Old 07-08-2007
elementary elementary is offline
Senior Member
elementary has a reputation beyond reputeelementary has a reputation beyond reputeelementary has a reputation beyond reputeelementary has a reputation beyond reputeelementary has a reputation beyond reputeelementary has a reputation beyond reputeelementary has a reputation beyond reputeelementary has a reputation beyond reputeelementary has a reputation beyond reputeelementary has a reputation beyond reputeelementary has a reputation beyond repute
Isolating a fridge freezer?
I have the acoustics in my recording room beginning to take shape and now I need to find a solution to the hum of the fridge.
I'll mainly be recording drums so a small level of hum is tolerable.
The fridge can't be turned off or taken out of the room, so i was thinking, build a box with no bottom out of thick plywood and line it with rockwool then slip this over the fridge.
Might this idea work? Anything I need to make sure of in construction?
Has anyone else experienced and solved this problem?
Thanks
Ryan
Old 07-08-2007
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
You have to allow for the fridge to vent the heat, if you do that, your idea will work. There should be minimum setback dimensions listed in the manual, usually it's an inch or two at the back, along with a couple of inches at the top and bottom. If you follow that, then you should be able to build a box to fit. It should still be quiet enough for drums, even with the vents. It will also help to isolate the box from the floor with rubber feet or something.
Old 07-09-2007
TimOBrien TimOBrien is offline
2.5K Gold Member
TimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond repute
Originally Posted by elementary View Post
The fridge can't be turned off ....
Yes it can.
Any fridge will stay cool for 4 or 5 hours if you leave the door closed.
(Experience during power outages from the 4 hurricanes I've had roll across me the last few years...)
Old 07-09-2007
R.A.E's Avatar
R.A.E R.A.E is offline
The Village Idiot
R.A.E has a reputation beyond reputeR.A.E has a reputation beyond reputeR.A.E has a reputation beyond reputeR.A.E has a reputation beyond reputeR.A.E has a reputation beyond reputeR.A.E has a reputation beyond reputeR.A.E has a reputation beyond reputeR.A.E has a reputation beyond reputeR.A.E has a reputation beyond reputeR.A.E has a reputation beyond reputeR.A.E has a reputation beyond repute
Originally Posted by TimOBrien View Post
Yes it can.
That is unfortunate.
As for the fridge ventin' the heat...I'm not too sure you want to throw a box over it...sounds like if you leave that box there long enough something will go wrong.
ii-V7-Imaj7
-T. Cooper
Old 07-09-2007
Faithful Departed
Lots of fridges have boxes thrown around them, it's just that they are called cabinets Hence the clearance and vent requirements stated in the manual.
Old 07-09-2007
NL5's Avatar
NL5 NL5 is offline
Unpossible!
NL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond repute
Thanks
Ryan
First off, drum tracks are the LEAST tolerable to room "noise". You have a bunch of mics all recording that low level hum, so multiply the "nominal" noise by however many mics you are using. It really starts to add up!
Second, just put the fridge on a power strip with a switch, and make the strip accessible. I have been doing it for years. Just don't forget to turn it back on!
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F.
Old 07-09-2007
Senior Member
Thanks everyone for the input Switching it off wins!
Old 07-09-2007
pandamonk's Avatar
pandamonk pandamonk is offline
Three Thousand and Counting
pandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond reputepandamonk has a reputation beyond repute
It's the cheapest options too More money for gear... bliss
Old 07-09-2007
89gtsleeper 89gtsleeper is offline
Dedicated Member
89gtsleeper has a reputation beyond repute89gtsleeper has a reputation beyond repute89gtsleeper has a reputation beyond repute89gtsleeper has a reputation beyond repute89gtsleeper has a reputation beyond repute89gtsleeper has a reputation beyond repute89gtsleeper has a reputation beyond repute89gtsleeper has a reputation beyond repute89gtsleeper has a reputation beyond repute89gtsleeper has a reputation beyond repute89gtsleeper has a reputation beyond repute
yep, power-strip that biotch
put hard drive in freezer jmorris Digital Recording & Computers 11 01-04-2006 19:52
Isolating instruments and vocal "booth" in small basement room thehymns Studio Building & Display 0 11-16-2005 23:47
Fridge from hell Secret Clubhous Recording Techniques 8 09-10-2004 10:47
