Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 06-14-2007
aidan_m's Avatar
aidan_m aidan_m is offline
Budding Rock Star!
aidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond repute
Kick pedal bouncing! Grrrr..
I was recently recording and decided to use the clicky hard side of my beater, but it ends up leaving an after-bounce off the skin.. i.e. beater hits when supposed to but then bounces off the skin again.. (duh-dum)
Ended up having to gate the kick to eliminate this but would appreciate any tips on how to stop it all together without going back to soft side of beater..
Any advice on skin tension/spring tightness/beater angles etc.. appreciated!
Old 06-14-2007
MadAudio's Avatar
MadAudio MadAudio is offline
Damned if I do
MadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond repute
My guess is it's your technique. When you play, do you tend to let the beater rest against the head on a hit? If so, that's the problem.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music.
"Do yourself a favour just shut up, read up then put up." --muttley600
Old 06-14-2007
aidan_m's Avatar
Budding Rock Star!
was thinking that, but p[laying and recording for years and have never had the problem, do rest after hit though..
Old 06-14-2007
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
You've had the problem, you've just never noticed it. With a soft beater it would tend to bury, with a hard one it will bounce.
If you loosen your head, it might help. You could just make an effort not to rest the beater on the head...
Your technique will also be a problem if you ever decide to start using triggers.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 06-14-2007
JuliánFernández JuliánFernández is offline
2&4
JuliánFernández has a reputation beyond reputeJuliánFernández has a reputation beyond reputeJuliánFernández has a reputation beyond reputeJuliánFernández has a reputation beyond reputeJuliánFernández has a reputation beyond reputeJuliánFernández has a reputation beyond reputeJuliánFernández has a reputation beyond reputeJuliánFernández has a reputation beyond reputeJuliánFernández has a reputation beyond reputeJuliánFernández has a reputation beyond reputeJuliánFernández has a reputation beyond repute
Oh no... don´t say that, please...
I´m not sure if you guys -telling that burying the beater is a problem- are drummers or not, but any experienced player will tell you that there´s nothing wrong about that...
Many many top players bury the beater. Vinnie, Porcaro, Erskine (funky era), Vega...
You need to work on your foot control, that´s all...
You may wanna try heels down, heels up, burying or not burying the beater... Is about comfort and making the GROOVE happens.
Experiment, and have fun...
HTH.
Old 06-14-2007
Farview's Avatar
Burying the beater isn't a problem unless:
A. you can't control it, so it bounces
B. you are using triggers and a double pedal
I am a drummer... And I bury the pedal, but I can control it and i play differently with triggers than I do without.
Another suggestion for the OP: Do you have a hole in the front head? If you don't, it will make the beater bouncier.
Jay Walsh
Old 06-14-2007
MadAudio's Avatar
Damned if I do
I am a drummer as well, and have been playing for nearly 30 years. Burying the beater can be fine as you have noted Julián, but it doesn't work in all situations - especially those that Farview has described.
My kick tone is very distinctive. For many years I have used a Tama plastic beater in conjunction with a hard plastic disc attached to the head, and letting the beater face release is essential. Just ask anyone who played my kit at JamFest 6!
Old 06-14-2007
2&4
Great guys... you´re right, the problem seems to come for lack of control...
I just wanted to chime in to adress that burying the beater is not a problem per se.
Cheers,
J.
Old 06-14-2007
junplugged's Avatar
junplugged junplugged is offline
Busy Writing/Producing...
junplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond repute
i had that problem for a while. sometimes it happens again when i'm not warmed up and my leg and foot is too tense and not releasing after the kick, and sometimes when i'm too far up on the pedal.
some harder beaters also make it worse, but i also saw an experienced drummer once have that happen when he was using a kit that wasn't his.
so it's a combination of what you're used to and the gear and it's subtle, but annoyed the heck out of me for a while and i posted all over about it.
i play mostly foot-down now and starting out with that was a lot of bounce/double hits, but not much anymore. i didn't get it w/ heal up, even when not bashing the beater/ leaving it in the head.
Old 06-14-2007
junplugged's Avatar
or maybe i just have been using the felt for a long time since then?
Old 06-15-2007
aidan_m's Avatar
Budding Rock Star!
So in summary, I'm not playing right???? After 20 years dang!!!
This happenned on a kit that 's not mine.. maybe down to the skin tension as I've never had the problem before with hard beater on click pads (and would have noticed before as I've played on a plenty released stuff!)
The drummers here:
So is it a bad technique to leave the pedal down after a hit? i play heel up and would just be floating my leg in the air if taking foot up after hits.. (p.s. i use pearl double pedal just for little fills and stuff not metal double pedal) I use a pearl pwershifter:
Like This One
Any and all help appreciated!!*
*Disclaimer: Advice I don't like will be ignored! Especially that pertaining to my bad technique!
  #12
Old 06-15-2007
tmix tmix is offline
1K Silver Member
tmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond repute
I play heels up.
I also get to play a lot of different set ups at festivals.
Beater side head tension DEFINITELY plays a huge part, but it drastically effects the tone as well. The looser it is the less it double dribbles.
Also the pedal adjustment for heels up is more critical.
