Old 06-29-2007
northern cali northern cali is offline
Senior Member
northern cali has a reputation beyond reputenorthern cali has a reputation beyond reputenorthern cali has a reputation beyond reputenorthern cali has a reputation beyond reputenorthern cali has a reputation beyond reputenorthern cali has a reputation beyond reputenorthern cali has a reputation beyond reputenorthern cali has a reputation beyond reputenorthern cali has a reputation beyond reputenorthern cali has a reputation beyond reputenorthern cali has a reputation beyond repute
need help/info on which studio monitors i should use
i need to get a pair of studio monitors but i have no idea on what i should get, i know theres different kinds such as active and powered and such but thats as much as i know
my setup is
pro tools m-powered
berhinger ub1202fx http://www.zzounds.com/item--BEHUB1202FX
audiophile 2496
akg c2000b mic
my budget is around $150 to $200, buying used isnt an issue...
thanks...
Old 07-07-2007
anteroom123 anteroom123 is offline
geek
anteroom123 has a reputation beyond reputeanteroom123 has a reputation beyond reputeanteroom123 has a reputation beyond reputeanteroom123 has a reputation beyond reputeanteroom123 has a reputation beyond reputeanteroom123 has a reputation beyond reputeanteroom123 has a reputation beyond reputeanteroom123 has a reputation beyond reputeanteroom123 has a reputation beyond reputeanteroom123 has a reputation beyond reputeanteroom123 has a reputation beyond repute
well for starters... active means they have amps in them and therefor are powered.
i would recomend some of the behringer 2030a's or 2031a's , you could probibly pick a pair up for about 200, they have a pretty flat response and include an eq on the back for room compensation.
i would stay away from cheaper m-audio or fostex moniters,.. or any other cheeper moniters for that matter, anything below 150 dollars is probibly just a glorified pc speaker, and probibly a waist of your money.
its really not worth your time or money to buy a moniter that doesn't give a true response, remember, there is a diffrence between hi-fi speakers, witch are built to make your music SOUND good, and moniters witch are supposted to be built to let you hear what your music REALLY sounds like.
the flatter the response the better. if your monitering with speakers that hype the bass, then your probibly going to cut back on the bass alot when mixing and then when anyone else listens to your song, their going to be like.. ''wheres the bass?"
your better off saving your money and getting something good, or atleast decent.
the behringers (2030a's and the 2031a's) were reviewed by sound on sound, and a few others and were rated pretty highly. i have used them and put them along side my mackies and they quality blew me away. i havn't seen a better speaker for under 300
but thats just my $.02
good luck
-Matt
Old 07-08-2007
Senior Member
thanks alot homie...
Old 07-08-2007
groovyisland's Avatar
groovyisland groovyisland is offline
avast ye swabs!
groovyisland has a reputation beyond reputegroovyisland has a reputation beyond reputegroovyisland has a reputation beyond reputegroovyisland has a reputation beyond reputegroovyisland has a reputation beyond reputegroovyisland has a reputation beyond reputegroovyisland has a reputation beyond reputegroovyisland has a reputation beyond reputegroovyisland has a reputation beyond reputegroovyisland has a reputation beyond reputegroovyisland has a reputation beyond repute
my m-audio system came with a graph from when my speakers were tested before they left the factory
its flat enough for me and i would bet good money that they run flatter than ns-10's the classic nearfield monitor
they started life as home stereo speakers anyway so whats the diff
home theater installers like to install studio monitors for home systems now
if you have good ears you can mix on just about anything by using reference cds
professionally produced cd music that has the kind of sound you want to go for
play the cd then play your song make your song sound like the cd
on the other hand if you can afford it go for something nice
events are nice as are mackies and adams
if i had a lot of money i would probably go for tannoys
as long as you reference you cant go too far wrong
G.F.C.G Membership No#: 000 041
my sister makes fractal art www.fractalus.com/cheshirecat
Old 07-09-2007
avast ye swabs!
and yeah a lot of people like the behringer truths
the powered ones with the 8.25 woofers
Old 07-10-2007
geek
yah i agree, if you cant afford someting decent than you can make a comprimise, but you dont want to make to many of those. your moniters are one of the most valuable tools in your studio (as i understand), so try and get good ones, but dont make to many compromises on them. if you have to get some cheaper moniters, i hear it helps to add a graphic eq into the moniter chain. thats going to cost a little extra (200-300) and as i said before the behringer truthes accually come with some sort of eq built in. im sure theres numourous others that also come with something like that but im not really shopping around for moniters at the moment so i wouldn't have a clue.
good luck
Old 07-10-2007
cusebassman's Avatar
cusebassman cusebassman is offline
Freakin' sweet
cusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond reputecusebassman has a reputation beyond repute
You'll be using enough bottom-of-the-consumer-recording end equipment that you want to use monitors of some kind (not PC speakers - compensating is difficult and not an exact science).
The KRK RP-5s are nice - a pair will run about 300, but they are well worth it, in my opinion. I've heard some decent things about the Behri's recommended as well. Do a title-only search on "monitors" - you'll get about 3,000 threads just like yours from this forum, regarding the want to buy monitors for X number of dollars, and the pros and cons therein.
Originally Posted by Ford Van
I AM RIGHT
Old 07-10-2007
avast ye swabs!
the problem with 5 inch woofers is youll never be sure about the bass
on the other hand my m-audio system is 3 way with satellites and a sub
you have to be sure the sub is balanced correctly
i only paid 200 shipped for a system that i first saw for 350
i think its discontinued now
when i first saw it i thought hmmm that looks like the ultimate cheapie space-saver system
you get an 8 inch powered subwoofer with 2 lx4 passive satellites. i actually like the sound of the 4 inch driver better than say a 6.5 inch. to me it sounds less boxy. the resonant frequncy is gonna be a lot higher.
i have the 8 inch woofer depth with a very focused sound field.
i cant believe they discontinued the system. i must have gotten a closeout price.
