Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 07-06-2007
fris9 fris9 is offline
Senior Member
fris9 has a reputation beyond reputefris9 has a reputation beyond reputefris9 has a reputation beyond reputefris9 has a reputation beyond reputefris9 has a reputation beyond reputefris9 has a reputation beyond reputefris9 has a reputation beyond reputefris9 has a reputation beyond reputefris9 has a reputation beyond reputefris9 has a reputation beyond reputefris9 has a reputation beyond repute
Mic bleeding
I'm using a 2 overhead, kick, and snare mic setup to record, but I'm having trouble getting the snare to "pop" out of the mix. I've been told that I need to use compression on it and then give it a boost, but that brings up a new question. On my snare mic (sm57), i'm getting some bleed from the high hat, and a little from the toms. If I compress that mic, how will those bleed throughs affect the sound? One more question- do engineers delete noise between hits? Same with the kick drum. seems like a lot of work, but that it would clean up the bleeding, at least in between the hits on the kick or snare. Hope that makes sense.
Old 07-06-2007
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
With that type of mic setup, you are supposed to get the sound of the kit from the overheads and just use the kick and snare mics to add a little more uummmph! to the sound of the overheads.
If you want to micro-manage the drum mix, you need to close mic all the drums, a spaced pair of overheads and a whole bunch of noise gates. (and a decent drummer)
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 07-06-2007
Drakaland Drakaland is offline
Junior Member
Drakaland has a reputation beyond reputeDrakaland has a reputation beyond reputeDrakaland has a reputation beyond reputeDrakaland has a reputation beyond reputeDrakaland has a reputation beyond reputeDrakaland has a reputation beyond reputeDrakaland has a reputation beyond reputeDrakaland has a reputation beyond reputeDrakaland has a reputation beyond reputeDrakaland has a reputation beyond reputeDrakaland has a reputation beyond repute
A gate on the snare should take care of some of the cross talk between the hi hats and snare.
Old 07-06-2007
nddhc nddhc is offline
Senior Member
nddhc has a reputation beyond reputenddhc has a reputation beyond reputenddhc has a reputation beyond reputenddhc has a reputation beyond reputenddhc has a reputation beyond reputenddhc has a reputation beyond reputenddhc has a reputation beyond reputenddhc has a reputation beyond reputenddhc has a reputation beyond reputenddhc has a reputation beyond reputenddhc has a reputation beyond repute
If your drums are on carpet then a hard reflective surface under your whole kit or even just your snare (like a small sheet of wood or similar) might help.
Also, the tuning of your drum, the room you record in, and the way you play it will have more impact on your sound than you can even begin to imagine - but that should be a given
Good luck -
Im still learning as well
Old 07-06-2007
jamacian jamacian is offline
Banned
jamacian has a reputation beyond reputejamacian has a reputation beyond reputejamacian has a reputation beyond reputejamacian has a reputation beyond reputejamacian has a reputation beyond reputejamacian has a reputation beyond reputejamacian has a reputation beyond reputejamacian has a reputation beyond reputejamacian has a reputation beyond reputejamacian has a reputation beyond reputejamacian has a reputation beyond repute
Get your drum sound in your overheads right so the snare pops out. Then if that's not enough pop mic the snare bottom. I spend a lot of time on my overheads, XY, ORTF or spaced pair, each has it's own sound and needs lots of fine tuning to get things right.
Old 07-08-2007
Elton Bear Elton Bear is offline
Unregistered Abuser
Elton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond reputeElton Bear has a reputation beyond repute
I've had pleasing results with Overheads, Kick, and undersnare - little or no hi-hat bleed in your snare, and the overheads pick up more than enough 'pop' - the undersnare just gives a much richer sound to the whole thing.
