Recording drums on a 4 track. Best option?
I'm going to be getting a Tascam Porta One.
For recording drums, to reduce the hassle of bouncing tracks, will it be good to buy a mixer to have the drums going straight to one track? Or, Record the drums seperately then mix on computer. The problem with option 2 is I'm not sure how I would transfer it to the computer. Thanks for any help. |
Using a Tascam Porta One would be redundant and it would add noise and distortion. If you are going to buy a mixer anyway then just run the mixers L+R outs into the computer and record the drums in stereo. IMO that is the best way if you don't have a soundcard with multiple inputs.
ocnor's right. Grab yourself a small mixer and an inexpensive recording soundcard from M-Audio, (Audiophile 24/96, or Delta 44, or Delta 1010lt) and you'll be good to go. And get better results.
Tom |
The problem is, where the drums will be is nowhere near the computer, and moving it is not an option.
So the Tascam is useless for drums? |
Thanks F_cksia. I will probably be using 3 to 4 mics. I might mic the snare. I suppose the advantages of doing it this way is having it in stereo, correct?
I'm not familiar specifically with the portaone, but can't you just route the 4 inputs to your destination track, i.e. use the porta as your mixer, recording 4 channels to only to one or two tracks? That is definately possible on the 424 series.
you could try mono drums, it's been done before so i've heard.
I love recording drums to my cassette 4-track. Yes the sound is sorta low-fi, but if done well, the results are surprisingly good. Plus you get that tape sound.
Try various 3-mic techniques. The toughest part is making sure the mics are set just right so that they are all in phase with each other. |
| Recording drums?? Which option should I use for a room? | trandg | Recording Techniques | 5 | 12-21-2005 15:46 |
| Recording real drums with Audiophile | Ishtar69 | Recording Techniques | 14 | 04-29-2003 16:17 |
| recording all at once VS. track at once.............who wins??? | carlpony351 | Recording Techniques | 15 | 04-23-2003 17:33 |
| Portable HD or Computer-Based?? | pablo | Recording Techniques | 26 | 07-26-2001 15:33 |
| after track 1 recording...help | ronnyron | Cakewalk / Sonar Forum | 5 | 07-01-2000 21:03 |
