Old 07-07-2007
bloomboy bloomboy is offline
Senior Member
bloomboy has a reputation beyond reputebloomboy has a reputation beyond reputebloomboy has a reputation beyond reputebloomboy has a reputation beyond reputebloomboy has a reputation beyond reputebloomboy has a reputation beyond reputebloomboy has a reputation beyond reputebloomboy has a reputation beyond reputebloomboy has a reputation beyond reputebloomboy has a reputation beyond reputebloomboy has a reputation beyond repute
1/2" vs. 1/4" 2 track... is there really that much of a difference?
So I'm almost finished recording my first album, and am looking for a recorder to mix down to... It looks like I have two options:
1) get a 1/2" 2-track headstack for my tascam 38
2) get a 1/4" 2-track tape recorder
The second option would be about 100 dollars cheaper at current prices. Does anyone here have experience with both of these formats? Is the difference really that noticeable? Of course I'd love to make the comparison myself, but circumstances don't really permit it at the moment. Also consider that I am mixing down from 1/2" 8 track, so the 1/4" 2-track would already be a step up in terms of track width.
Peace,
Theo
Old 07-07-2007
SteveM's Avatar
SteveM SteveM is offline
A Complete Unknown
SteveM has a reputation beyond reputeSteveM has a reputation beyond reputeSteveM has a reputation beyond reputeSteveM has a reputation beyond reputeSteveM has a reputation beyond reputeSteveM has a reputation beyond reputeSteveM has a reputation beyond reputeSteveM has a reputation beyond reputeSteveM has a reputation beyond reputeSteveM has a reputation beyond reputeSteveM has a reputation beyond repute
The 1/4" 2 track would do a great job so I wouldn't say it's necessary to go to 1/2" if you want to save the money. Where do you get the 1/2" headstack?
Old 07-08-2007
Senior Member
JFR makes them... they haven't got one specifically designed for tascam recorders but I'm assuming finding a way to mount it wouldn't be too terribly difficult, and hooking it up would be a piece of cake... just attatch tracks one and two and leave the rest. But I'm pretty sure I'll just go with 1/4" anyhow. I might spring for the 1/2 if I was tracking to wide format tape, but with 1/2" 8 track I just can't see that there will be much of a difference, and like you said I'm sure it'll sound great.
Theo
Old 07-08-2007
Beck's Avatar
Beck Beck is offline
Analog Partisan Ranger
Beck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond repute
Putting a ½” headstack on a ¼” machine is an intriguing prospect that I’ve considered. I would be inclined to start with a half-track (2-track) like the 32 and add the ½” guides, lifters and reel clampers, etc. from a junked 38 or something. Your biggest gains will be in signal-to-noise ratio (S/N). Doubling track width will give you about 3dB better S/N. But the overall performance of the system will depend on how the rest of the machine is designed. You can find ¼” half-tracks that perform better overall than some ½” half-tracks. All things being equal though a ½” machine of the same model will have an advantage over its ¼” little bro.
In practice ¼” half-track (with and without noise reduction) was very common for mastering, and much of our favorite music of every genre from the ‘60s, ‘70s, ‘80s was mastered to ¼” and still is by those that prefer tape for this stage.
Each track on NAB standard ¼” half-track is a bit wider than each track on a 2” 16-track, (approximately 79 vs. 70 mils) so yes you are stepping up in track width compared to most any format people commonly use for multi-track. Think of it this way… with ¼” half-track you have tracks wider than what many people consider the ultimate – 16 on 2” and you also have a wider distance (shield) between the tracks.
So IMO 2 tracks on ½” is more than most people really need. Factor in the difference in price between ½” and ¼” tape and your total cost of ownership for the ½” can end up significantly more than at first look.
Depending on the type of music you’re mastering you may or may not desire noise reduction. Dolby A, C, DBX Type I or a single-ended device will do the trick for all but those recording the sounds of an empty anechoic chamber. (Those are creepy by the way… you can actually hear the blood rushing through your veins).
I get fully professional results with ¼” half-track, and a rather modest machine at that. There is nothing that would compel me to move up to ½” at this time.
There are ultra wide track fans out there though, but even ½” isn’t enough. I think they might do 2 tracks on 2 ft. tape if they could. There is a point of diminishing returns. ½” is reasonable but maybe not necessary.
«:: «::B::» «::E::» «::C::» «::K::» ::»
"Where in the hell are the red M&M's?"
~My Lil' Sister, 1976
Old 07-08-2007
SteveM's Avatar
A Complete Unknown
Check your Craigs list when looking for a half track. I got my 32 for $30 !! and it works great.
Old 07-08-2007
The Ghost of FM's Avatar
The Ghost of FM The Ghost of FM is offline
French Mofo
The Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond repute
Also worth noting about doing a two track conversion of a 38 is that the channel cards don't have the headroom to calibrate cleanly to a 1/2" - 1/2 track standard.
Even switching tape formulations beyond the factory 456 calibration is taking the 38 into dangerous waters so I wouldn't advise going in that direction at all.
Cheers!
Old 07-08-2007
Tim Gillett Tim Gillett is offline
Musician/technician
Tim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond reputeTim Gillett has a reputation beyond repute
You dont say what sort of music it is or give any other details.
