Old 07-11-2007
foreverain4 foreverain4 is offline
1K Silver Member
foreverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond repute
speaker level to line level di (electrical question)
my application:
i am a drummer. i play live with a click. i have a small mixer that i want to use to blend my monitor feed and click signal; which will then be monitored with my wired in ears. i want to make it streamline and quick to do so as setup time is limited.
my idea:
to take a parallel out of my monitor wedge (speaker level most of the time) into a di, then into my mixer.
my solution:
i know pro co makes a direct box that you can plug a speaker line in to and it coverts it to line level.
my question:
what is this box actually doing to the signal? is it just attenuating the level? what impedence does the amp see? is there any risk to the pa amp or my mixer? i have an rms di that attenuates -45db. would this essentially do the same thing as the proco?
Lynn
www.trhrecorders.com
Old 07-11-2007
1K Silver Member
i think i found my answer. according to this the RMS di should work just fine...
http://www.tkk.fi/Misc/Electronics/c...r_to_line.html
Lynn
Old 07-11-2007
engine joe's Avatar
engine joe engine joe is offline
Senior Member
engine joe has a reputation beyond reputeengine joe has a reputation beyond reputeengine joe has a reputation beyond reputeengine joe has a reputation beyond reputeengine joe has a reputation beyond reputeengine joe has a reputation beyond reputeengine joe has a reputation beyond reputeengine joe has a reputation beyond reputeengine joe has a reputation beyond reputeengine joe has a reputation beyond reputeengine joe has a reputation beyond repute
move further back in the chain before the power amp.
Old 07-11-2007
1K Silver Member
keep in mind i am looking for quick and easy. i dont want to have to hunt down a rack of amps, then try and convince the FOH engineer to let me start plugging and unplugging in his rack. read the link i posted above. looks like it should work without any issues...
Lynn
Old 07-12-2007
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
Yes, it will work. The trick is you really don't know the level off the speaker out. Power amps are mainly very low impedance current sources; whether or not there is any voltage gain depends on the amp and the setup. So it's really nice to have a variable attenuator in that situation.
Old 07-12-2007
cavedog101's Avatar
cavedog101 cavedog101 is offline
Force of Nature
cavedog101 has a reputation beyond reputecavedog101 has a reputation beyond reputecavedog101 has a reputation beyond reputecavedog101 has a reputation beyond reputecavedog101 has a reputation beyond reputecavedog101 has a reputation beyond reputecavedog101 has a reputation beyond reputecavedog101 has a reputation beyond reputecavedog101 has a reputation beyond reputecavedog101 has a reputation beyond reputecavedog101 has a reputation beyond repute
My drummer has several hookups for his inears...one of them is a Beringer box that goes inline with the speakers, so if we're in a venue with a house PA and no line out for him(one of the other boxes does this) he just takes it off of any speaker line close by. It has attenuation and a direct through so I can feed the bass signal separately which is also attenuated. It does not add impedance to the line. It was cheap cheap cheap!!!
coming soon! drool'n dogg rekords
Hey Everyone: PA System??? IronsideMessiah Other Equipment and Reviews 32 02-19-2006 10:28
Keyboard into MR8: Line level input not working properly SKYflyer Digital Recording & Computers 2 09-04-2005 14:47
HeLP! Speaker Ohms, question about hooking combo to cab and bypassing combo speaker bigcolyn Other Equipment and Reviews 4 05-11-2005 15:46
Changing speaker level to line level Racer X Other Equipment and Reviews 17 11-02-2000 11:06
Speaker level (70V) to line level JimL Newbies 7 07-19-2000 08:48
