Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 07-02-2007
warlock110 warlock110 is offline
Dedicated Member
warlock110 has a reputation beyond reputewarlock110 has a reputation beyond reputewarlock110 has a reputation beyond reputewarlock110 has a reputation beyond reputewarlock110 has a reputation beyond reputewarlock110 has a reputation beyond reputewarlock110 has a reputation beyond reputewarlock110 has a reputation beyond reputewarlock110 has a reputation beyond reputewarlock110 has a reputation beyond reputewarlock110 has a reputation beyond repute
Ring mount VS shock mount?
what's the difference? i see some uses shock mount and some uses ring mount, and i have no clue what's the difference between them.
Old 07-02-2007
crazydoc's Avatar
crazydoc crazydoc is offline
Master Baiter
Location: Please forgive me. I don't mean to be a prick, but I guess I am.
crazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond repute
The shock mount decouples the mic from the environmental vibrations from the floor through the mic stand. The ring mount doesn't. If your stand is on a concrete floor, you probably don't need a shock mount, unless there are industrial goings-on or heavy traffic nearby.
I'm going through a difficult period - it's called life
Old 07-02-2007
Dedicated Member
i'm on a carpet floor, does that mean i'll need a shock mount?
Old 07-02-2007
Robert D Robert D is offline
Close to the Edge
Robert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond repute
Shockmounts are always a good idea. Whether it's necessary or not varies in degree from one mic to the next based on how well the diaphram is internally decoupled (mechanically) from the mic body, and as Crazydoc said, on the floor type. Other factors, like proximity to roads, traintracks, etc., may have an affect on this, as does anything in the building, like a washer or dryer, heating or air conditioning unit, etc. Then there's the singers and musicians who like to move, tap their feet, etc., which can end up traveling up the stand.
Some shockmounts are on the spendy side, but there are usually alternatives available that are quite reasonable, around $20. The cheap ones work just fine, and are a good investment in not losing the perfect take to mechanically coupled noise.
Regards,
RD
http://www.myspace.com/twentysevenmoons
Old 07-02-2007
rockinrocker rockinrocker is offline
Freedom Hater
rockinrocker has a reputation beyond reputerockinrocker has a reputation beyond reputerockinrocker has a reputation beyond reputerockinrocker has a reputation beyond reputerockinrocker has a reputation beyond reputerockinrocker has a reputation beyond reputerockinrocker has a reputation beyond reputerockinrocker has a reputation beyond reputerockinrocker has a reputation beyond reputerockinrocker has a reputation beyond reputerockinrocker has a reputation beyond repute
is there cement underneath the carpet? if so, probably not. if it's something else that will transmit vibrations, then yes.
Old 07-02-2007
Dedicated Member
are all shockmount the same ( as if one can be use for multiple mic). i have one for my MXL 990, but i'm not sure if it'll fit the other mic that i'll be buying, it'll suck if it slip n fall haha.
Old 07-02-2007
MemoGtr's Avatar
MemoGtr MemoGtr is offline
Así o más verger?
MemoGtr is a jewel in the roughMemoGtr is a jewel in the roughMemoGtr is a jewel in the rough
hello everyone
and sorry to hijack this thread but its just a quick question and i didnt find it answered when i searched it
i see that some put their mics in the shockmounts in an upside down position
is there actually a difference?
it justs scares the hell out of me
Memo!!
Old 07-02-2007
crazydoc's Avatar
Master Baiter
No - you need different mounts for different mic sizes (diameter of the body, mainly.) The 990 has a fat one, so there aren't many mics the mount will fit. Many large diaphragm condensers have smaller bodies, and would fit too loosely or fall out of that mount. Small diaphragm condensers are even smaller (many less than an inch in diameter) and need even smaller mounts.
If the mic diameter is within 1/4" or so of the mic that goes with a particular shock mount, it's a pretty safe bet it will fit the mount. However, different styles of mounts may have looser or tighter tolerances.
Old 07-02-2007
crazydoc's Avatar
Master Baiter
Originally Posted by MemoGtr View Post
hello everyone
Not really - just make sure it isn't a loose fit, and make sure the cable is wrapped around part of the stand that will break the fall.
Some people feel the upside down mic is easier for the vocalist to approach, and in a tube mic it doesn't heat the capsule, but it's just a matter of which way you think looks coolest.
Old 07-02-2007
Dedicated Member
upside down look the coolest lol.
i went to the website
the XML 990 is 60mm wide
the mic i'm gonna buy is 50mm
let's hope 10mm isn't gonna be a huge difference.
Old 07-03-2007
crazydoc's Avatar
Master Baiter
It is. The other mic will be too small - that's almost a 1/2" difference. You can measure the inside diameter of your 990 shockmount without a mic in it, and I think you'll find it's more than 2". Even if it's just 2", that won't give it enough tension to hold the mic.
  #12
Old 07-03-2007
cusebassman's Avatar
cusebassman cusebassman is offline
Freakin' sweet
cusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond repute
What is the other mic you will be buying, out of curiosity?
As far as shockmounts go, they do help, depending on the situation. I live in an apartment on the second story of an old wooden house - the refridgerators running on every floor cause the entire house to have a very faint low-frequency rumble, that you would only notice buy plugging in a mic, slapping on headphones and crankin the gain considerably. Because I record acoustic guitar, you can hear this rumble unless I used a shockmount.
With the shockmount it is still there a bit, but it isn't as pronounced. As for upside-down / right-side-up facing, I usually hang my Large diaphragm condenser upside down simply because it is valve-based, and as someone mentioned, I don't feel comfortable using it for long periods of time in the upright position due to capsule heating. Not sure if that's really something to worry about, but I'm not taking my chances
Originally Posted by Ford Van
I AM RIGHT
  #13
Old 07-03-2007
Dedicated Member
i think i might be getting the ADK 51-A V. taking my shot, not really well known but someone did a test and i think i like the sound. I was considering the SP B1, but everyone has that one, let's test something else.
Looking for a shock mount that doesn't suck.... dgatwood Microphones 4 03-18-2007 10:50
Soundelux shock mount problem tombuur Microphones 5 03-31-2006 10:47
SP C1 Shock mount question proxymoron Microphones 59 05-07-2004 12:39
New in box Samson CO1 with shock mount... billisa Free Ads for Music / Recording Equipment 2 06-10-2003 18:28
Do I need a shock mount? clifchamb Microphones 9 01-20-2003 14:58
