Old 07-31-2007
Whoopysnorp's Avatar
Whoopysnorp Whoopysnorp is offline
Huh huh..."member"
Whoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond reputeWhoopysnorp has a reputation beyond repute
Just picked up a Tascam ATR-60
It's the 1/2" 8-track version. Got it for $100. I'm not positive that it's in fully functional condition, though--the guy who sold it wasn't into recording and didn't know anything about it. I know that all the lights come on and the motors spin, but that's about it. I'm feeling around among my friends to see if I can find a test tone reel to borrow, and I have a friend who's experienced at calibrating tape machines who's willing to come over and help, plus he has some 1/2" tapes we can try to play on it. I also called up Tascam today and ordered a copy of the manual. My dad has a demagnetizer that I need to get from him. Is there anything else I should be aware of before I start messing with this? I am experienced with digital recording, signal paths, gain structure, etc etc, so that's all covered. However, the last analog recording I've done was on my dad's Tascam 22-4 1/4" pro-sumer machine when I was in high school.
Old 07-31-2007
Beck's Avatar
Beck Beck is offline
Analog Partisan Ranger
Beck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond repute
Nice score... hope you get it running. If you've used the 22-4, you'll be fine figuring it out.
Watch out for old sticky tape if the tape you have is old, even unused. It will mimic all sorts of mechanical problems that the machine does not really have.
«:: «::B::» «::E::» «::C::» «::K::» ::»
"Where in the hell are the red M&M's?"
~My Lil' Sister, 1976
Old 08-04-2007
Huh huh..."member"
Okay, I haven't been able to get my hands on a calibration tape, but I just got done messing with it anyway. Here's what I found:
1) I expected the low speed to be 15 ips and the high speed to be 30 ips, but a friend gave me a 2 track master tape recorded at 30 ips, and I'm unable to reproduce it at the correct speed. Either this is a 7.5/15 ips machine or there is a motor problem.
2) I recorded a sine wave sweep from 20 Hz to 20 kHz on all channels and checked each one individually on both the sync and repro heads. They all sound good except channel 1, which had this kind of rumbly distorted noise in the background of the tone sweep, particularly during the parts of the tone sweep where the frequencies were low. Does anybody know what might cause this? It played back the same way on the sync and repro heads so it's definitely being recorded to the tape. It seemed to diminish as I recorded over that part of the tape more and more. The tape was a never-been-recorded reel of Agfa 468.
Old 08-04-2007
jpmorris's Avatar
jpmorris jpmorris is offline
Tape Wolf
jpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond repute
Looks like the ATR-60 is stock at 7/15. There are 15/30 versions but this was done as an option so it's probably rarer. If it were me I'd stick with 15ips anyway.
As for the problem on channel 1, if it goes away with multiple recordings, my first thought would be to double-check the erase head and make sure it's clean.
Old 08-04-2007
SteveM's Avatar
SteveM SteveM is offline
A Complete Unknown
SteveM has a reputation beyond reputeSteveM has a reputation beyond reputeSteveM has a reputation beyond reputeSteveM has a reputation beyond reputeSteveM has a reputation beyond reputeSteveM has a reputation beyond reputeSteveM has a reputation beyond reputeSteveM has a reputation beyond reputeSteveM has a reputation beyond reputeSteveM has a reputation beyond reputeSteveM has a reputation beyond repute
I've heard that noise before and I'm pretty sure it has something to do with the bias. Maybe when you recalibrate it it might take care of it.
Old 08-04-2007
Herm's Avatar
Herm Herm is offline
1K Silver Member
Herm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond repute
I am just thinking here and dont know crap but do test tapes go down to 20 Htz? Will these machines handle stuff that low?
Old 08-04-2007
Huh huh..."member"
Good, I was hoping that was the case. From what I've read the ATR-60-16 is completely useless at 30 ips (all the low end drops off) so I wouldn't have wanted to use that anyway.
I wasn't only hearing the noise in the very lowest part of the frequency spectrum--it was still there on past 1000 Hz. Anyway, it only happened on the one track. I do need to calibrate for sure. I'm going to try recording some more stuff on that tape and then on a different tape and see if that changes anything. Overall, I'm very pleased with my purchase so far. The machine seems to be in quite good shape.
Old 08-04-2007
Huh huh..."member"
Today I recorded some guitar on it. I did notice a distinct difference between track 1 and the other tracks I tried--whereas on the other tracks the guitar sounded huge and warm, on track 1 it sounded thin and it distorted easily. There was also some background noise. Is this something that can be fixed in calibration? Can you calibrate individual tracks in that way? I'm totally new to all this...
Old 08-05-2007
Muckelroy's Avatar
Muckelroy Muckelroy is offline
Force of Nature
Muckelroy has a reputation beyond reputeMuckelroy has a reputation beyond reputeMuckelroy has a reputation beyond reputeMuckelroy has a reputation beyond reputeMuckelroy has a reputation beyond reputeMuckelroy has a reputation beyond reputeMuckelroy has a reputation beyond reputeMuckelroy has a reputation beyond reputeMuckelroy has a reputation beyond reputeMuckelroy has a reputation beyond reputeMuckelroy has a reputation beyond repute
I'm not familiar with the ATR-60, but you should isolate the problem to the electronics, or the headstack.
If at all possible, is there a way to connect the track 1 electronics to a different track on the heads? like track 3 or 4, just for troubleshooting sake?
I dunno if it's a good idea or not, but if it's possible, it's definately a good approach.
Perhaps this can be done by swapping out the cards on track 1 with the cards on a different track. Not sure exactly how it's done on this model though.........
Then again, I wouldn't even take such a step unless you've tried calibrating that track first. Then try doing this if the problem persists.
