
Thanks for all the help
Wow , thanks for all the help , this is honestly one of the best communities out there , lol , i would post more often but im always in the studio!!!
shouldn't micing rhyme with slicing? mandocaster Microphones 65 05-11-2005 13:12
Drum miking Techniques needed jspitza Recording Techniques 6 02-12-2005 14:50
Vocal Miking Techniques...problem. mari Microphones 15 09-06-2003 13:45
advanced distorted guitar miking techniques maskedman72 Microphones 10 01-03-2003 11:12
Stereo Miking techniques... tubedude Mixing / Mastering 5 04-21-2001 02:27
