Old 09-09-2007
Nick The Man's Avatar
Nick The Man Nick The Man is offline
SOUND
Nick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond reputeNick The Man has a reputation beyond repute
Recording Clean Tube Amps
My buddy just bought a nice Fender tube amp, sounds great. I've heard quite a few solid state Fenders and liked those but this tops them all. I wanna record this thing to its full potential.
What kind of means do you go through to get that perfect clean tone/recording?
I have 57s, e609, AT4050, things like that to capture it with.
I usually just use a 57 on amps, but i figured theres some unique things that everyone does to capture their amps. What do ya got?
Old 09-09-2007
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Same as any amp. Move the mics around until it sounds interesting. I'll usually use a 57 or ribbon up close and a condensor or ribbon out in the room.
Old 09-09-2007
Seafroggys Seafroggys is offline
Force of Nature
Seafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond repute
I have a tube Music Man amp I've been recording with. I've only used my Audix i5 on it, haven't needed to use my 57 yet, but it gets great results.
Old 09-10-2007
Track Rat's Avatar
Total Gear Slut
Tex said it all. I've come to realize in my old age that just about any mic can do a great job at capturing sound. The one's that sound brilliant, you just have to experiment. That said, I'd try the 4050.
Mike
Old 09-10-2007
mrhotapples mrhotapples is offline
Dedicated Member
mrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond reputemrhotapples has a reputation beyond repute
Screw my post. I didn't like it. I change it!
if you play good, the amp sounds good...Start with your SM57 on the sweet spot of one of the speakers you're pumping that baby through. If you really need more than that, take your best condenser and...Don't shoot me...Mic the strings of the guitar.
This sounds BADASS if you are playing harder. You'll get the amp in this mic too. Creates a very detaild picture of the guitar's sound.
Old 09-10-2007
SOUND
REALLY. Mic the strings? I have honestly never even heard of doing this, seems like it would give a pretty undesirable sound.
Old 09-10-2007
Track Rat's Avatar
Total Gear Slut
Lou Reed used to do it.
Mike
Old 09-11-2007
The Axis's Avatar
The Axis The Axis is offline
Dedicated Member
The Axis has a reputation beyond reputeThe Axis has a reputation beyond reputeThe Axis has a reputation beyond reputeThe Axis has a reputation beyond reputeThe Axis has a reputation beyond reputeThe Axis has a reputation beyond reputeThe Axis has a reputation beyond reputeThe Axis has a reputation beyond reputeThe Axis has a reputation beyond reputeThe Axis has a reputation beyond reputeThe Axis has a reputation beyond repute
Using any of your mikes (SM57 would be my first choice) just try different positions and angles of the mike relative to the speaker cabinet (an individual speaker). It is ammazing how the sound field right in front of a speaker varies ! I ended up liking having the mike lightly touching the grill cloth, about 2" off center of one speaker cone, and pointed directly perpendicular to the speaker (not looking towards the center of the cone).
The point here is just experiment while listening. I personally would avoid the complicated two-mike setups, because they invariably cause some comb-filter effects.....but even those sound "good" at times.
Another tactic: if you want to capture a great sound just like it sounds to your ears, set a stereo pair of small condenser mikes at about the level and spacing of your own head and ears. This might cause "bleed" difficulties if other instruments are playing at the same time, but works great for solo playing.
Old 09-11-2007
mrface2112 mrface2112 is offline
Thread Killer
mrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond repute
yep, mic the strings. works real nice on a hollowbody--gives a bit of a sheen to the sound. also works real well on any electric that's got halfway decent resonance to it.
everyone else has already addressed the amp......listen via headphones while he plays, move the mic around and stick it where it sounds the most desirable. any of those 3 mics should kick out a perfectly acceptable guitar track.
cheers,
wade
Old 09-11-2007
jfrog's Avatar
jfrog jfrog is offline
uber-nerd
jfrog has a reputation beyond reputejfrog has a reputation beyond reputejfrog has a reputation beyond reputejfrog has a reputation beyond reputejfrog has a reputation beyond reputejfrog has a reputation beyond reputejfrog has a reputation beyond reputejfrog has a reputation beyond reputejfrog has a reputation beyond reputejfrog has a reputation beyond reputejfrog has a reputation beyond repute
I've never done that, but I remember reading about somebody big - Mark Knopfler maybe - who does that.
The Stratocaster Lounge (JR's songs)
“How can I miss you when you won’t go away?”
-Dan Hicks
Old 09-11-2007
Dedicated Member
I do it. I'm not anybody big, but I am getting to the point of always doing it for clean guitars. If you process it right and set it in low, it adds a really nice acoustic quality to any electric stringed instrument. It's nice on bass for certain genres too. Parallel compression of bass strings + bass amp/di on a fast punk song or a pop/slap style player...NICE. Give it a try.
