Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 07-20-2007
Seafroggys Seafroggys is offline
Force of Nature
Seafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond repute
Output from Cubase LE to my speakers
So I have a Presonus Firestudio with Cubase LE. Currently I can hear everything normally through the headphones plugged into the front of the Firestudio.
However, I just got some cheap computer speakers that plug into the typical green soundcard port on the back of the tower. Now these can play everything outside of Cubase fine, but cannot playback anything in Cubase.
Is there anyway to route what goes through Cubase into the standard Soundcard?
Old 07-21-2007
jaybriggs84 jaybriggs84 is offline
Dedicated Member
jaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond reputejaybriggs84 has a reputation beyond repute
This isn't the answer you want, but cheap computer speakers are NOT what you want to be listening on
Old 07-21-2007
Force of Nature
Yes, because I bought these cheap speakers thinking they would make kickass studio monitors
Its really hard to playback mixes for people when you have two pairs of headphones, one of them being used by you.
Old 07-21-2007
TimOBrien TimOBrien is offline
2.5K Gold Member
TimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond repute
If you have multiple people listening to headphones you need a headphone amp; Behringer 4700 is $100 and works great - there are others as good.
Here's a basic monitor guide to get you started (you should be reading ALL of Tweak's guides...)
http://www.tweakheadz.com/studio_monitors.htm
Old 07-21-2007
Force of Nature
Why is nobody answering my question?
I have read Tweaks. I will get monitors eventually. I got $20 speakers so I have something now for people to listen to! So how can I get Cubase to work through the internal soundcard in addition to my Firestudio?
Old 07-22-2007
Gandalf's Avatar
Gandalf Gandalf is offline
Number 10
Gandalf has a reputation beyond reputeGandalf has a reputation beyond reputeGandalf has a reputation beyond reputeGandalf has a reputation beyond reputeGandalf has a reputation beyond reputeGandalf has a reputation beyond reputeGandalf has a reputation beyond reputeGandalf has a reputation beyond reputeGandalf has a reputation beyond reputeGandalf has a reputation beyond reputeGandalf has a reputation beyond repute
The answer to your question is yes. You need to go to the VST connections menu and create a sterio output bus with your soundcard selected for the channels. Then select this bus as the output bus for all the tracks.
That said, jaybriggs84 is correct you will get a lot of latency as the soundcard will not have an ASIO driver and the sound quality will suck.
Old 07-22-2007
Force of Nature
I could always try finding some conversion cables, two 1/4" mono to single 1/8" stereo plug, so I can plug it into my monitor port. But I dunno if that would work, with volume and power issues.
Old 07-22-2007
true-eurt's Avatar
true-eurt true-eurt is offline
Mrs. Hyde
Location: Loving the imperfect is the perfection of love
true-eurt has a reputation beyond reputetrue-eurt has a reputation beyond reputetrue-eurt has a reputation beyond reputetrue-eurt has a reputation beyond reputetrue-eurt has a reputation beyond reputetrue-eurt has a reputation beyond reputetrue-eurt has a reputation beyond reputetrue-eurt has a reputation beyond reputetrue-eurt has a reputation beyond reputetrue-eurt has a reputation beyond reputetrue-eurt has a reputation beyond repute
Thank you Gandalf!!
SpankSHED songs
I may be off my rocker but I'm still on a roll
EurtSongs
Last edited by true-eurt; 07-22-2007 at 15:05.. Reason: Wanted to try out my new White Out pen.
Old 07-22-2007
Nick98338's Avatar
Nick98338 Nick98338 is offline
Dedicated Member
Nick98338 has a reputation beyond reputeNick98338 has a reputation beyond reputeNick98338 has a reputation beyond reputeNick98338 has a reputation beyond reputeNick98338 has a reputation beyond reputeNick98338 has a reputation beyond reputeNick98338 has a reputation beyond reputeNick98338 has a reputation beyond reputeNick98338 has a reputation beyond reputeNick98338 has a reputation beyond reputeNick98338 has a reputation beyond repute
Why use the the computer's cheap, internal sound card? The Presonus *IS* a sound card. A rather high quality sound card. Why use the presonus to get sound into the computer, and then use the cheap computer sound card to get sound out of the computer? Why confuse the computer? Disable the computer's internal sound card and use the Presonus for all sound, both in and out of the computer.
Old 07-22-2007
Force of Nature
Problem is, the speakers have a 1/8" Stereo plug, and the Firestudio has 1/4" Mono outs. So I'll need a converter.
Old 08-11-2007
Obi-Wan zenabI's Avatar
Obi-Wan zenabI Obi-Wan zenabI is online now
Force of Nature
Obi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond reputeObi-Wan zenabI has a reputation beyond repute
I run some 1/4" outs from my firePOD into a 1202 vlz, and then out from the tape outs on the VLZ to my fancy 1970's-1980's hi-fi in order to monitor. This is because recording gear and home stereo gear run at different levels-- +4 dB and -10 dB respectively. Not that I fuly understand what that means.
That may or may not be useful for you, but I am sure there are some CR outs on the F.S. that you could rig up your basic Radio Shack adapters to get it from two 1/4" monos to one 1/8" stereo. I bet you'll lose far less audio quality that way, when compared with running it thru your computer's sound card.
I don't need no stinkin' sig.
  #12
Old 08-14-2007
cusebassman's Avatar
cusebassman cusebassman is offline
Freakin' sweet
cusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond repute
Spot on. There's an adapter for just about everything - even things you aren't supposed to do (like drop one side of a balanced XLR and convert it to 1/4" mono )
Originally Posted by Ford Van
I AM RIGHT
  #13
Old 08-19-2007
rockinrocker rockinrocker is offline
Freedom Hater
rockinrocker has a reputation beyond reputerockinrocker has a reputation beyond reputerockinrocker has a reputation beyond reputerockinrocker has a reputation beyond reputerockinrocker has a reputation beyond reputerockinrocker has a reputation beyond reputerockinrocker has a reputation beyond reputerockinrocker has a reputation beyond reputerockinrocker has a reputation beyond reputerockinrocker has a reputation beyond reputerockinrocker has a reputation beyond repute
I think you also need to select you're onboard sound card under device setup, and i'm pretty sure you can't use 'em both at the same time.
DI Box the solution? TripleJ Newbies 52 09-08-2006 09:52
Vocal Output Sounds different from Headphone then Speakers?? newbieatthis Digital Recording & Computers 9 05-23-2006 16:24
Computer Speakers with cubase LE david7287 Cubase User Forum 6 07-18-2005 16:22
Cubase SX output routing ad0lescnts Cubase User Forum 7 11-28-2004 21:38
Headphone output in cubase VST1 thunder2 Cubase User Forum 1 08-15-2004 09:02
