Drum Mics: How is this for a start?
So I'm moving into the realm of micing up a full drum kit. I'd like to mic up as many things as I can, really. I can turn off mics that I don't need. And I'm going to do some degree of sound replacement from time to time so I'd like to keep lots of mics on the kit so I can have lots of options during mixing.
Here is my current thoughts on what I'm wanting to use. Please let me know if you think this would be a good starting point or not. To date, most of my recording research has been centered around mixing and recording electric guitars. I was using BFD and programming my stuff. But now, I want to get into recording a kit since I want to record some bands. Kick: AKG D112 Snare: Audix i5 Toms: Audix D2 x2, Audix D4 x2 Hats: Shure SM57 Ride: Shure SM57 Overheads: Rode NT5 Pair (just picked some up for $285, shipped) Should I mic the top and bottom of the snare? Also, ANY other suggestions are very appreciated! EDIT: For reference, these are the mics that I currently own... Rode NTK Shure SM57 x2 AT AT4033 Shure SM7b Naiant MSH-1 x2
Myriad Rocker My Web Design/Production Company: Myriad Productions My Band: Black Leaf Clover |
You've got a decent setup there. I ocassionally mic the port on the snare (little hole in the side) or do a top and bottom setup. Obviously, throwing a mic on the snare-side of the the snare drum will pick up more snares. If you can afford the inputs, then do this.
Also, I would suggest building a homemade version of the Yamaha Subkick if you have any 6-10" speakers lying around that you're not using. Just wire the speaker up in reverse, place it about 8-12" from the kick, facing it and run it through a DI with a pad and you're good to go. With this setup, I like to place the D112 inside the kick aimed right at the beater contact point. Be careful with phase between the D112 and the "homekick" though. Let me know if you have any questions about it. |
my 2 cents
for hats i would choose a condenser over a dynamic.
although i don't have to much experience with using 10 mics for drums. I started off with 6, then got better mics and ended up using only 4, unless I'm recording in a really nice room, then i will add a large condenser (room mic)as a 5th mic. by the way the nt5's are definitely worth the money, and for what you paid for them I'm a little more than jealouse ![]()
www.MikeUlloa.com |
That's a damn good price for the NT5s and they are great overhead mics for drums. I would suggest e604s for toms, they come in a 3 pack for around $300. I am not a fan of the audix tom mics, they have a bit too much attack for my tastes. Great for metal but not as versatile in my limited experience.
Hmmm negative on the 57s for hats and ride (do you even need a ride mic?) but the rest is good. I used D2 and D4s on toms at school and they work wonders.
How's the I5 on the snare? I currently have a 57 on the snare, thinking of picking the I5 for a rhythm guitar mic. |
From what I've read about the i5, it's great for a lot of things. It's basically a better 57. I keep bouncing back and forth on the D2/D4 and the e604. I'm settled on the D112 for kick and the i5 for snare, though. I might actually throw an SM7 or SM57 on the bottom.
I have a set of E604s and have never really been satisfied with the tones they produce. I'd opt for SM57s over the 604s any day.
http://www.myspace.com/sundrone |
Wow, I find them to be much smoother than 57s on toms. Even for guitar cabs or bass they sound much fuller to me. I gave up my 57 on snare for a GT Convertible. It really cuts through the mix in a noticeable way. I rarely mic my hihat but an e609 picks it up well when I do.
You may find that between the overheads and bleed through from the other mics that, a mic on the hi-hats is not needed. I dont mic them and they come out fine. You can use the extra 57 for the snare bottom (reverse the phase if needed), Or as a backup when needed. If you dead set on using a mic on the hats, then when mixing the drums, mix it in last. You might see what I am getting at.
#12
#13
My current drum mic setup is really pleasing to my ears at the moment, and for the most part they all can serve other purposes very well!
Kick - Audix D6 (especially good for heavier stuff, but also can be used for other stuff if you mess around with placement) Snare Top - Audix I5 Snare Bottom - either SM57 or MXL990, depending on the snare Toms are Sennheiser e609s on 12" and smaller and AT Pro25s on anything bigger Overheads - MXL991s Hat/Ride - CAD M177/MXL990 I used to mic the hat but always found it just wasn't getting used much, if I mic a cymbal I'd rather do the ride personally. Depending on the style of music a well placed room mic can be really helpful in making the kit sound more full. Here is a song I just recorded for a band where I used the entire setup above except I didn't use a bottom snare mic or room mic. This mix wasn't the final, but my internet is too slow for me to upload the final mix. http://www.lightningmp3.com/live/file.php?fid=8293
Poop |
#14
if you mic the ride and the hi hat and bring them up in the mix just enough so that you get better pan separation. but definately i would use a pencile condencer on the ride and the hats and not a dynamic.
