Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 06-23-2007
AaronTheBassist AaronTheBassist is offline
Newbie
AaronTheBassist is on a distinguished road
CPU/Buffer Problem - SX 3 with i88x
This probably has a simple answer, but I'm really new to the DAW world.
The Setup:
Athlon XP 2700+ (2.16 ghz)
768 mb RAM
Yamaha i88x firewire interface
The Problem:
There is a huge jump on the CPU processing meter when I change from my soundblaster card to the interface. This seems to only be happening recently. The CPU is fine when I'm in a very small session (i.e. compressing and eqing a 2-track), but in a modest 10-12 track session with 1-3 plugins per track, the CPU is maxed out, even when the playback is stopped. My computer becomes more or less frozen. My latency seems to be a bit lower than usual (~5ms input, ~3 ms output).
I haven't tracked recently, so I don't know if the CPU is less stressed with input, rather than output. I could temporarily fix the problem by freezing half of the tracks, but I'd rather not. I know I need to get a better computer, but I think there is something else at play.
Old 06-24-2007
JoeNovice's Avatar
JoeNovice JoeNovice is offline
Junior Cheeseburger
JoeNovice has much to be proud ofJoeNovice has much to be proud ofJoeNovice has much to be proud ofJoeNovice has much to be proud ofJoeNovice has much to be proud ofJoeNovice has much to be proud ofJoeNovice has much to be proud ofJoeNovice has much to be proud ofJoeNovice has much to be proud of
Since you've got a limited amount of processing and a less than powerfull processor you should consider your usage of plugins to be a problem. Do you really need 30 plugins running for 10 tracks? NO....
Use Group channels to process multiple tracks with the same plugin; like reverb. Reverb works very well as a group plugin. Compression can also be grouped together in some instances.
7 times down, 8 times up......
Old 06-24-2007
Newbie
I already use group channels for reverb, and sometimes compression on drum submixes. My biggest session uses 22 plugins - I'd say about 55% eq, 40% compression, and 5% reverb. It didn't seem like a processing problem a while ago when my latency was a bit higher. And it isn't a problem when running through a soundblaster card. I run sessions at 44.1/24.
Old 06-24-2007
JoeNovice's Avatar
Junior Cheeseburger
You do change you hardware buffer settings when mixing correct?
If you don't, you should. Mixing should always be done with a higher buffer setting to help reduce CPU crunch. There's really not much need to have low latency when mixing.
Track with low-latency buffer settings, mix with high buffer settings.
Why do you use a SoundBlaster card anyway? Those things are notorious for causing problems.
Old 06-25-2007
Newbie
Thanks for the tip, that seemed to solve most of the problem. Things are still a bit glitchy when I use the word clock on the i88x as the master clock. I have no clue why.
I use the soundblaster just to check mixes on my comp's speakers.
rack with legs so i can tilt back walters The Rack 43 08-17-2007 20:35
M-Audio Firewire Audiophile, Firefox + Media Player problem?!! carlosguardia Digital Recording & Computers 0 03-05-2007 14:35
robot sounding spdif problem thedude400 The Rack 16 12-22-2006 10:26
Sonar 4-5 "Random" problem (tough one) Thrawn Cakewalk / Sonar Forum 2 08-20-2006 14:18
Unwanted distortion in amp; possible preamp tube problem? Whoopysnorp Guitars and Basses 11 09-16-2003 13:06
