Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 07-06-2007
Phildo Phildo is offline
I heart guitars!
Phildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond reputePhildo has a reputation beyond repute
Help - unpredictable glitching in SX3!
OK - long story short - studio computer commits hara-kiri, new computer in place, more powerful, more memory, less glurge on the o/s (bare-bones Win XP install), Cubase re-installed, files rescued, ready to go.
Sort of.
But it's being a bit odd. Doing some recording last night, and I'm finding that some projects are glitchy, while some play back fine.
Fair enough. It's probably the ones which are track/plugin heavy which are glitching.
Um, no.
The ones I'd expect to glitch (lots of tracks of audio, lots of plug ins - amp sims, EZDrummeretc) are running fine (although the CPU meter's showing a heavy load), while the ones which are little more than a couple of tracks with an instance or two of reverb are falling over.
Nuts.
Any ideas?
And yes, it's a full, legal, be-dongle'd install of SX3...
"I killed the President of Paraguay with a fork..."
www.myspace.com/germanfilmstars
www.myspace.com/weirdoiom
www.myspace.com/stoliday
Old 07-06-2007
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
Computer specs? Sound card? Driver?
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 07-07-2007
I heart guitars!
Intel P4 2.4GHzwith 640 Meg Ram, Tascam FW1082 with latest driver. Not the most mega-spec'd PC, I know, but the songs I'm having problems with playerd back fine on my 1.7 laptop woith 512 Meg.
Old 07-07-2007
Make sure your using the ASIO driver and increase you buffer setting
Old 07-07-2007
I heart guitars!
Buffer setting in Cubase or on the 1082 - it's already at max on the 1082 control panel?
(Ps - ta for the help...)
Old 07-07-2007
Should be one and the same (i.e. should not matter). What is the buffer set at? I would start at 512 and go up if it does not help. Also, try changing it before starting cubase and check it under the "device control panel" after it starts at make sure it still is at 512 or higher. Are you seeing performance spikes?
Old 07-07-2007
NL5's Avatar
NL5 NL5 is offline
Unpossible!
NL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond repute
Just a longshot here, but is the processor running at the correct speed?
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F.
Cubase SX3 projects working on Cubase 4? Dom414 Cubase User Forum 5 04-09-2007 22:52
Will projects from VST5 play in SX3? Booda Cubase User Forum 3 01-29-2007 00:27
SL3 or SX3? Mindset Cubase User Forum 4 01-14-2007 15:16
SX3 installation problems Superhuman Cubase User Forum 2 09-22-2006 11:35
Cubase SX3 vs. Cubase SX3 Pro Edition. MCreel Cubase User Forum 16 04-21-2006 06:07
