Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 08-04-2007
atticus3897 atticus3897 is offline
Newbie
atticus3897 has a reputation beyond reputeatticus3897 has a reputation beyond reputeatticus3897 has a reputation beyond reputeatticus3897 has a reputation beyond reputeatticus3897 has a reputation beyond reputeatticus3897 has a reputation beyond reputeatticus3897 has a reputation beyond reputeatticus3897 has a reputation beyond reputeatticus3897 has a reputation beyond reputeatticus3897 has a reputation beyond reputeatticus3897 has a reputation beyond repute
some guitar help...
something is wrong with my guitar, it is a Gibson Les Paul Faded Special, and when I run it through my half-stack, sometimes I get a crackling noise, sometimes I don't, but I do get some hiss (kinda sounds like one of those bug zapper things) anyways, i dont know if it is the pickups or if i need to get it rewired, anybody got any idea whats going on? i know its not the amp because 1. its new and 2. my epiphone doesnt make any noise if i do the same thing
thanks
Old 08-04-2007
YeshuasFan's Avatar
YeshuasFan YeshuasFan is offline
Just L'il Ole Me
YeshuasFan has a reputation beyond reputeYeshuasFan has a reputation beyond reputeYeshuasFan has a reputation beyond reputeYeshuasFan has a reputation beyond reputeYeshuasFan has a reputation beyond reputeYeshuasFan has a reputation beyond reputeYeshuasFan has a reputation beyond reputeYeshuasFan has a reputation beyond reputeYeshuasFan has a reputation beyond reputeYeshuasFan has a reputation beyond reputeYeshuasFan has a reputation beyond repute
I'd start by checking the patch cord.
"To have the right to do something is not the same as to be right in doing it."--G.K. Chesterton
Old 08-04-2007
Anfontan's Avatar
Anfontan Anfontan is offline
Banned by eurt
Anfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond repute
I agree that the cable is the best place to look first. After that I would open the control panel and see if there is a good ground to the electronics-usually all the volume and tone control cans will be wired together for a common ground, and the 3rd pin on the volume pots will be grounded to the can itself.
Also, check the guitars output jack to be sure its not loose-that the nut is holding it tightly-that would cause the problem you are describing-intermittent connections. Hope this helps.
Old 08-04-2007
ez_willis's Avatar
ez_willis ez_willis is offline
Virtual Ninja
ez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond repute
Sounds like a loose wire at the output jack. You'll need to replace the guitar.
Originally Posted by 60's guy View Post
You win.
Old 08-04-2007
Newbie
ok if you guys can see from these pictures let me know if things look right...
http : // www . geocities .com/noiseboxrock/index . htm
just fix the spaces in the url
Old 08-04-2007
ez_willis's Avatar
Virtual Ninja
Would you like me to come fix the guitar for you, too?
You win.
Old 08-05-2007
Newbie
i'm just looking for some help and i couldn't post images or url's so i put spaces in
Old 08-05-2007
ez_willis's Avatar
Virtual Ninja
Ah! New feature on the recently upgraded board. My bad. Sorry.
I removed the spaces and pasted the link and it still wouldn't load.
PM me the address.
You win.
Old 08-05-2007
ez_willis's Avatar
Virtual Ninja
PM me the address.
Click on my username and select Send Private Message
You win.
Old 08-05-2007
c7sus's Avatar
c7sus c7sus is offline
Disenfranchised Member
c7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond repute
Or a preamp tube going microphonic.
Old 08-05-2007
Flamin Lip's Avatar
Flamin Lip Flamin Lip is offline
Dedicated Member
Flamin Lip has a reputation beyond reputeFlamin Lip has a reputation beyond reputeFlamin Lip has a reputation beyond reputeFlamin Lip has a reputation beyond reputeFlamin Lip has a reputation beyond reputeFlamin Lip has a reputation beyond reputeFlamin Lip has a reputation beyond reputeFlamin Lip has a reputation beyond reputeFlamin Lip has a reputation beyond reputeFlamin Lip has a reputation beyond reputeFlamin Lip has a reputation beyond repute
Are you close to a CRT, TV neon sign? Does this happen everywhere or just in certain rooms?
"Frisbeetarianism is the belief that when you die, your soul goes up on the roof and gets stuck."
George Carlin
  #12
Old 08-06-2007
Newbie
PM me the address.
no problem, i sent you the link in a message, let me know if that works...
and i know its not something that is around me in the room because its in the same chair in the same situation and these noises do not happen with my epiphone but they do happen with my gibson
  #13
Old 08-06-2007
ez_willis's Avatar
Virtual Ninja
thanks
To confirm that it is in fact the guitar, do you have another amp to plug into?
It's more than likely a loose wire at the output jack, but I still can't open the link.
You win.
