Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 08-20-2007
slidey's Avatar
slidey slidey is offline
Happy Legs Fingers Davis
slidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond repute
Live mixing
it's an artform in itself, to be able to produce a sound as instantly as possible. I like it myself, keeps me on my toes & tests my abilities to successfully use compression. It's good fun
anyway I'm aware from seeing other people mix (both good & bad) that everybody has their own take on how to do things & I'm just curious to know what other live producers get up to. I always ask if the artist is happy with FX being used, reverb, delay etc etc & usually the answer is yes & sometimes that can be fun. Hard to draw the line sometimes regarding overdoing things
all good experience
boing out
Slide monger
BOING!!!!!!!
G.F.C.G membership No# : 000 042
boingaroo aka wannabe drumber
Old 08-20-2007
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is online now
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
I'm not sure just what you're asking, slidey, but IMHO, it's all in the sound czech. From there it's a matter of riding the faders to adjust for differences in performance intensity when the real set begins.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
Old 08-20-2007
slidey's Avatar
I'm not really asking anything as such
I was recently involved in the planning, building & testing of a 10k PA system & there's a lot involved, we ended up running a 2 way system rather than a 3 way crossed system. The 2 way has a mono summed sub bass from 120hz down, the lows (as labeled on the X-over) are going from 120hz-600 & it's then crossed into the top cabs
over the years I've picked up quite a lot of tips & usefull info from discussing & talking over all things sonic with other live sound men & indeed watching them mix as a fly on the wall
some of the festival gigs I've played at have had mind blowing PA systems & on having a look at the backstage racks I find my head slowly starting to melt. When the onstage monitor mixer is bigger than my usual front of house
the next big PA production I'm involved in I'm going to run a 20 channel monitor mix back to the stage........could be fun
BOING!!!!!!!
Old 08-20-2007
boingoman boingoman is offline
moldin' oldie
boingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond repute
As I see it the technical aspects of the job have to be second nature, letting you concentrate on customer service stuff like this.
Are you sure you have the details of this system correct?
Old 08-20-2007
Lt. Bob's Avatar
Lt. Bob Lt. Bob is offline
Spread the Daf!
Lt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond reputeLt. Bob has a reputation beyond repute
yeah , that doesn't sound quite right if it's 2-way and the subs are covering 120hz down .... what exactly is covering between 120 and 600?
Thats it for me in this thread. I'll only eat the bait once .... voxxy
Old 08-20-2007
moldin' oldie
G.
Yeah, just like mixing in the studio. Set your gains and move the faders, and the album is pretty much done.
Old 08-21-2007
slidey's Avatar
OK I just checked the crossover
stereo 2 way by Rane.....
standard stuff like your inputs, Hi/Lo outs left & right & a mono sub bass output
So from what I can see on the unit the crossover point between hi & Lo is 5-600 & the mono sub level is from 120hz down
the crossover point was set there for the last job because it sounded right. it can cross from 100hz-3k but if the mono sub level is used anything under 150hz isn't even noticed
BOING!!!!!!!
Old 08-21-2007
moldin' oldie
It seems to me like you are running a triamped system using a 2-way corssover, not a two-way system. Just terminology. And I'm not sure what boxes you are using, but those xover points seem a little odd.
If I read it right, you are going
subs......120hz down
midbass...120-600hz
tops.........600hz up and I assume the tops have their own passive xovers.
If it sounds good, whatever, you are the person there listening, but to me it seems like you would be taking lots of stuff out of your mid/high boxes and dumping them into your midbass cabs, while taking those critical freqs out of the mid/high boxes, which are designed to reproduce them. If the mid/high packs are truly bad, a midbass box might sound better. But in my experience it's hard to find a midbass box that sounds really good up to 600hz. 150-200hz is way more typical. Depending on the boxes, I'd maybe try skipping the midbass cabs and seeing if it sounded better with just the subs and tops run at whatever xover point they like. Especially since with no delay control you are likely getting some really odd stuff happening at that 600hz point. Or get a real 3-way crossover, and go something like
Subs....65hz down
Midbass....65-150hz
mid/high....150 up
or whatever the cabs like.
It just seems to me like you may be compromising system performance with this configuration. But if it sounds good, it sounds good, and you do what you can with what you've got.
As far as the other stuff, there's nothing like having a happy client who tells you they are happy. It definitely can make your day! It's amazing how much better a gig can go when you ask people what they want to hear. Good relations are critical. It doesn't always work out, but at least you can say you tried your best to make everything smooth.
Old 08-21-2007
xstatic xstatic is offline
Been Here, Posted That
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
I enjoy doing live shows a lot. In fact, running a live sound company is half of what I do. Live mixing is definately different. In some ways it is harder, in some ways easier. With live sound you get one shot, thorugh a rig that is usually much more volatile than a studio environment, in a room that changes and is less than optimal, with gear that is usually lesser, and hot monitors that complicate it all further. The upside though is that everyone form musician to audience member has lower expectations than they do on an album and other things to distract them from intensely focusing on the mix.
As far as the PA descriptions, what you are descriobing definately sounds odd... Boingo is right on many points, but the crossover frequencies are a little weird... There are a lot of systems out there that are designed with lows that go way past 150. In fact, most of them are that way when dealing with a 4 way system. My Turbosound floodlights run up to 150 on just the 21 inch subs. EAW 850's (very standard) run well past 150 on the lows as do EV X-arrays, JBL SRX, and most every box out there for that matter.
Have fun with running th larger monitor mixes too. Runing monitors is a great way to learn frequencies and their interaction. Wait until the day though when you are not running just a 20 channel monitor mix, but actually running 20 or more monitor mixes themselves. Thats when things get alittle more stressful
Dealer for Peluso Microphones, Blue Microphones and CBI cables....
http://www.myspace.com/xstaticstudios
Old 08-24-2007
Luthier's Avatar
Luthier Luthier is offline
Newbie
Luthier has a reputation beyond reputeLuthier has a reputation beyond reputeLuthier has a reputation beyond reputeLuthier has a reputation beyond reputeLuthier has a reputation beyond reputeLuthier has a reputation beyond reputeLuthier has a reputation beyond reputeLuthier has a reputation beyond reputeLuthier has a reputation beyond reputeLuthier has a reputation beyond reputeLuthier has a reputation beyond repute
just wanted to say that I do a lot of recording and live mixing....2 very different things!
I love recording but my favorite is definatley live mixing.....you get no second chances, I love the "moment"...to me, it's all about using your guts, your instincts. There is no time for the kind of endless twiddling and tweaking that you can fall into in a studio situation. Also, in the studio I'm always second guessing what the mix will sound like on my home system or in my car etc.
Live, you don't give a shit what it might sound like anywhere but where you and the audience are! and so you do whatever it takes to make it sound good right? For example, I do some sound design work at a theatre and the PA system has been SIMmed and the master EQs are set and you can never touch them. In a live band mixing situation I'll often grab the mains EQ and adjust it rather than adjusting that particular freq on the channel strip
Live Mixing Situation Scriabin Mixing / Mastering 0 12-19-2001 21:05
HELP!! Live Mixing!! Nilbog Mixing / Mastering 8 05-09-2000 14:13
Mixing Bands Live Fishmed Mixing / Mastering 2 02-08-2000 21:59
