Tascam 2488 Users needed
Is anyone using a tascam 2488 or 2488mk2? I was hoping to make some 2488 recording friends to share info, tips, tricks, compare tracks, etc... etc...
there is guys here that have both and I think there is also a 2488 forum try a google on it
THIS MACHINE KILLS FASCISTS..... Quote:
There are a few 2488 users around, me being one of 'em.
Zaphod B Two-Headed President of the Galaxy (in exile) Tunes at http://www.soundclick.com/cowtowntommyboy "I have educated. I know what asshole is. "
I've got a mkII, but alot of the functionality is the same. If you ever have any questions or problems, let me know and I'm sure I can help or at least point you in the right direction.
I am a recent purchaser of a 2488 MkII. Still getting to know it (I am an evening hobbyist, recording my own songs). Lots of good stuff and a few annoyances so far.
I own a 2488 for 3years now. It works fine for me.
New 2488 Mk2 user, need help!!!
I'm usin' 1 now , but somethings ain't workin' yet.
a) it's suppose 2 record 8 simultaneous tracks, it's nowhere in the manual explained n I only managed to record only 2 tracks... Any idea??? b) how can i add external fx like reverb, compressor n make it return to the Tascam? I plugged them from Tascam fx out, returned to 4 inputs and tough I can see in the fx the sound is comming out, I can't "hear" it If anybody could help... Thanx in advance |
Hi mt,
2488 MK1 here; apartment recordist, and very happy with machine. A couple of useful places: http://www.soundadviceforums.com/ The folks at 'soundadvice' I know from when they came from the forum below, of which I am also a member. Good people, good advice. This is the original Tascam forum set up after Tascam itself shut theirs down: http://www.tascam2488.com/ Plenty of archived and new 2488 info. On-line collabs take place at both sites. Have at it; I'm sure you'll find both help and friends there. If you see 'Cosmic Closet' at either one, that's me ![]() See you around, C. |
Route the track effect send through the outboard processor, and back into an unused input channel. Be sure you have that input channel assigned to a track, and that you have the gain trim adjusted. You will be dry on the first track and wet on the second.
Related question - the 2488 will output individual tracks of mixdown tracks as wav files right? So you can collaborate with anyone who can import wavs?
Tom
OAncient1 Music Page |
Tom,
It will, and yes you can ![]() C. |
#12
how does the tascam 2488 for recording live? and what is needed, like laptop? mixer er wat?
#13
august,
The 2488 can record 8 tracks at a time for as long as there is hard-drive space. However, it is good practice not to max out the drive sector you record on completely, as that could back you into a corner when it comes to any post-show edits and such (they all require some room to be executed.) If you need more than 8 live tracks, you'll need someone with a mixer live-mixing the extra channels into the 8 tracks which you can then mix down after the fact. One important thing: Several users have had the 2488 lock up and freeze during live setups. The reason seems to be excessive vibration from, say, bass and drums. If this happens, you will lose your recordings. There is no 'cure' except shutting the machine down and re-starting. The machine should always be placed on a firm, even surface that allows air to circulate under the machine as well. And keep it from stronger external vibrations at all costs. After you are done, if the machine has run continuously during the set, you will now have one unbroken 'song' as far as the machine is concerned. You can now transfer this into a PC audio program (Audacity is free) and split the songs up in individual cuts, tweak as you please, and then burn a CD. Best, C. |
#14
thanks cosmic,
still, where do i put the mic inputs, is it a pa system with the 2488 attached or wat? or would u recommend a different device |
#15
Also correct about continuous running. I would rehearse stopping recording, saving, and setting up a new song with a saved scene so that you can break up the recording between songs. This will have a couple of benefits. If the 2488 does lock up, you will only lose what is being currently recorded. Also, it will make your life a little easier for post-performance mixing.
#16
Sorry this is soo late
Yes I use a 2488, love it!
Better late than never, I guess. I'm still trying to get use to the USB BAck up?!?
MrChubbs |
#17
i just won an auction for the original 2488. looks like i'll be joining the ranks of 2488 users
If ignorance was water the world would drown. |
#18
#19
i wanted the Mkii for it's extra memory, but this one was brand new and came at a decent price so i figure for the extra 300-400 it would have cost to get the Mkii, i'll just store any extra tracks on my computer and spend the money on a couple of more mics
#20
I think you'll really enjoy it. Memory hasn't been a problem for me, but I've been doing most of my work in 16-bit so far. (And to be honest I haven't been all that prolific.) Anyhow, backing up to free up disk space is easy.
#21
#22
Great news Nicole, congratulations
![]() ![]() I'm sure you're going to enjoy it a lot. As a former DP01 user, I still do what you said, back everything up in my PC. So eventhough I have the 80GB HD, it's never going to be full...not even close ![]() Also, with the 2488, you can burn all your individual tracks to a CD for ease of transfer. Say I record the drum tracks first, then add some bass and guitars (12 tracks); I burn these to a CD, then transfer to my PC for mixing, then bounce the 12 tracks to a stereo track, and then clean out the original 12 tracks. Then, keep on tracking ![]() Anyway, there's more than one way to skin a cat ![]() Again, congrats! Cheers!
My music http://www.soundclick.com/jorgesalo |
#23
i'm sure i'm going to enjoy it a lot. 24 tracks is going to seem like heaven compared to the 8 i have now, or the 4 tracks i started with on a yamaha md4 i seem to recall that the original 2488 needed a patch to fix some glitches? is this right? and if so where can i get this patch and how do i install it?
| Tascam 2488 and Finale | stucat | TASCAM User Forum | 0 | 03-31-2007 17:10 |
| Yamaha AW1600 vs. Tascam 2488 | osz | Other Equipment and Reviews | 18 | 02-13-2007 05:39 |
| TASCAM 2488 and MIDI | rdachowski | TASCAM User Forum | 3 | 08-21-2004 20:27 |
| VF160EX vs Tascam 2488 | mhetheridge | Fostex Forum | 11 | 06-23-2004 23:04 |
| tascam 2488 | coast ghost | Other Equipment and Reviews | 3 | 06-01-2004 12:35 |
