Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 07-03-2007
question444 question444 is offline
Senior Member
question444 has a reputation beyond reputequestion444 has a reputation beyond reputequestion444 has a reputation beyond reputequestion444 has a reputation beyond reputequestion444 has a reputation beyond reputequestion444 has a reputation beyond reputequestion444 has a reputation beyond reputequestion444 has a reputation beyond reputequestion444 has a reputation beyond reputequestion444 has a reputation beyond reputequestion444 has a reputation beyond repute
tuning 10" yamaha tom
This is driving me crazy. If I tune the top head where I want it, the bottom head raises in pitch. If I then tune the bottom head where I want it, the top head lowers in pitch. Advice please? (I am trying to tune these heads to a 'D').
Old 07-03-2007
Senior Member
got it
The top head had just come totally loose, and the heads had to build up tension again. This drum has a joint lugs, instead of independent lugs. That may have had something to do with it. It was a matter of flipping the drum over and over and retuning until they met each other.
Old 07-04-2007
toddyjoe toddyjoe is offline
Junior Member
toddyjoe has a reputation beyond reputetoddyjoe has a reputation beyond reputetoddyjoe has a reputation beyond reputetoddyjoe has a reputation beyond reputetoddyjoe has a reputation beyond reputetoddyjoe has a reputation beyond reputetoddyjoe has a reputation beyond reputetoddyjoe has a reputation beyond reputetoddyjoe has a reputation beyond reputetoddyjoe has a reputation beyond reputetoddyjoe has a reputation beyond repute
Joint lugs mounts can sometimes be tricky like that. However, you might want to double-check and make sure the joint lug mount is securely attached to the shell with no slop whatsoever. A loose joint mount can make the problem you describe much worse because the the lug bolts are pushing and pulling on a floating mounting point rather than a solidly-anchored one.
Rogers 10" Koa Cortex Rack Tom redtide34 Drums and Percussion 5 10-19-2003 01:32
Does anyone speak Yamaha? HapiCmpur MIDI Mania 2 09-09-2002 14:37
yamaha aw16g vs. boss 1180 multitrackers jeffree Other Equipment and Reviews 2 08-22-2002 16:28
