Old 07-05-2007
Nico2112's Avatar
Nico2112 Nico2112 is offline
Dedicated Member
Nico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond reputeNico2112 has a reputation beyond repute
Has this ever happened to you??
I was about to record some guitar tracks this morning; suddenly when I tried plugging the cable into my effects board, I noticed I couldn't. I checked the cable's plug, and the ring wasn't there I took a lamp and checked inside the effects board female 1/4 plug, and guess what? The ring is in there!
Has this ever happened to you?.....and
How did you solve this problem?
Cheers!
My music http://www.soundclick.com/jorgesalo
Old 07-05-2007
Minion Minion is offline
1K Silver Member
Minion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond reputeMinion has a reputation beyond repute
Yes, I have had that happen with a couple Racks that I own....I fixed one of them by useing some Conductive epoxy and glued the ring back into the Female connector.....You could also probably just replace the whole 1/4 in TRS jack without to much fuss as long as you are OK with a soldering Iron...
M-Audio Delta 44 + Delta 1010LT
5 Piece Drum Kit w6 Cymbals
Custom Made Bass Guitar
Custom Made Les Paul Guitar
Mackie Traction Studio 2.1
P-4 PC w 512mb DDR 80gb HD
Sell you used Equipment Here:
http://www.proaux.com/phpprobid/index.php
Old 07-05-2007
rhymes4life27 rhymes4life27 is offline
Newbie
rhymes4life27 is on a distinguished road
It has actually, tweezers work.
Old 07-05-2007
Nico2112's Avatar
Dedicated Member
Yup, tweezers were my first idea. The tip wouldn't come out
I had to take the pedal board apart and finally remove it. Painstaking process, but I succeeded
Just checked the effects, and everything is working in perfect order
Thanks for your comments.
Cheers!
Old 07-09-2007
cusebassman's Avatar
cusebassman cusebassman is offline
Freakin' sweet
cusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond repute
I know he fixed the problem, but those internal jacks are often housed in nothing within the outter case - if you pop the hood of the piece of gear, you can probably just grab whatever obstruction ended up getting stuck in there. Otherwise, tweezers usually work.
Or throw it out and buy a new one, as is the American way
Originally Posted by Ford Van
I AM RIGHT
It Happened Again ! ! ! mark4man Cakewalk / Sonar Forum 8 12-22-2003 20:23
