Old 08-02-2007
Damo Damo is offline
Newbie
Damo is on a distinguished road
arghhh - inserting compression
'sake...just got back from the music store with 2 y-cables, 1/4"TRS to split female XLR...hooked these up to my stereo compressor (dbx 266xl) and insert the 1/4" ends in my main inserts (i use a mackie cr1604vlz)...as soon as they are in, NO SIGNAL!!! what the hell am i doing wrong?
also, if someone knows how i'm supposed to hook up a stereo EQ along with the compressor, could you please let me know...as the y-cables are taking up all available XLR jacks on the back of the compressor, can i out from the EQ into a 1/4" input on the compressor (ie. can the compressor take both the xlr and 1/4" inputs in one channel?)
sorry for the rant...hungry/lightheaded/mad...
Old 08-02-2007
chessrock's Avatar
chessrock chessrock is offline
Banned
chessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond repute
Did you turn the power on?
Old 08-02-2007
Newbie
aye, i did....power is on everywhere...
Old 08-02-2007
Newbie
i just thought of something...are the connectors to the compressor supposed to be TRS too, or can they be XLR?
fuck this is doing my head in.
Old 08-02-2007
MOFO Pro MOFO Pro is offline
Opinions are like SM-57s
MOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond reputeMOFO Pro has a reputation beyond repute
Was it an "insert" cable or a "Y" cable... A "Y" sends the same signal balanced signal to both XLRs... the "insert" cable splits to an unbalanced send and return
It's not just the signal chain... It's the hands that touch it
Old 08-02-2007
Newbie
well sir, it's a "Mogami insert 6ft 1/4"TRS-XLRM&F"
it's the one under Single Channel Insert (top left group) with order # R296 0106 on the following pdf:
http://www.radialeng.com/rcs/pdfs/radcat-insert-y.pdf
Old 08-02-2007
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
Looks like 'tip is send on the mackie. Does the cable have tip going to the male XLR for the input (FM) on the dbx?
No ohm meter? Maybe jack the input up, threshold down and tap the tip or ring.
To add eq to the chain just continue the the loop- comp (or eq) out > eq (or comp) in, out > to insert return.
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
Old 08-02-2007
superspit's Avatar
superspit superspit is offline
idiots unite!
Location: I hit a live electric bass repeatedly with a maraca, so I needed to mic the maraca and the bass amp at the same time.
superspit has a reputation beyond reputesuperspit has a reputation beyond reputesuperspit has a reputation beyond reputesuperspit has a reputation beyond reputesuperspit has a reputation beyond reputesuperspit has a reputation beyond reputesuperspit has a reputation beyond reputesuperspit has a reputation beyond reputesuperspit has a reputation beyond reputesuperspit has a reputation beyond reputesuperspit has a reputation beyond repute
.........can the compressor take both the xlr and 1/4" inputs in one channel?...
Not sure this is a good idea, but maybe refer to your hardware's manual/schematic?
I did read somewhere that just because you have 2 sets or formats of I/O, you wouldn't necessarily use them at the same time.
Generally, for inserts (master or channel) I stick with the 1/4 inch stuff, it works very well.
I do run a 'program compressor' and 'graphic' as my master fx inserts, and these are 'looped' together (as I only have 1 master insert in my desk), as MIXSIT suggested above!!!
Regards,
Spit.
G.F.C.G. membership #:000038.
"I love sitting at a big console with blinking lights and knobs and feel like Mr.Sulu on the bridge of the Enterprise"
my shit!
http://www.soundclick.com/bands/page...?bandID=742373
www.myspace.com/obzcure
Old 08-03-2007
sajs sajs is offline
Dedicated Member
sajs has a reputation beyond reputesajs has a reputation beyond reputesajs has a reputation beyond reputesajs has a reputation beyond reputesajs has a reputation beyond reputesajs has a reputation beyond reputesajs has a reputation beyond reputesajs has a reputation beyond reputesajs has a reputation beyond reputesajs has a reputation beyond reputesajs has a reputation beyond repute
http://www.mackie.com/pdf/1604vlzpro_om.pdf
Your mixer says to use 1/4" insert cables for the main inserts. I would try those, that's what I use.
The way I hook up my EQ and Comp to the main inserts is, the SEND to the Comp In, Comp OUT to the EQ IN, EQ OUT on the RETURN to your main insert.
You do this for each L&R insert. Good luck.
Old 08-03-2007
Newbie
so no xlr anywhere?
every 1/4" should be TRS?
i'm praying that the inserts themselves haven't been screwed with - i bought the board second hand and the pod had been flipped.
Old 08-03-2007
No there's just no advantage to the XLR in this case since the insert path is unbalanced.
The insert end is TRS because it's two paths.
Download the manual. Look at the circuit explanations.
Then test the in and out paths.
  #12
Old 08-03-2007
There's always the possibility that you've swapped your send and return... you have tried them both ways??
  #13
Old 08-03-2007
That's the thing. With XLR's it's not an option.
  #14
Old 08-03-2007
Huh????????????????????
  #15
Old 08-03-2007
On the receiving device, inputs are fm, male out (if I have the gender right.
  #16
Old 08-03-2007
superspit's Avatar
idiots unite!
all this talk of gender and going both ways.....!!
geesh......am I in Adult Matchmaker, or what!!!?
heehe!
my shit!
  #17
Old 08-05-2007
VSpaceBoy's Avatar
VSpaceBoy VSpaceBoy is offline
..loading
VSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond repute
Originally Posted by Damo View Post
so no xlr anywhere?
Not true, it can be either it doesn't matter.
Have you tried reversing as mentioned?
If still no luck just trouble shoot to see whats not working.
Are the lights showing a signal coming into the 266?
Try running a 1/4" from the insert, to the line in on a different channel to verify that its sending a signal.
Then
  #18
Old 08-06-2007
So Damo, did you get it figured out? What happened?
Just curious.
Wayne
the Basics fuquam Mixing / Mastering 26 02-26-2007 18:45
Multiband Compression DrunkPete Mixing / Mastering 20 11-24-2005 19:30
compression help and tips needed for sequenced music tomc Mixing / Mastering 1 05-31-2004 19:08
Compression on final mix Jack Real Mixing / Mastering 3 05-26-2004 10:37
Compression setting stuff for very dynamic vox..... UberGawkman Mixing / Mastering 4 09-11-2002 23:26
