My amp's got a crackle in it, darnit.
It happens only when I play a certain fret, and to be sure I played the same note on different strings. It's like a frequency/pitch thing. More so on the clean channel, but does happen on the lead channel
Isn't that weird? I don't know if I can track something like that down.
Is it a tube amp? Possibly some microphonics going on? Could also be just the right frequency causing something to shake loose. Does it do it with different guitars also?
Maybe you can interface with my ass, by biting it. GFCG Member No : 000 015 "It's hopeless. I can hear all this great music in my head, but my stupid hands can't keep up..." |
It's Tube.
Does it happen at all volumes or just at loud volumes? Have you tried isolating the head from the cabinet to see if maybe it's from the speaker vibration? If it's a combo amp, then that might make things trickier to track down, since they make all kinds of rattles and noises as it is!
If it's the amp, but not a tube, then you'll have to get into the amp to take a look, but if you're not experienced at dealing with the inner workings of amps, then take it to a tech. There are voltages in there that can kill you even with the amp powered down and disconnected. Buit you've been around here a while and read all that before, eh? |
Someone on here had the same amp and turned it into a head by cuttin the bottom off of it. I think I make try that this summer. It happens at low to mid volume on the clean and at loud volumes on the lead.
Haha weird i'm having the same problem, se emy 'valves' thread. What kinda amp?
Good tips here. Another possibility might be the speakers. If you isolate the head from the cab and still get the noise on that note, then it's possible that there might be a speaker connection inside the cab coming loose or something like that. Hitting that one note could make the connection jiggle just right and cause some noise. If that were the case, it wouldn't be too volume dependent, because even at low volumes, just hearing that frequency could make it shake enough to cause the noise.
The fact that it's a combo could make the diagnosis a bit trickier; I feel your pain! Another question, is the crackle significantly louder than the guitar tone itself, or does it more or less blend in? Does the crackle volume/strength increase with amp volume, or does it seem to stay more constant when compared to the amp volume?
#12
Jimmy's amp crackles and I don't care...
In His Name Big Kenny |
#13
Turn the amp upside-down and see if it still makes the noise!
| Crate Amps | HLC | Other Equipment and Reviews | 9 | 06-15-2005 20:48 |
| Expensive vs. Cheap Amps | Lopp | Guitars and Basses | 25 | 06-02-2005 19:31 |
| Where to Put the Guitar Amps | AlexW | Recording Techniques | 10 | 04-27-2005 11:59 |
| CAD 88 for amps / overall? | mrelwood | Microphones | 1 | 04-18-2005 23:04 |
| One guitar into multiple amps | Fantastic_Mad | Guitars and Basses | 8 | 07-24-2002 21:45 |
