"PINK NOISE FULL bw -20 dBFS"
So i have a sample of "PINK NOISE FULL bw -20 dBFS"
I load it up in Cubase SX3 with all faders set to "0". Now the meters are saying that its -14.4dBFS....?? Then i load the same sample up in Wavelab6 and it says -11.29 dBFS with a -19.26dB RMSFs Shouldn't cubase be -20dB RMSFs to? Do i have to calibrate my meters or is this normal? |
what format is the noise in???
The format is .wav
Cheers, Otto |
Roger Nichols has a free version of the Inspector plug in that you can use as a meter plug in in Cubase. Be warned that it's RMS reference level is a full scale square wave, so everything will read 3 dB lower than standard practice when using it for RMS measurements (i.e. the noise file will show -23 dBFS RMS, once you figure out that the meter scale marking for -24dBFS is actually labeled "-21 dB".
Cheers, Otto |
| DITHERING...A few questions... | RAMI | Mixing / Mastering | 32 | 11-07-2005 11:30 |
| Silencing the PC: Reviews! | Halion | Digital Recording & Computers | 0 | 07-26-2005 08:45 |
| Please Help!!! | Girlnezz | Cool Edit Pro / Adobe Audition Forum | 28 | 06-25-2003 14:18 |
| What is the noise floor on your Delta? | canada-paul | Digital Recording & Computers | 30 | 05-27-2003 06:59 |
| watery sound after noise reduction in Cool Edit 2000 | radiogold | Cool Edit Pro / Adobe Audition Forum | 2 | 04-16-2002 02:52 |
