Go Back   Home Recording > User Forums by Brand > Don't Fear The Reaper
Old 09-12-2007
new2mix new2mix is offline
Senior Member
new2mix has a reputation beyond reputenew2mix has a reputation beyond reputenew2mix has a reputation beyond reputenew2mix has a reputation beyond reputenew2mix has a reputation beyond reputenew2mix has a reputation beyond reputenew2mix has a reputation beyond reputenew2mix has a reputation beyond reputenew2mix has a reputation beyond reputenew2mix has a reputation beyond reputenew2mix has a reputation beyond repute
outputting the delay or reverb from one track to another
I have heard of people doing this and wanted to play around with it. Usually I just double the track and offset it a few ms. I was reading on here somewhere where people were running the effect out into another track. Basically creating a track of just the delay or reverb and panning that to the opposite side of the original recording. Is this a good idea? How would you do it in Reaper? I have no idea how to use the buses and stuff yet.
Old 09-13-2007
pipelineaudio's Avatar
pipelineaudio pipelineaudio is offline
Official Shill as of 7/07
pipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond reputepipelineaudio has a reputation beyond repute
Heres a simple example of delaying the vocals slightly, using sends
http://shup.com/Shup/3677/BradSucks_...ous-delays.RPP
Note in this example the sends are post fader, so that changing the volume of the main vocal track will have an effect on the delay volume as well. You can change these to prefader sends depending on how you want to deal with it.
Click the I/O button on the main vocal track or either of the delay tracks to see whats going on
Mixing secrets by sonusman s_o_n_u_s_m_a_n Mixing / Mastering 261 05-14-2009 19:26
Just another thread! Gorty Roland, Boss, VS Series Forum 314 08-27-2007 04:39
I will finally share some "secrets" about mixing. Ford Van Mixing / Mastering 120 03-14-2007 16:07
Where do I pan the reverb in an acapella track ? rossmcm Mixing / Mastering 5 06-23-2006 05:33
REVERB, DELAY,.. Plug-in or Hardware? 11miles Mixing / Mastering 5 11-28-2004 15:17