  #14
Old 08-06-2007
ez_willis's Avatar
Virtual Ninja
Have you removed the cover plate to inspect the wiring?
You win.
  #15
Old 08-07-2007
Newbie
yes i have, that is what is in the pictures.. possibly i could e-mail them to you?
and at the moment i do not have another amp to plug into, however, i have other guitars that i have plugged into this amp and it is only the gibson that has this problem
  #16
Old 08-07-2007
Crumbles Crumbles is offline
Banned
Crumbles has a reputation beyond reputeCrumbles has a reputation beyond reputeCrumbles has a reputation beyond reputeCrumbles has a reputation beyond reputeCrumbles has a reputation beyond reputeCrumbles has a reputation beyond reputeCrumbles has a reputation beyond reputeCrumbles has a reputation beyond reputeCrumbles has a reputation beyond reputeCrumbles has a reputation beyond reputeCrumbles has a reputation beyond repute
you should be able to post links and pictures now
  #18
Old 08-08-2007
tom18222 tom18222 is offline
yes
tom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond reputetom18222 has a reputation beyond repute
Fuck You You Fucking Cocksucker
  #19
Old 08-10-2007
Newbie
anybody got any ideas on what is wrong?
  #20
Old 08-15-2007
Newbie
can anybody please help based on the pictures?
  #21
Old 08-15-2007
JPXTom's Avatar
JPXTom JPXTom is offline
Bizzle Studio...Guy.
JPXTom has a reputation beyond reputeJPXTom has a reputation beyond reputeJPXTom has a reputation beyond reputeJPXTom has a reputation beyond reputeJPXTom has a reputation beyond reputeJPXTom has a reputation beyond reputeJPXTom has a reputation beyond reputeJPXTom has a reputation beyond reputeJPXTom has a reputation beyond reputeJPXTom has a reputation beyond reputeJPXTom has a reputation beyond repute
You know i have had problems similar and it has been the cord...but obviously if other guitars work then thats not the case. make sure the input jack on ur guitar is good..cause thats been the case before as well.
  #22
Old 08-16-2007
steveuk steveuk is offline
Newbie
steveuk is on a distinguished road
Hi new here and my first post so I hope I can help, the photo's dont really help as even really iffy contacts can take some close inspection, I did notice that you do not appear to have any sheilding in the "pot"bay,which I would have exected with a gibson, if you are useing the same lead for both guitars then its unlikely to be the lead, the jack socket can often be a problem if is slightly loose,there is a longer contact bar in the socket that makes contact with the signal tip of the jackplug,sometimes the "spring" has gone out of the bar and a gentle bit of bending can tighten up the contact with the jack signal tip,check also your pickup changeover switch by wiggleing it and note if there is any noise when you do this, the same with each of the pots volume and tone, if there is any noise increase or decrease you could try a blast of tandy contact cleaner the same will work on the pickup selector,If none of this helps you are going to have to get to work with a soldering iron and just lightly retouch every soldered joint with the minimum of solder on the iron(low wattage) or check all contacts with a multimeter, try to get some screening foil in your pot bay though and ground it, if you need a cicuit diagram pm me I have most models and pickup wireing codes...good luck
  #23
Old 08-16-2007
Zaphod B's Avatar
Zaphod B Zaphod B is offline
President, Ramrod Club
Zaphod B has a reputation beyond reputeZaphod B has a reputation beyond reputeZaphod B has a reputation beyond reputeZaphod B has a reputation beyond reputeZaphod B has a reputation beyond reputeZaphod B has a reputation beyond reputeZaphod B has a reputation beyond reputeZaphod B has a reputation beyond reputeZaphod B has a reputation beyond reputeZaphod B has a reputation beyond reputeZaphod B has a reputation beyond repute
Like steveuk said, check the pickup selector switch and exercise all the volume and tone pots. Really dirty pots can get nudged into a position where the moveable arm is just barely making contact because of dirt or oxidation - just sweeping them through their range a few times can often clear them up.
Beyond an iffy output jack, the other possibility is that you have a cold solder joint somewhere.
Zaphod B
Two-Headed President of the Galaxy (in exile)
Tunes at http://www.soundclick.com/cowtowntommyboy
"I have educated. I know what asshole is. "
How to Play Guitar, by David Fair Pirateking Guitars and Basses 28 10-16-2008 12:12
What's your favorite Guitar tone/sound?! carlosguardia Guitars and Basses 90 08-16-2008 23:00
Live Vox/Guitar: Keeping Guitar out of the Vocal Mic SmattyG Recording Techniques 19 11-27-2006 14:36
God! Can someone PLEASE help me fix my Epiphone ES-335 Dot guitar?!?!?! pisces7378 Guitars and Basses 22 08-21-2003 22:25