It helps to have a good adjustable pedal like an Iron Cobra where you can adjust the tension first, then move the beater while your leg is on the pedal putting the "at rest" weight on it where the beater is maybe a half inch or so off the head.
My experience anyway.
Tom Menikos
T-Mix Studios
Mansfield Texas
WWW.tmixstudio.com
  #13
Old 06-15-2007
aidan_m's Avatar
Budding Rock Star!
Red face
Originally Posted by tmix
I play heels up.
Thanks for the input.. I know the problem can't be me
  #14
Old 06-15-2007
Farview's Avatar
No one would have questioned your technique if you would have explained that this didn't happen on your kit and it wasn't the first time you used a hard beater and a click pad. Knowing that, it's obviously the pedal adjustment/head tension. Lack of a vent in the reso head will also give you more bounce if you are used to having a hole.
Jay Walsh
  #15
Old 06-15-2007
2&4
Let me say this...
It doesn´t make (or it shouldn´t make) any difference if is not your kit (or pedal)... I´d seen many pro player playing and grooving the hell of someelse´s kits...
You should be able to play any kit with enough control to make it sound good.
Anyway, i´m not sure if it´s a good idea to try "new things" when recording... Kenny Aronoff used to say: "Use what you practice, practice what you use".
Look it this way... you found that you´re control is better with soft beaters. Now you can go woodshed to achieve good control with hard beater, with both heels down or up technique.
JMHO.
  #16
Old 06-15-2007
Farview's Avatar
JMHO.
There is a big difference between the feel of a 24 inch kick with no front head and the batter head slacked out and a 20 inch kick cranked to the moon with a closed front head. Let alone being used to a Trick pedal and having to use a speed king.
Being able to 'groove the hell out of someone elses kit' assumes that the kit is set up somewhat appropriately for what you are doing.
No one can pull off big band swing on my kit, you can't play death metal on Buddy Riches old setup. It just won't happen no matter who you are.
Jay Walsh
  #17
Old 06-15-2007
2&4
I disagree. Gear does not dictate what you can or cannot do. Ability and cotrol does.
I´m not saying that all kits are the same, there´s obviously better choices for different approaches/styles, but you can make swing a whole big band with almost any kit. BTW, Aidan "problem" is about control, IMHO, not gear. Ask any pro session drummer, and he´ll tell you that he´s supposed to deliver great music with any drumset.
Do you think Louie Bellson or Joe LaBarbera are not gonna make a band swing thier asses off if you give them a 24" bass drums and ZBT cymbals?! I bet they can.
  #18
Old 06-15-2007
Farview's Avatar
I'm not saying that they couldn't do what they do, I'm saying that they wouldn't make the drums speak like they should and I'm sure it would take them time to get used to the triggers. (try to do anything with brushes on a kit loaded with triggers)
Most guys bring their own pedals for a reason. You can't jump from an Axis to a speedking and expect to have the same speed (the pedal won't do it) or feel.
If you are used to having some bounce on the kick (or the other drums for that matter) and you jump on a kit with the heads slacked out, you won't be able to play your best. Possibly not the old school guys from the 50's that were playing crap equipment (by todays standards) to begin with, but they really weren't playing at the outer reaches of human ability. Some of them were possibly held back by the pedals and such that were available at the time.
I mean really, if a pedal will not follow your foot as fast as your foot can go, you aren't going to get it done.
Maybe you haven't been around enough of these guys when something isn't exactly to their liking.
Jay Walsh
  #19
Old 06-15-2007
2&4
Oh, i really do. I remember Elvin pissed off in Europe (France maybe) for a crappy stool.
I agree with you, i just wanted to adress how important is being prepared to face any situation.
It works for me, at least. When i sit on a drumset i try to make it sounds good anyhow, and no matter how crappy the kit is, i try to do my best.
The bottom line to me is, woodshed and play as much as you can. Control is the key to grooving. And when we play, is the only thing that matters.
And, again, when recording try to do what you know you CAN do. Experiment is not a good idea for recording neither live playing.
Cheers.
  #20
Old 06-15-2007
MadAudio's Avatar
Damned if I do
I think the bottom line here, Aidan, is that you are not playing "wrong" and never have been. You're just having an unsurprising initial difficulty adjusting to a different method. You'll get through it.
  #21
Old 06-19-2007
aidan_m's Avatar
Budding Rock Star!
Cheers for all the input people.. Looks like I've started quite the debate!! Solved my problem anyway.. Dropped stool height a touch to give more leg control and problem solved!
anyone know how to rewire a nonlatching sustain pedal for a Yamaha DD55 bass pedal?? retrorelix Drums and Percussion 1 06-26-2006 14:24
kick in the chest evading me! vermades Mixing / Mastering 21 08-08-2004 09:58
kick drum rumbles detuned6 Drums and Percussion 13 06-18-2003 05:17
good overhead and kick drum mic placement..... HEEEEEEEEEEELP!!!!!!!!!! ZEKE SAYER Drums and Percussion 4 07-16-2002 20:42
What's a good double kick drum pedal? Whoopysnorp Drums and Percussion 12 05-12-2002 20:27