The main sonic improvement is maybe 3 or 4 db less noise, noise which depending on the type of music may well be totally masked by the music on 1/4" anyway.
On some program, especially classical, even 1/2" is too noisy. On much pop/rock commercial stuff, 1/4" is more than good enough.
Do a real life test with your material.
The difference between 1/2" and 1/4" is probably negligible compared to the many production decisions made in the course of creating your tracks. Whichever way you go is unlikely to make or break your album.
Regards,
Tim.
Old 07-09-2007
Dr ZEE's Avatar
Dr ZEE Dr ZEE is offline
Anti-Pro Circles Insider
Dr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond repute
- Option 2. Get Half-Track And face the music.
If the 'noise' is such an "issue" here, then I'd say, for the real life test do this: get 1/4" half track 15ips deck (assuming in good working order), tascam 32 will do. Record some silence. Play back the recorded silence and struggle trying to hear that "nasty noise" (also, assuming, that the amplifier you are listening through is "noiseless" at the volume level that would require to make the tape noise audible , or you may face the conflict of noises in there). Do not do such test with some music program that follows the silence section under "investigation", becuse when the music will hit - it may permanently damge your ear (assumingly that the speaker (or phone driver) survives the blast)
specific note in case of tascam 32 - DO NOT use its headphone output for critical monitoring of material. It's only good for cue-ing. That headphone amp has its own "noise generator" built in or something, I suppose
Yeah. OK.
well, I never heard 1/2" master. so can't really say how noisy it may be. maybe it can be pretty damn noisy. oh boy -
Dr ZEE
MZE | ZDL | DZW
Old 07-09-2007
MCI2424's Avatar
MCI2424 MCI2424 is offline
1K Silver Member
MCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond repute
Originally Posted by Beck View Post
I get fully professional results with ¼” half-track, and a rather modest machine at that. There is nothing that would compel me to move up to ½” at this time.......
What is the definition of "fully professional results?"
"Tascam, Fostex or Studers don't make hit records...........people do"
MCI2424 - 2007
Old 07-09-2007
Dr ZEE's Avatar
from zeepedia:
fully professional result (definition) - the client is foolly happy and the professional's wallet is full.
Dr ZEE
MZE | ZDL | DZW
Old 07-09-2007
MCI2424's Avatar
1K Silver Member
Originally Posted by Dr ZEE View Post
from zeepedia:
So any paid work is fully professional?
MCI2424 - 2007
  #12
Old 07-09-2007
Dr ZEE's Avatar
no.
from zeepedia:
fully professional work (definition) - a work the purpose of which is achieving a fully professional result.
see post#10 for fully professional result definition
Dr ZEE
MZE | ZDL | DZW
  #13
Old 07-09-2007
MCI2424's Avatar
1K Silver Member
no.
from zeepedia:
Sounds like circular logic to me.
MCI2424 - 2007
  #14
Old 07-09-2007
ofajen ofajen is offline
Daddy-O Daddy-O Baby
ofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond reputeofajen has a reputation beyond repute
Peace,
Theo
I'd suggest you start with the 1/4" machine. Should be adequate for mixing down from your 1/2" 8 track. Try it first. After that, if you still think you need a 1/2" machine, too, you can always get one later. Besides, it's just a good thing to have at least one 1/4" machine around.
I have a friend who runs a studio in North Carolina and often mixes projects to 1/2" tape, but he generally does so because his clients insist on it because, to them, "analog" only means 1/2" tape at 30 ips, though they'd probably be hard pressed to really explain why. He'd just as soon use one of his 1/4" machines in a lot of cases, but he needs to keep his clients happy. My suggestion is that you try the 1/4" machine first and see if it makes you happy.
Cheers,
Otto
  #15
Old 07-09-2007
evm1024's Avatar
evm1024 evm1024 is offline
1K Silver Member
evm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond reputeevm1024 has a reputation beyond repute
The question is....
You know, I think that it is quite obvious what he meant. Were you asking the question in good faith or are you picking a fight? What is the point of your question?
In Sunny Vancouver ..... (Washington)
  #16
Old 07-09-2007
MCI2424's Avatar
1K Silver Member
I am doing what Dr. ZEE does everytime I mention the mere word "professional". If it works for Dr. ZEE, why not others?
Not picking a fight. Go read some of Dr. ZEES rants and you will be better informed.
MCI2424 - 2007
  #17
Old 07-09-2007
evm1024's Avatar
1K Silver Member
Dr Zee does make sense. It is not just babble. Try parable. Ever look at a Miro and have it jump into focus?
  #18
Old 07-10-2007
Dr ZEE's Avatar
amen.
Dr ZEE
MZE | ZDL | DZW
  #19
Old 07-10-2007
MCI2424's Avatar
1K Silver Member
Makes sense how?
MCI2424 - 2007
Just another thread! Gorty Roland, Boss, VS Series Forum 314 08-27-2007 04:39
1/2" and 1/4" ? themaddog Analog Only 6 05-14-2006 20:49
1/2" 4 track?? Ding Dong Analog Only 4 03-04-2006 15:26
The Grammy's bknot1 DJ & Hip Hop Production 2 02-09-2006 11:46
The Magix recording studio rufiochris182 Newbies 18 12-30-2003 14:09
