Old 03-04-2001
smellyfuzz's Avatar
smellyfuzz smellyfuzz is offline
Force of Nature
Location: AMITYVILLE, NY 110110100101000101010 ----- I live in the ----- HORROR HOUSE
smellyfuzz has a reputation beyond reputesmellyfuzz has a reputation beyond reputesmellyfuzz has a reputation beyond reputesmellyfuzz has a reputation beyond reputesmellyfuzz has a reputation beyond reputesmellyfuzz has a reputation beyond reputesmellyfuzz has a reputation beyond reputesmellyfuzz has a reputation beyond reputesmellyfuzz has a reputation beyond reputesmellyfuzz has a reputation beyond reputesmellyfuzz has a reputation beyond repute
Angry
FAZING CYMBALS
I have miked up & recorded a drum set for a first time...
The snare, toms & hi-hat sounded pretty good...
But the crash cymbals phased a bit.
Any suggestion?
Old 03-04-2001
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Turn down all faders except the overheads... check those for phase problems.... if there are, move the mic positions till the phase issues disappear -- 1 inch can make a HUGE difference.
Then bring up each of the rest of the mics and check against the overheads, adjusting the position until the phase problems are minimized... worst case, reverse phase on offending mics that positional adjustments don't seem to work on...
That should do it...
Bruce
Old 03-04-2001
smellyfuzz's Avatar
Force of Nature
Smile
THANKS BRUCE !!!!!!!!!!!!
Old 03-04-2001
Shailat's Avatar
Shailat Shailat is offline
Period
Shailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud of
You might try an XY position that tends to eliminate most phasing problems and sounds rather nice as overheads.
