Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 06-07-2007
strungout's Avatar
strungout strungout is offline
Newbie
strungout is on a distinguished road
Arrow Drum Rec. ~OHs~
I'm going to record a fellow band I know. I'll be using the MOTU ultralite w/ 2 preamps. How should I use the preamps for the 5 piece kit (3 toms, 2 cymbals, hihat, 1 bass, 1 snare)?
I was thinkin:
-2 Rode NT5s
OR
-1 Rode nt5 and a shure beta52 kick mic
You could probly tell that Im not a drummer.
Old 06-08-2007
dgatwood's Avatar
dgatwood dgatwood is offline
is out. Leave a message.
dgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond repute
I was thinkin:
-2 Rode NT5s
OR
If you only have two pres, I'd say two Rode NT5s from out in front of the kit and pray that your room sounds good. Buy some pres.
Originally Posted by Obi-Wan
If you mod me down, I will only grow stronger.
Old 06-08-2007
Track Rat's Avatar
Total Gear Slut
I'd use both Rodes; one about two drums stick lengths directly above the snare, aimed at the at the snare and the other on the front kick head.
Mike
Old 06-08-2007
tmix tmix is offline
1K Silver Member
tmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond repute
Exactly what I would do.
If I was not going to do a lot of tom fills I may even put 1 in front of the kit focused toward the kick and one just on the snare(really close just under the hi-hat).It will give a bigger snare sound in relation to the rest of the kit.
Tom Menikos
T-Mix Studios
Mansfield Texas
WWW.tmixstudio.com
Old 06-08-2007
strungout's Avatar
Newbie
So this is not a good idea at all then...
http://www.youtube.com/watch?v=IiFOD1EeKhQ
Old 06-09-2007
Track Rat's Avatar
Total Gear Slut
Nothing wrong with that. It still comes down to the player and how he hits. The way I discribed gives you some mix control over kick to snare ratio after the fact. With the Mixerman method with just two mics (nothing on the kick)you have stereo with good phase coherency but are at the mercy of the player on how much kick makes it to tape. Try it. Hell, try everything. There is no one right way. If it sounds good to you, it is good.
Mike
Kick Drum Miking Question zackformula Microphones 18 06-22-2006 07:28
sync'in separate midi tracks Modern_Talking MIDI Mania 9 05-07-2006 23:52
Drums from A-Z: My Approach LeeRosario Mixing / Mastering 5 04-10-2006 01:34
Cheap drum triggers/pads Lopp Drums and Percussion 7 04-09-2003 22:58
how to get that loud,low-end,kick drum click sound step by step right here ZEKE SAYER Drums and Percussion 31 05-20-2002 15:55