Mackie 32.8+24.E plus automation [2] Mackie MDR 24/96 mtr e-machines pc/Nuendo for tracking and editing m-audio firewire 410, samson c01, audix d6, samson tom mics Alesis qs7 keyboard controller, Korg Triton Rack, A R T,preamps |
#15
$0.02
Yeah, other than your ride & hats, good setup.
Try the SM7 in the kick if you haven't already, you may be surprised! Also, try i5 on top snare, 57 on bottom, and if you can't afford both mics for inputs or whatever reason, i think go for bottom instead of top every time!
Kicking it lo-fi: POS computer Cubase SX2 M-Audio Delta 1010LT ART Studio V3 Tube MP Behringer Eurorack Desk AKG C3000B Shure SM58 Shure SM57 Sennheiser e818 S II Ashton DMP-100 drum mics |
#16
Really? I never heard of that. Well, I've heard of riding faders for mix purposes, etc...But never heard of varying the volume of overheads in a song. Isn't that like taking the drums in and out of the room during the song???
#17
I forget where I heard to try that. But after I heard it, I tried it out and it was pretty cool. Granted, I was using BFD so I had direct mics on everything as well. The overheads just came real low in the mix so all I had going was a "close mic" on everything. Make more sense now? Makes the chorus really slam in the few songs I've tried it on.
#19
I'm contemplating micing them up with something else, though. Don't know what yet. Preferably something that sounds good but doesn't break the pocket book.
#20
How does your room sound?
Is it carpeted or wooden floor? If its carpeted, put the drums on a sheet of plywood and put a 57 on the top snare about 1.5-2 inches above the rim pointed at the centre. If you back the mic off a little and have a reflective surface under the drum, the snare wires will reflect back up into the mic and give you a nice snappy sound. I usually find a snare recorded on a carpeted floor to be a little dull. I always find snare the hardest to capture well, so maybe stick another mic on it really close to use as a trigger. Try the d112 or sm7 on the kick, the audix on the toms, the rodes as overheads and maybe put the NTK about 15 feet out from the kit pointing straight at the snare if you have the room. Thats what I'd do anyways ![]() |
#21
Why not go with the Naiant MSH-1s for your hat & ride? Your overheads are going to pick up tons of cymbal anyway, so the high-end rolloff probably won't be an issue - it might even be an asset.
Of course, there's also the voice in my head that says if you can't do it with a 57 then you aren't really trying... ![]() |
#22
Okay, this might be it. Let me know what you guys think.
Kick In - AKG D112 Kick Out - Shure SM7b Snare Top - Audix i5 Snare Btm - Shure SM57 Tom 8" - Audix D2 Tom 10" - Audix D2 Tom 14" - Audix D4 Tom 16" - Audix D4 Overhead R - Rode NT5 Overhead L - Rode NT5 Room - Rode NTK Hi-Hats - Audio Technica AT4033 Ride - MXL V67G That still leaves me with 2 of the Naiant MSH-1's and a Shure SM57 to spare.
#23
#24
#25
Myriad, that sounds good and should give you plenty of options, the only thing i would add is another 57 on the snare top, placed very close to the head purely as a trigger if you have the option.
I usually find I need to back the snare mic off a good bit to get a great sound out of it and then if you are using that track to trigger hits also, tom and kick bleed may begin to set off the snare trigger. This is only really a problem if you have a lot of dynamic snare work I suppose though. |
| Any great alternative to the SM57 for the snare? | endserenading81 | Microphones | 43 | 08-02-2007 08:18 |
| i need some help with drum mics | hardcore guy | Microphones | 3 | 06-13-2005 16:12 |
| Need some advice on buying drum mics | superstupid | Drums and Percussion | 9 | 03-13-2005 08:12 |
| Quality of CAD drum mics | PeteHalo | Microphones | 2 | 01-09-2003 00:23 |
| Quality of CAD drum mics | PeteHalo | Drums and Percussion | 2 | 01-08-2003 07:48 |
