Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 08-02-2007
CIRO's Avatar
CIRO CIRO is offline
Capitu´s brother
CIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond reputeCIRO has a reputation beyond repute
M/S mastering technique
Well, I "discovered" (too late, I know...), the M/S mastering "trick" (Tom "masteringhouse" page, tks...)
I´m doing some experiences, seems to be definitelly another perspective of mastering.
My question:
when a Mastering Engineer take a project, in what situation he/she uses the M/S?
I´ts more a technique to fix mixing issues (like voice and/or instruments eq/volume ,and maybe changing things that would be not necessary if mix it was well balanced?)
Or even with a very good mix this technique can be used as an improvement?
(I know that "it depends" must be the right answer, but...)
Tks
Ciro
my songs
www.soundclick.com/openstation
Old 08-04-2007
masteringhouse's Avatar
masteringhouse masteringhouse is offline
www.masteringhouse.com
masteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond repute
My question:
Tks
Ciro
my songs
It's definitely not something that you want to use by default, but exactly for the reason that you mentioned, to fix mixing issues. It allows you to isolate problems based on position in the stereo field. Since vocals, snare, kicks, and bass are usually in the middle, you can eq or compress them differently to either address a problem with levels or frequency balance. Likewise it can be used to "widen" a mix by using the S component either by raising the amount, or using delay and phase "tricks".
If you have the ability to fix the mix, do it there and not while mastering. You'll have better control.
Tom Volpicelli
The Mastering House Inc.
MySpace:
www.myspace.com/masteringhouse
Old 08-04-2007
CIRO's Avatar
Capitu´s brother
Thanks,Tom!
Ciro
my songs
Old 08-04-2007
Thanks,Tom!
Ciro
my songs
My pleasure!
Tom Volpicelli
MySpace:
My Mastering Perspective Autist Mixing / Mastering 27 07-26-2005 09:22
Mastering guys... bennychico11 Mixing / Mastering 10 06-19-2005 23:13
Mastering - Oh no not again!! John Sayers Mixing / Mastering 14 01-22-2002 00:08
Mastering yourself with LOTS of time vs. Mastering House (couple of hours) Dijoux Mixing / Mastering 11 07-10-2001 04:05
