Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 06-23-2007
dupedd dupedd is offline
Newbie
dupedd has a reputation beyond reputedupedd has a reputation beyond reputedupedd has a reputation beyond reputedupedd has a reputation beyond reputedupedd has a reputation beyond reputedupedd has a reputation beyond reputedupedd has a reputation beyond reputedupedd has a reputation beyond reputedupedd has a reputation beyond reputedupedd has a reputation beyond reputedupedd has a reputation beyond repute
Should I add compression on heavier hitting songs?
I've been looking through the search engine and still can't find specifically if I should, or if it's common to apply compression to drums on the way in(when recording). Right now I have good levels, between -18 and -12 on average, some peaking at around -9 but I'm wondering if I should maybe apply at least a limiter or some compresion on the snare and kick and maybe get more prescence out of them wiith the increased gain that I'll be able to afford.
I apologize for the newbie question, but I've been spending hours tonight pouring over the forums looking for some answers I need by tomorrow's recording session. A couple of the songs really have some heavier hitting on the snare and kick but have really light sections as well so turning down to keep the heavy sections levels in the right place has the quiter sections maybe too soft sounding. Is this a time to apply compression when recording?
Old 06-23-2007
scorpio01169's Avatar
scorpio01169 scorpio01169 is offline
Senior Member
scorpio01169 has a reputation beyond reputescorpio01169 has a reputation beyond reputescorpio01169 has a reputation beyond reputescorpio01169 has a reputation beyond reputescorpio01169 has a reputation beyond reputescorpio01169 has a reputation beyond reputescorpio01169 has a reputation beyond reputescorpio01169 has a reputation beyond reputescorpio01169 has a reputation beyond reputescorpio01169 has a reputation beyond reputescorpio01169 has a reputation beyond repute
me personally i would try and get those levels into the -5 to -3 range.....and yes compression will tighten the hits up a bit with a setting between 3.1 or 4.1 depending on your compressor
Mackie 32.8+24.E plus automation
[2] Mackie MDR 24/96 mtr
e-machines pc/Nuendo for tracking and editing
m-audio firewire 410, samson c01, audix d6, samson tom mics Alesis qs7 keyboard controller, Korg Triton Rack, A R T,preamps
Old 06-23-2007
RAMI's Avatar
RAMI RAMI is offline
www.ramirami.com
RAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond repute
Instead of being stuck with the compression you recorded, and maybe not like it, why don't you record with no compression and then add it later. Your levels seem to be fine, so you don't need to compress for that reason. And if you want to compress simply for the "sound", you can compress as hard and as often as you like once it's on "tape".
Old 06-23-2007
Newbie
my thought was maybe it might be a good idea for songs that have very dynamic volume and intensity changes on the drums. This one song we're recording has very soft and very heavy hard rock drumming but we have the levels set for the hardest hitting parts, leaving the softer parts MUCH lower in volume. I thought if I at least added a limiter for the hardest hitting I could raise the gain for the all around, therefore giving more prescence to the softer parts. Does this make sense?
Old 06-23-2007
BurnBarfield's Avatar
BurnBarfield BurnBarfield is offline
I'm a big gay loser.
BurnBarfield has a reputation beyond reputeBurnBarfield has a reputation beyond reputeBurnBarfield has a reputation beyond reputeBurnBarfield has a reputation beyond reputeBurnBarfield has a reputation beyond reputeBurnBarfield has a reputation beyond reputeBurnBarfield has a reputation beyond reputeBurnBarfield has a reputation beyond reputeBurnBarfield has a reputation beyond reputeBurnBarfield has a reputation beyond reputeBurnBarfield has a reputation beyond repute
What I would typically do in your situation is to automate your effects, that way you can have different levels set for the different sections.
Poop
Old 06-23-2007
ez_willis's Avatar
ez_willis ez_willis is offline
Virtual Ninja
ez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond repute
Damn, dude, don't beat yourself up. That's a totally valid question asked in a clear and precise manner. And you did your homework first by using the search function.
Now go pick on a few people in the newbie forum for shits and giggles.
Originally Posted by 60's guy View Post
You win.
Old 06-25-2007
Newbie
We got some pretty good takes yesterday. Rock on!
Old 07-09-2007
CJWalker CJWalker is offline
Dedicated Member
CJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond reputeCJWalker has a reputation beyond repute
Well I still consider myself a 'newb,' though I've been having luck setting the overall levels on the kit and running the drum bus send through a compressor, adding to taste for more punch. I try avoid a lot of compression for individual drums though I seem to like it on toms.
BBS Member Tutorials/Guides chadsxe Mixing / Mastering 29 10-19-2005 11:37
Tom Lord-Alge giraffe Mixing / Mastering 16 05-15-2005 15:48
Compression....what a bummer Bob's Mods The Rack 36 03-12-2005 10:40
Having trouble getting the mix just right! Kewlpack Mixing / Mastering 51 12-23-2004 22:00
when to add compression James Galloway Recording Techniques 12 04-14-2003 15:00