Kicking it lo-fi:
POS computer
Cubase SX2
M-Audio Delta 1010LT
ART Studio V3 Tube MP
Behringer Eurorack Desk
AKG C3000B
Shure SM58
Shure SM57
Sennheiser e818 S II
Ashton DMP-100 drum mics
Old 07-08-2007
mrface2112 mrface2112 is offline
Thread Killer
mrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond repute
welcome to the wonderful world of recording drums. my advice: don't hit the hat so hard and hit the snare a whole lot harder. that's the best way to fix that bleeding problem.
might not be the easiest, though. but you'll be better for it in the long run.
and remember, only use a tourniquet on a mic to stop the bleeding in a "last resort" situation. a clean compress is best.
cheers,
wade
Old 07-09-2007
CJWalker CJWalker is offline
Dedicated Member
CJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond repute
Lately I've been doing a lot of playing around with the overall stereo image and getting the snare to cut through the mix with the rest of the set. I feel that most of the snare issues that I've been having are based upon the overhead mic' setup itself. The 'Recorderman' method and it's variants are a great starting point to get the snare centered and present. I have also become fond of using a second mic under the snare, phase flipped, to give a more 'dimensional' sound so to speak. Additional room mics also help depending on location. You can also try nudging/advancing the overheads a millisecond or so..
Old 07-09-2007
guttapercha's Avatar
guttapercha guttapercha is offline
Lovely Lad
guttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond repute
I've found that this approach doesn't work if the drummer hits ghosts on the snare.
Old 07-10-2007
eeb eeb is offline
Force of Nature
eeb has a reputation beyond reputeeeb has a reputation beyond reputeeeb has a reputation beyond reputeeeb has a reputation beyond reputeeeb has a reputation beyond reputeeeb has a reputation beyond reputeeeb has a reputation beyond reputeeeb has a reputation beyond reputeeeb has a reputation beyond reputeeeb has a reputation beyond reputeeeb has a reputation beyond repute
this is my preferred set up on the kit.. I love getting a more natural sound with the over heads.. Our ep (that i'm currently mixing) I used 2 overheads, 2 room mics.. kick and 2 on the snare (top and bottom) the drums basically mixed themselves except a few bleed issues (solved with a bit of automation)
with this set up you're really relying on your overheads to do most of the work... getting a great drum sound before you start tracking is key..
that being said i agree with Elton bear.. try to make everything stand out in the overheads... some careful eq'ing might be an order.. try not to overcompress either (this might just be my personal taste but too much compression will kill that natural sound you get by micing this way and to me that's sorta defeating the purpose)
Old 07-10-2007
Supercreep's Avatar
Supercreep Supercreep is online now
Immortalizes Your Member
Supercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond repute
Hit the snare harder. Light touch on the hats.
  #12
Old 07-10-2007
nuemes's Avatar
nuemes nuemes is offline
Be Here Now
nuemes has a reputation beyond reputenuemes has a reputation beyond reputenuemes has a reputation beyond reputenuemes has a reputation beyond reputenuemes has a reputation beyond reputenuemes has a reputation beyond reputenuemes has a reputation beyond reputenuemes has a reputation beyond reputenuemes has a reputation beyond reputenuemes has a reputation beyond reputenuemes has a reputation beyond repute
Attach foam just behind the head of the snare mic to keep the SM57 from picking up the hihat. Compression on the snare can add pop but be careful if using it while tracking or else you'll end up with something unnatural sounding.
  #13
Old 07-10-2007
HangDawg's Avatar
HangDawg HangDawg is offline
bUnGhOlIo
HangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond repute
See, I find just the opposite. Ghost notes are in the overheads and only the CRACKS come from the snare mic. That is, if you plan it this way and set the gates properly.
http://www.garagerecording.com/images/lava22.gif
SELECT W.People
FROM tbl_world W
WHERE W.Clue = TRUE
NO RECORDS RETURNED
  #14
Old 07-10-2007
Lovely Lad
Interesting. I was trying to gate out the hat, but I see what you mean here. If I set the gate more stringently, the snare mic won't pick up anything but the crack. I'm gonna try it.
Thanks!
JD
  #15
Old 07-11-2007
Supercreep's Avatar
a room mic with heavy compression will bring out those ghost notes. Mix it to taste.
Just maybe some useful info Mindset DJ & Hip Hop Production 4 12-18-2006 10:23
Drum mic bleeding UKPete Drums and Percussion 27 06-24-2006 22:49
Advice On Recording Vocals! rnb259 DJ & Hip Hop Production 8 04-28-2006 13:31
nanocomp better than art tube mic pre? trdn1 Other Equipment and Reviews 2 03-11-2006 12:22
Mic Comparison: SM57, EV757, 4033, 4050, C1, NTK, 460B Sonixx Microphones 97 05-30-2002 15:00
