Old 07-02-2007
ceedubindustrie ceedubindustrie is offline
Newbie
ceedubindustrie has much to be proud ofceedubindustrie has much to be proud ofceedubindustrie has much to be proud ofceedubindustrie has much to be proud ofceedubindustrie has much to be proud ofceedubindustrie has much to be proud ofceedubindustrie has much to be proud ofceedubindustrie has much to be proud ofceedubindustrie has much to be proud of
Analog Mixer Overdrive
Dear all-
Over the weekend I found that overdriving the input to a channel on my Tascam m-30 mixer made for lovely distortion on my x0xb0x. The input LED was lit up like a tannenbaum.
The Tascam manual said that hot levels aren't good for the mixer, but I'm not sure if this is what they mean! I'd like to know if it is Patently Bad. In other words, do you have experience with mixer components failing due to high input?
I ask because my Behringer can withstand it, but sounds like crap. I'd like to continue to use the Tascam for this effect if I'm reasonably sure it is OK.
-C
Old 07-02-2007
Somnium7's Avatar
Somnium7 Somnium7 is offline
Noise Criminal
Somnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond repute
I used to do this all the time with my Tascam mm-20 and never had any negative consequences. I do it now with my current mixer and no problems here either.
I can't see how this could cause any component failures in the circuitry.
If you could see crime in a mans face we wouldn't have any mirrors - H. Bogart
Somnium7
Somnium7 on MySpace
Old 07-02-2007
_DK's Avatar
_DK _DK is offline
Dedicated Member
_DK has a reputation beyond repute_DK has a reputation beyond repute_DK has a reputation beyond repute_DK has a reputation beyond repute_DK has a reputation beyond repute_DK has a reputation beyond repute_DK has a reputation beyond repute_DK has a reputation beyond repute_DK has a reputation beyond repute_DK has a reputation beyond repute_DK has a reputation beyond repute
I'd guess the electronics won't last as long as they would with a normal use... you'd have to recap soon etc etc
Tascam 38
Tascam 208
Electro-Harmonix 12AY7
Teisco Beltone amp
Old 07-02-2007
cjacek's Avatar
cjacek cjacek is offline
Analogue Enthusiast
cjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond repute
In addition to possibly getting bent VU meter needles, from pinning them, I can't see such overdriving to be good [at least in the long term as DK already mentioned].
Old 07-02-2007
jjones1700's Avatar
jjones1700 jjones1700 is online now
Learning, always learning
jjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond reputejjones1700 has a reputation beyond repute
I'm not sure how audio amps (or pre-amps in this case) work, but in radio receivers / transmitters it is possible to blow out transistors from overloading the front end or suffering too much resistance on the back side and burning something out. I would imagine that the circuits in the mixer are designed to handle a specific voltage range. Whether or not you are exceeding what the manufacturer's tested limit is anyone's guess.
Instead of blowing out a mixer and turning it into a door stop, how about getting an effects unit?
<insert witty and more appropriate comment here>
Old 07-02-2007
bloomboy bloomboy is offline
Senior Member
bloomboy has a reputation beyond reputebloomboy has a reputation beyond reputebloomboy has a reputation beyond reputebloomboy has a reputation beyond reputebloomboy has a reputation beyond reputebloomboy has a reputation beyond reputebloomboy has a reputation beyond reputebloomboy has a reputation beyond reputebloomboy has a reputation beyond reputebloomboy has a reputation beyond reputebloomboy has a reputation beyond repute
Yeah, I used to do this on my old mixer with accoustic guitar until I noticed that the channels I most often used to record guitar had become noticeably duller
To use an extreme example, I use old cassette decks with 1/4" inputs and outputs for distortion (not tape distortion, just overdriving the electronics) and I have to get a new one about once every 2 months becuase the high end starts to totally disappear.
Now I use the old mixer when I want that overdrive effect and make sure that every signal is brought back within reasonable parameters before it hits my mixer or tape recorder.
Connecting analog mixer to pro tools breakthru Analog Only 3 08-03-2006 01:36
Soundcraft Spirit Analog Mixer in digital rec. environment hand in glove Digital Recording & Computers 1 06-25-2006 14:05
Applying an analog mixer for my computer base music creation kenoir Digital Recording & Computers 21 05-04-2006 13:52
interface inconjunction with analog mixer radismatt Digital Recording & Computers 1 01-25-2005 15:01
24 Trac DAW and Analog Mixer Combo - Help with Setup Deface7String Digital Recording & Computers 2 04-11-2003 21:42
