Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 07-09-2007
moelar2 moelar2 is offline
Dedicated Member
moelar2 is a jewel in the roughmoelar2 is a jewel in the roughmoelar2 is a jewel in the rough
Can't edit effects settings with Numberpad
A friend came over to show me some of his cubase projects. He didn't change any settings, but ever since he's left, I can't edit effect settings with the number pad. For example, if I want to change my delay time from 200ms to 77ms, I can't do it by simply typing "77" with my numpad. Instead, I have to use my mouse, which accurate only to about 40ms (meaning, I can't go from 1 to 6; I can go from 1 to 40 at minimum).
Does anyone know where I can reset this?? I set my preferences to default, but still, it's not functioning...
Old 07-09-2007
RezN8's Avatar
RezN8 RezN8 is offline
Blick-um, blick-um...
RezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond repute
Is number lock on or off?
Is your keyboard set to Insert (help key?)
Old 07-09-2007
Dedicated Member
Its on. What do you mean by "is your keyboard set to insert"? I pressed the insert key off and on, but no change.
Old 07-09-2007
Dedicated Member
Fixed the problem. I had to go into the "key commands" menu under "File" and manually delete the pad settings. Resetting to default values didn't work on it's own b/c apparently that IS the default (though I'm positive I never changed it before).
Confused, in need of help? Benreturns Newbies 56 11-06-2003 04:02
Cool Edit Pro vs. Cool Edit 2000 Chammy Sony Tools / Sonic Foundry 9 03-30-2003 10:00
Adding Effects...PLEASE HELP! emojoe Digital Recording & Computers 1 07-28-2000 04:33
Adding Effects...PLEASE HELP! emojoe Newbies 2 07-25-2000 17:52
Adding Effects (TC Electronic M-ONE)...PLEASE HELP! emojoe Other Equipment and Reviews 0 07-24-2000 18:48