Food for thought....
Old 08-05-2007
A Reel Person's Avatar
A Reel Person A Reel Person is offline
It's Too Funky in Here!!!
A Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond repute
Arrow I'd not pass "GO" until I've made sure...
the head is spotlessly clean.
On the other hand, this kind of rumble could indicate head wear on the edge track, (1).
Still, head cleaning comes first in troubleshooting like this.
Beatles and other Classic Rock covers!! Yeah, Yeah, Yeah!!!
637 songs by 191 bands.
Old 08-05-2007
Huh huh..."member"
I've cleaned the heads every time I put tape on it--I don't think that's the issue. When I played back a pre-recorded tape, track 1 sounded fine through both the sync and repro heads. If the sync head will play that track fine, does it make sense that it would record it fine too? I'm not sure. Next step will be to wait for my manual to arrive, get my hands on a calibration tape, and align everything. Oh yeah and I need to spring for a demagnetizer too.
  #12
Old 08-05-2007
Huh huh..."member"
I didn't even know tape machines used cards. I'll look into it.
  #13
Old 08-05-2007
cjacek's Avatar
cjacek cjacek is online now
Analogue Enthusiast
cjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond repute
Is the agfa 468 tape shedding excessively, especially at the edges?
  #14
Old 08-05-2007
Huh huh..."member"
No, it doesn't seem to be shedding at all. It must have been well kept. Of the tapes I've put on there, the one that's shedding most is a 2-track master recorded on Ampex 499.
  #15
Old 08-05-2007
ausrock's Avatar
ausrock ausrock is offline
Feeling Monolithic
ausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond reputeausrock has a reputation beyond repute
While I've found the manual for my ATR-60 16 trk to be very comprehensive, it doesn't offer any troubleshooting for the electronics themselves.
Whoopy, any chance of taking some pics of the front and back of the deck. The cards in the 16 trk are easily accessed and swappable and probably are on yours as well.
--- Humans are analogue beings ---
--- Digital information lasts forever......or maybe five years...............................Which ever comes first. ---
  #16
Old 08-05-2007
Huh huh..."member"
I can see that there is some kind of motherboard the cards are on. Do they just slide out?
  #17
Old 08-05-2007
ausrock's Avatar
Feeling Monolithic
I can't see sufficient detail in the pic but if the main frame has "slides" supporting either end of the pcb's then chances are they have edge connections on the other side which push into sockets on the main pcb.......you may be able to see them if you look between the pcb's.
From my experience, they can be a very tight fit so patience and care is required to pull them free.
In my 16 trk, all this is in the lower section of the machine and the cards are vertical but apart from that difference, I can't imagine that there'd be any reason for Tascam to alter the basic methods used in these machines.
  #18
Old 08-05-2007
Huh huh..."member"
There is indeed a 'slide' on either side of the card. So, if I'm understanding you right, I should be able to just carefully pull the cards out, no tools required?
  #19
Old 08-05-2007
ausrock's Avatar
Feeling Monolithic
Provided you have confirmed that the channel cards fit into "sockets" on the main pcb, (the "sockets" are probably similar to the long RAM sockets on a PC motherboard) AND that there's no sign of anything other than the "slide" supports at the card ends holding the cards in place...........then I'd be prepared to firmly but gently attempt to remove a card.
Like I said, they are really a tight fit in the sockets but once you get the feel of them it becomes easier.
ALSO......use a marker to number each card and where it fits.......saves any mix ups if you're trying to chase down a problem .
ChrisO
  #20
Old 08-05-2007
Huh huh..."member"
ausrock, thanks for your help--I just successfully swapped cards 1 and 7, and confirmed that the problem is in the electronics and not the head. I'm sure now that it's just a calibration issue.
  #21
Old 08-05-2007
ausrock's Avatar
Feeling Monolithic
Glad to have been some help, please keep us informed as you work through this.
ChrisO
  #22
Old 08-05-2007
cjacek's Avatar
Analogue Enthusiast
Whoopy: is there any chance of posting a short soundfile of the offending channel? When you do the test tone, does ch1 stay about the same level as the rest? No dropouts or cutouts?
  #23
Old 08-05-2007
Huh huh..."member"
Don't really have the means to digitize it at the moment. The problem is now on channel 7, of course, and signals recorded to it are definitely quieter than on the other channels. If I'm recording over an area of the tape that I've already recorded, I don't really get much in the way of dropouts, but I do start to get them the instant the head hits a section of tape that has not been recorded yet. I'm guessing it's a bias issue. If it persists after I calibrate, then I'll start to worry, but for now I think I'm in good shape.
Speaking of good shape, this machine seems to be in surprisingly good shape. I haven't been able to identify any serious problems. It has some head wear, but the sound is still fine on both the sync and repro heads.
  #24
Old 08-06-2007
cjacek's Avatar
Analogue Enthusiast
Is anyone of the opinion that it may be a bad solder joint on that channel card?
  #25
Old 08-06-2007
Arrow Maybe just an oxidized adjustment pot.
FS: TASCAM 34B New-In-Box! cjacek Free Ads for Music / Recording Equipment 33 12-13-2007 05:02
Pro Tools Digi 001 OR Tascam 2488 sevendustweb Digital Recording & Computers 3 10-21-2005 16:06
Pro Tools Digi 001 OR Tascam 2488 sevendustweb Newbies 5 10-21-2005 15:37
Mackie into Tascam problem SouthSIDE Glen Recording Techniques 2 04-27-2005 19:35
Urgent: Tascam MS-16 / MSR-16 / ATR-60 ? gilwe Analog Only 24 01-30-2004 08:33
