Effects Question...
The new forum will see a flood of stupid questions that I was too afraid to ask at Sonikmatter's faggoty Logic Audio forum.
I had no help with learning this program, so I know what I know because I just happened to stumble across it more than once. To make matters worse, I'm running 4.7. ![]() 1. How do I permanently apply an effect to an audio track? I want to be able to move tracks around without having to open the effect in the mixer and dial it in to the same settings on the new channel. |
In 7.2.3 you'd just render the audio track, and then import it back in.
"The philosophers have only interpreted the world, in various ways. The point, however, is to change it." Karl Marx |
Isn't there a bounce button on the main out/master track? You'd have to basically mute all the other channels then print your effects and save the result. Later versions of logic have an automated freeze function to make this easier.
Conditioned to self interest with emotion locked away.....if that's what they call normal then I'd rather be insane. |
The University I work at has a broadcasting program. Our I & IT department copies any program used on campus for home use, so I have a copy of Office at home in case I need to do some work at home. I could get a copy of a more recent version of Logic but I don't use a Mac, and the program is no longer compatible with a PC.
Man I barely remember 4.*
Not a fan of Sonikmatter EZ? hahaha Did Clif bust yer balls? If I recall you can monitor with fx but it requires a work around. I think you have to bounce it to a new track - ie put the fx on that you want, arm a separate track - and "record" it to that.
I don't find this stuff amusing anymore. |
Not a fan of Sonikmatter EZ? hahaha Did Clif bust yer balls? If I recall you can monitor with fx but it requires a work around. To print an effect I think you have to bounce it to a new track - ie put the fx on that you want, arm a separate track - and "record" it to that.
Nah, after browsing the forum for awhile like a good little noob, I was too scared to actually post anything.
Thanks though. |
![]() I think the way I used to do it was to mute all the other tracks and record the mix (of the track you want with effects) to disc. I can't recall if is there a 'bounce' option in V4. Quote:
Dags
I have suffered for my music, now its your turn. |
Yep. Thanks!
#12
1 Mute all tracks except the one that you are working with. Hit the 'bounce' button (bottom right of output track). This will create a new track (with rendered effects) which you can then load in and use instead of the one you are working with. 2 If you are using the ISIS sound card that came with earlier versions of Logic, you can call up the ISIS console, set input tracks 7 & 8 to SPDIF. You also need to bridge the SPDIF in and out on the breakout box (RCA to RCA). Go back into Logic, mute all tracks except the one you are working with, set the input of a new track to 7 or 8 (or both), and hit record. |
| question about cables for effects... | tom18222 | Guitars and Basses | 5 | 06-27-2007 12:58 |
| CERTAINLY retarded effects question ;) | Lomas | Newbies | 9 | 10-06-2006 03:36 |
| Effects during monitoring...not the usual question | Myriad_Rocker | Recording Techniques | 5 | 01-06-2006 09:56 |
| really simple question about 424 effects | Rocket Boy | TASCAM User Forum | 1 | 08-15-2003 14:30 |
| Heres a question for you: ---> Plugin Effects or Hardware effects? | anppilot | The Rack | 11 | 07-22-2001 13:50 |