  #12
Old 09-11-2007
Ironklad Audio Ironklad Audio is offline
1K Silver Member
Ironklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond repute
another trick that can help out, if you don't want to mic the strings, is to take a clean DI track and mix it in below the tracks that came off of the amp
  #13
Old 09-11-2007
danny.guitar
Guest
Posts: n/a
Cardiod condenser mic like an AT in close proximity and slightly pointed away from center of the speaker worked really well for me.
  #14
Old 09-11-2007
Dedicated Member
I want to emphasize not just pointing the mic at a certain part of the speaker. You'll save yourself a lot of trial and error by having the amp set up at a low volume with good iso headphones on and moving the mic around and finding a spot that jumps out at you. Some speakers are way too bright to go anywhere near the center of the cone, some way too dull to do anything but jam them into the center. This way you can figure out where a specific speaker's sweet spot is and automatically go there to begin with on every session.
  #15
Old 09-11-2007
SOUND
Is it bad to record loud sources with mics that don't have very high SPL levels? I feel like i remember reading about people damaging the diaphram when recording loud sources with condensors.
  #16
Old 09-11-2007
SOUND
Yeah i could really use a nice pair of iso cans, I never really focused on buying anything real nice when it comes to my headphone department. Shit I only have AKG K44's, pretty much as cheap as they come, they get the job done. I don't think they are the best with isolation but I'll have to try this idea because trial and error is kind of a bitch.
  #17
Old 09-11-2007
SOUND
Sounds pretty cool, what kind of guitars do you use. Do you think it would sound appropriate with Strats? Do you have any sample you can post?
  #18
Old 09-11-2007
Guitarer Guitarer is offline
Custom User Title
Guitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond reputeGuitarer has a reputation beyond repute
I've heard it from a few bands. I believe Finger Eleven's done it.
  #19
Old 09-11-2007
SOUND
I'm about to hit buy on those Direct Sound Extreme Isolation headphones. Any thoughts before I add them to my cart and do the deed?
  #20
Old 09-11-2007
Dedicated Member
Here's the only immediately available sample of this tecnique I have. The guitar was a semihollow dot/es335 kinda guitar with old ass strings, bass is a standard fender jazz bass. Both were miced at the 12th fret with a CAD m177 and DI into a Firepod. I'm not proud of this recording. It's a guitarist a band I work with playing all of it.
Rate of Release
  #21
Old 09-12-2007
IronFlippy's Avatar
IronFlippy IronFlippy is offline
Dedicated To My Member
IronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond repute
If you have a decent room, try pulling the mic back a foot or two, and letting the room add to the sound. It gives a more relaxed feel to the track, instead of being in your face. Plus, it adds dimension to the song.
I can't listen to that much Wagner. I start getting the urge to conquer Poland.
  #22
Old 09-12-2007
SOUND
Rate of Release
Yeah, that sounds good, unique sound. I would be proud of that recording, the drums sound great if you ask me. Sounds like a tightly tuned set. Very cool!
  #23
Old 09-13-2007
1K Silver Member
in all honesty, almost all mics made today will work on almost any source - the only real exclusion being ribbon mics...which are actually usually rated @ ridiculous SPL's, but need to stay away from anything that creates a large "puff", i.e. in the hole of a kick drum
i seriously can't remember the last "modern" mic that i've seen that couldn't handle at least 130db...which i REALLY doubt that any amp will hit with a clean tone - my 100w tube head into a 4x12 cab hits 127db when it's maxed out.
  #24
Old 09-13-2007
SOUND
Yeah, well thats good to know, thanks. With that said, what pattern do you think i should set the 4050? It has omni, 8, and cardioid. I'll try them all but what do you think would work best?
  #25
Old 09-13-2007
TripleJ's Avatar
TripleJ TripleJ is offline
Senior Member
TripleJ has a reputation beyond reputeTripleJ has a reputation beyond reputeTripleJ has a reputation beyond reputeTripleJ has a reputation beyond reputeTripleJ has a reputation beyond reputeTripleJ has a reputation beyond reputeTripleJ has a reputation beyond reputeTripleJ has a reputation beyond reputeTripleJ has a reputation beyond reputeTripleJ has a reputation beyond reputeTripleJ has a reputation beyond repute
Depends on the sound you're going for. The cardiod will result in the most 'direct' sound and not much of a room sound. Figure 8 will start to involve the room a little more, and omni will capture the entire room as much as the amp. It's a matter of how it sounds, try it out, that's what this game is about!
You'll probably find you want to use Cardioid unless you have a fantastic room but that's not always the case.
Recording live amps? EL34 MP3 Mixing Clinic 4 05-10-2006 06:05
Budget recording amps for metal ericlingus Guitars and Basses 22 03-23-2006 09:20
Small tube amps like Pro Junior GuineaMcPig Guitars and Basses 19 07-20-2004 08:54
Lexicon 284 Class A Recording Tube Amp Pearldiver Free Ads for Music / Recording Equipment 2 08-02-2002 19:30
