Old 06-27-2007
LeBron LeBron is offline
Newbie
LeBron is on a distinguished road
Exclamation Noob-ish microphone issues
Hey all,
I recently bought a microphone (VIVANCO DM10). I know that it's not a professional microphone, but some people just can't afford better equipment. Ones like me
So, me and my friend wanted to record some of our raps on my computer. We use Acoustica Mixcraft 3, if that matters. But when we finish rapping along the song (we use headphones when recording), we hear a strange sound. Something like... I don't even know, how to visualize it . We're sure, that this sound is there because we raised the volume of the microphone, so we could hear our selfes in the song better, without need to lower the musics' sound. Maybe it's called "distortion" or something, but it only happens, when microphone is set to loud levels. Or even on medium.
We had the same problem with much more lame microphone (the one with headphones), so I couldn't believe, that this is happening. I mean, come on now, this microfone is much better that the old one...
I hope you understood, what I've been trying to say. I also hope, that you'll be able to help me.
Thank you.
Cleveland Cavaliers
Old 06-27-2007
bodaddy bodaddy is offline
Newbie
bodaddy has a reputation beyond reputebodaddy has a reputation beyond reputebodaddy has a reputation beyond reputebodaddy has a reputation beyond reputebodaddy has a reputation beyond reputebodaddy has a reputation beyond reputebodaddy has a reputation beyond reputebodaddy has a reputation beyond reputebodaddy has a reputation beyond reputebodaddy has a reputation beyond reputebodaddy has a reputation beyond repute
I am new to this forum but I think it would help if there was a way for us to hear the noise you refer to. Is there anywhere you can post it so we can hear? If it's distortion and it is happening on both mics then I would think you are clipping somewhere. Do you have a meter to see if it gets in the red. Also is the noise constant or only on volume peaks? Thanks.
Old 06-27-2007
Somnium7's Avatar
Somnium7 Somnium7 is offline
Noise Criminal
Somnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond repute
what are you using to record the audio with?
If you could see crime in a mans face we wouldn't have any mirrors - H. Bogart
Somnium7
Somnium7 on MySpace
Old 06-27-2007
Newbie
This is the sound I was talking about. For recording I use "Acoustica Mixcraft 3". I record everything with my computer, cuz' I can't afford the stuff, which would be made especially for high quality recording...
http://files-upload.com/328877/Hissing.mp3.html
Cleveland Cavaliers
Old 06-27-2007
Newbie
Ok I listened and have had that before. Are you recording directly to your comp? Your picking up interferance maybe. A ground problem maybe. Messed up cord. Could be a few things. It's not a buzz so it may just be inadequate interface(what ever your plugged into.) One option if you can't get rid of it is to use a noise reduction plug-in. highlight a sample of the noise and then create a template for that noise and it will remove that only or greatly reduce it. Maybe even try recording at a much lower level and then bring the gain up with a plugin.
Old 06-27-2007
groovyisland's Avatar
groovyisland groovyisland is offline
avast ye swabs!
groovyisland has a reputation beyond reputegroovyisland has a reputation beyond reputegroovyisland has a reputation beyond reputegroovyisland has a reputation beyond reputegroovyisland has a reputation beyond reputegroovyisland has a reputation beyond reputegroovyisland has a reputation beyond reputegroovyisland has a reputation beyond reputegroovyisland has a reputation beyond reputegroovyisland has a reputation beyond reputegroovyisland has a reputation beyond repute
hey that doesnt sound too awfully bad. if you have the mic plugged into your sound card that could be about the best signal to noise ratio you can hope for.
stock soundcards arent really made for recording.
its probably electrical noise from the input gain stage. if you gate it youll still have it while youre rapping.
G.F.C.G Membership No#: 000 041
my sister makes fractal art www.fractalus.com/cheshirecat
Old 06-27-2007
whjr15's Avatar
whjr15 whjr15 is offline
Dedicated Member
whjr15 has a reputation beyond reputewhjr15 has a reputation beyond reputewhjr15 has a reputation beyond reputewhjr15 has a reputation beyond reputewhjr15 has a reputation beyond reputewhjr15 has a reputation beyond reputewhjr15 has a reputation beyond reputewhjr15 has a reputation beyond reputewhjr15 has a reputation beyond reputewhjr15 has a reputation beyond reputewhjr15 has a reputation beyond repute
Since your mic is dynamic, you have to push the gain a bit more than you would on a condensor. That coupled with a less-than-stellar preamp will cause that noise.
Also, use the "line in" input instead of the "mic" input on your computer... If you haven't been doing so already.
Originally Posted by crazydoc
Most of us here
just don't give a F$#%
about making $ in this.
We just want to record some s#%$ that doesn't suck too bad, and have fun doing it.
Old 06-27-2007
danny.guitar
Guest
Posts: n/a
If there is no preamp in the signal chain before the sound card then he will probably have to use the mic input since that will use the sound card's (noisy) preamps. Otherwise, the signal would be too low going straight to line in. And would probably be unbearable when amplified.
The line-in jack expects a line-level signal. The raw signal from a microphone is not anywhere close to that as far as I know.
Old 06-28-2007
Newbie
Gotta' thank you all guys for your replies I've firstly tried to use bodaddy's method, recording at low gain. I've recorded, then I've simply multiplied the recorded track a few times, to gain more sound And the problem was gone THANK YA'LL!!!
Cleveland Cavaliers
Old 06-28-2007
Newbie
LOL mine was probably the most technically wrong way. These guys are much smarter than I am but I'm glad it worked out.
Which Measurement Microphone ? M300SEL Microphones 5 04-13-2007 12:47
Philips Conference Unit(CCS 400) as a microphone! How..? canakas Other Equipment and Reviews 3 11-13-2006 11:39
Studio projects LSD2 stereo microphone sale Jflojazz Free Ads for Music / Recording Equipment 0 02-10-2005 00:17
microphone static killthesoundboy Cool Edit Pro / Adobe Audition Forum 3 11-25-2004 05:18
