Old 07-10-2007
gtrman_66's Avatar
gtrman_66 gtrman_66 is offline
Dedicated Member
gtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond repute
Question 1" open reel videotape machine
I figured I'd post this here since it seemed the most relevant forum.
A friend of mine does construction work and was given a GE 1" reel to reel videotape machine out of a hospital they were doing some remodeling work in. He gave it to me, and so far, I don't know what I'm going to do with it yet.
I may part it out or, if the audio track specs are good enough, may want to use the audio side for an analog mixdown deck for projects that could use the sound qualities.
So far, I have searched the web and found very little about these machines, probably because they have been obsolete for their original purpose for a long time. If anyone could point me in the right direction to a resource to find info on these things, I'd really appreciate it.
thanks
Old 07-10-2007
evm1024's Avatar
evm1024 evm1024 is offline
1K Silver Member
evm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond repute
thanks
I don't know anything about the machine but I have a 8" reel of 1" tape that should fit the machine. It appears to use a 3" hub much like a nab hub. The tape is yours for postage if you want it.
Regards
In Sunny Vancouver ..... (Washington)
Old 07-10-2007
The Ghost of FM's Avatar
The Ghost of FM The Ghost of FM is offline
French Mofo
The Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond repute
Did it look anything like this?
http://www.labguysworld.com/GECV_007.jpg
The GE in the picture was a mono linear audio recorder along with the video side of it which I believe was black & white...I can't see this as being worth much as an audio recorder given its age, probable wear and original format.
There's a bit more info on it here;
http://www.labguysworld.com/GE-CV_VTR.htm
Cheers!
Old 07-11-2007
gtrman_66's Avatar
Dedicated Member
Thanks Ghost. No, the one I have is much newer, it has a manufacture date of 1988 and it is much bigger than that. I think the model number on front is HPR-50. I'm out of town right now so I won't be able to get home and look at it again until the weekend, I'll get the model and serial numbers etc then.I just thought it might be neat if there are parts that will fit existing analog audio machines out there that folks are trying to keep running.
evm, thanks much for the offer of the tape, I'm not sure about the hub size, but I may take you up on it
Reference: 3M Audio Open Reel Tapes A Reel Person Analog Only 7 03-20-2007 17:25
Fantastic News about RMGI (EMTEC) Open Reel Tape Beck Analog Only 5 06-02-2005 22:15
Open Reel Tape-In A Pancake Bloodbone Analog Only 10 03-13-2005 17:49
A few questions on open reel tape ... cjacek Analog Only 0 11-15-2004 18:08
Where do I get a "Service it yourself" open reel instruction manual ?? cjacek Analog Only 6 09-01-2004 19:44