Old 07-10-2007
avast ye swabs!
frequency analysis is what the pros use
you get a little omni mic like a earthworks. behringer makes a copy. reference mic.
then you play white noise through you system or maybe pink noise
the analyzer tell you what your problem frequencies are and you can eq them out
jbl makes some lovely nearfields that do this automatically and they have the analyzer built in. they come with everything you need and are not that expensive.
if i had the money i would be tempted to go that route also
Old 07-10-2007
andyhix's Avatar
andyhix andyhix is offline
www.miterecords.com
andyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond repute
I like my behri truths a lot. I listened to some of the better brands with 5" speakers, and I found the bass too light. My only advice is if you buy behri's, buy them new from a legit retailer, in case they crap out, you can get them replaced. One of my tweeters blew about a week after I started using them. Fortunately, Zzounds was awesome and replaced them and paid shipping both ways. You won't get that kinda service from ebay, obviously, and Behri's are known to crap out fairly often. If you get a good pair, though, I think they're decent - actually really good - for the price.
Old 07-10-2007
avast ye swabs!
ha ha i was gonna say i read about the beri's blowing up and catching fire
apparently there have been problems and concerns for life and limb
i didnt want to put the downer in there but since you mentioned it...
  #12
Old 07-10-2007
avast ye swabs!
heres a pic from the m-audio site
the sub is a monster
it has 5 amps and you can get an expander pack so you can have 5 of the lx4 passive satellites for surround mixing
  #13
Old 07-10-2007
avast ye swabs!
oops i mean 6 amps of course, one for the sub
  #14
Old 07-10-2007
jeap's Avatar
jeap jeap is offline
why cant we get a lawn?
jeap has a reputation beyond reputejeap has a reputation beyond reputejeap has a reputation beyond reputejeap has a reputation beyond reputejeap has a reputation beyond reputejeap has a reputation beyond reputejeap has a reputation beyond reputejeap has a reputation beyond reputejeap has a reputation beyond reputejeap has a reputation beyond reputejeap has a reputation beyond repute
full fidelity 2.1 monitoring with subwoofer and two satellites
LX4 Surround Expansion Satellites adds 3 satellites for complete 5.1 surround system
60 watts for sub, 27 watts per channel for satellites
8" subwoofer with 6 power amps for 5.1 Surround support
satellites feature 4” polypropylene drivers and 1” mylar drivers
small enough to fit anywhere (no AC routing)
satellite power supplied by subwoofer
ported enclosures for optimal fidelity
six 1/4” TRS balanced inputs
dynamic range (satellites and sub): 100dB (A-weighted)
frequency response (satellites and sub): 40Hz–20kHz; +1dB, -3dB
mid-range/ tweeter crossover frequency: 2.9kHz
RMS SPL @ 1 meter: 102.5dB (satellites); 105dB (sub)
signal-to-noise ratio: 82dB @ 1 watt (typical, A-weighted)
crossover frequency: 140Hz
low frequency -3 dB cutoff: 40Hz with 6th order alignment
satellite size/weight: 8.5” (h) x 5.75” (w) x 6.25” (d); 4.4 lbs. each
subwoofer size/weight: 15.6” (h) x 10.63” (w) x 12” (d); 30.86 lbs.
¤ ultra-cool brigade ¤
  #15
Old 07-10-2007
philippejarvis@ philippejarvis@ is offline
Newbie
philippejarvis@ is on a distinguished road
Speakers
hI
Try second hand yamaha mspc5
cheap nowadays and a nice fat sound
  #16
Old 07-28-2007
Obstacle1's Avatar
Obstacle1 Obstacle1 is offline
Incompetent at times...
Obstacle1 has a reputation beyond reputeObstacle1 has a reputation beyond reputeObstacle1 has a reputation beyond reputeObstacle1 has a reputation beyond reputeObstacle1 has a reputation beyond reputeObstacle1 has a reputation beyond reputeObstacle1 has a reputation beyond reputeObstacle1 has a reputation beyond reputeObstacle1 has a reputation beyond reputeObstacle1 has a reputation beyond reputeObstacle1 has a reputation beyond repute
I'm also looking for my first set of monitors and so went to my local Pro Audio shop and they technician there told me that the Fostex PM04's are the best around for their price. He said (apparently) that they supply or design the parts for all the other lower end monitors or something like that. Have also heard good stuff about the Behringer's but again I can't comment personally.
Fender Telecaster
Tanglewood Heritage TW1000B
Peavey Bandit 110
Boss ME-50, Small Clone, Boss DD-3
SM57, AT3035, AKGC2000b
Peavey PV8
Behringer Composer MDX2100, Behringer Virtualizer
M-Audio Audiophile 2496
Cubase SX2
Reason 3.0
Edirol MA-7A's
What are the absolute BEST studio monitors money can buy? triple cubic Other Equipment and Reviews 21 06-03-2009 20:57
Plugging in studio monitors bigdaddyd The Rack 2 12-20-2004 09:08
JBL 4206 Studio Monitors for sale! taperocket Free Ads for Music / Recording Equipment 1 12-03-2004 19:00
How are "consumer audio speakers" tweaked as opposed to studio monitors? UberGawkman Mixing / Mastering 21 03-21-2002 16:41
studio monitors Kante Keyboards and Sound Modules 10 01-02-2002 20:37
