overhead technique
So i was wondering what the best technique is for drum overheads. So far i have tried XY and also i have put the 2 overheads on their respectable sides. I havent really figure out which is best yet, and i was wondering if anyone had good ideas.
I say A LOT depends on the drummer AND room dimensions - especially ceiling height. Also depends on the type of mics and the pick up pattern... Also depends on how many other mics will be used AND the sound engineer's abilities. So you really HAVE to experiment.
I highly suggest you try ORTF, NOS and Blumlein pairs: http://en.wikipedia.org/wiki/Stereop...ty_stereophony Cheers, Rez Last edited by RezN8; 07-16-2007 at 08:37.. |
Try the Recorderman overhead technique. A lot of people have used it with good results. Here's a demo of it being used: http://youtube.com/watch?v=IiFOD1EeKhQ
A great deal of what techniques you can employ are dictated by the room. The smaller the space, the more restricted your choices become. Personally, I usually try one of three, X-Y, Mono (single mic) or a Jeklin Disc with a couple of omni's. These slow down the chances of phase problems and the X-Y or Jeklin setup still sounds like good stereo to me. And I really prefer the mono overhead but 99% of clients look at me like I'm from another planet when I mention it.
Mike |
I use a mono overhead, mainly because my only matched pair are cheap and I have an OK LDC to use, but it does the job for me!
Kicking it lo-fi: POS computer Cubase SX2 M-Audio Delta 1010LT ART Studio V3 Tube MP Behringer Eurorack Desk AKG C3000B Shure SM58 Shure SM57 Sennheiser e818 S II Ashton DMP-100 drum mics |
I use a spaced pair. I also worry more about capturing the cymbals rather then making sure everything is phase coherent, because phase coherency is near impossible and usually means you are compromising positioning. So what do I do? I use the phase flip button when needed. Its there for a reason.
Steven Slate Hear drum samples used by today's top mixers at: www.stevenslatedrums.com |
I've recently started using a mono overhead SDC with 2 LDCs in the room setup to about the position of a first row seat & equally spaced from the 1st tom & the last tom
but I'm gonna try the recorder man method. Never tried that one, thanks for the clip Steel phantom
BOING!!!!!!! G.F.C.G membership No# : 000 042 boingaroo aka wannabe drumber |
the kit is on a riser when I set this up about 1 foot off the ground & I might point out the the person's ear height for the mic is me on the 1st row position out front
which means the mic's on the floor ![]() ![]() ![]() ![]() ![]() nah I'm about 5,6 ![]()
We've used ORTF, spaced pair, XY, and Recorderman.
So far, Recorderman FTW. |
try recorderman
This place is garbage. |
I've used the Recorderman OH technique many, many times, but I can't help but feel I don't get the desired stereo spread I'm after when I use it. It was the first OH mic technique I learned here on the boards years ago. I usually use XY because I can manipulate the image by increasing the angles of the mics. I also have minimal phase issues this way. The way I see it, the Recorderman setup is for very minimalistic miking situations. If you're using more than 4 mics, I'd go with XY.
Strangely enough I've yet to try ORTF. It's been a while since I've experimented with drum tones...
Listen to my songs at: http://www.nowhereradio.com/artists/...y.php?aid=2076 The purpose of a cable is to get stuck under everything in its path. |
#12
#13
I will give it a go next time I use this technique.
#14
![]() If you use the Beyer M160/M130 combo, you'll likely dig it anyway. Those things are gorgeous on drums. |
#15
#16
I've tried M/S but my room's so small (12X14) there's no real bennifit that I can hear.
Mike |
#17
It just came to mind when you said you like a mono OH but your clients don't. If you can get a mono sound you are happy with, then you just add a fig. 8, you'll have the option of adding it in (or taking it out ) later. |
#18
A KM-184 for the center and a AM-52 for the fig 8.
Mike |
#19
I also try and have the snare centred between the OHs as much as I can. I use close mics on the cymbals also which gives me alot more control at mix down. Means I can really boost the OHs to get a natural roomy sound at times, and then I can also bring the OHs down in the mix, but still have the cymbals in there by bringing up the close cymbal mics. Eck |
| Mid Side & Blumlein Technique | karma101 | Recording Techniques | 3 | 09-13-2006 15:07 |
| Three Overhead techniques | Sonixx | Drums and Percussion | 41 | 05-10-2005 16:15 |
| X-Y overhead miking - need advice from those familiar with this technique | FattMusiek | Recording Techniques | 3 | 05-10-2005 15:05 |
| plz name that overhead micing technique | ron82 | Recording Techniques | 16 | 09-02-2003 09:21 |
