booth from doors
I'm reading around and figure I can make a 'diamond shaped' vocal booth shape http://www.vocalbooth.com/products/diamondseries.html for voice recording (voice over, not singing) from unfinished door panels.
The room is pretty quiet overall, but it is open (no door) to a hallway and a staircase up from the basement level. It is a pain when recording longer voice jobs (elearning, audio books...). I know it would be relatively cheap to use 36" luan door panels (about $25 ish) for the walls, frame it with 1"x1"'s and securing it with screws and liquid nail. Then fix Gypsum (drywall) sheets to the outside and inside. I was even thinking of using Green Glue (or equivalent) between the door/drywall contact surface. Seal it up with acoustic caulk and attack a solid door to the front of it. Overhead would be either same construction or just heavy plywood with insulation. Interior would have all the trimmings (treatment - foam, light, venting). I was even thinking of experimenting with sound blankets instead of foam (cheaper and less space). Any adjustments or 'absolutely don'ts' I should be aware of? |
The doors will just make it too heavy to bother moving around.
I've already built this - the same configuration you're proposing- and it works for me: http://www.palmcitystudios.com/timob...oundbooth.html Portable, storable and cheap (about $50-60 for 2 sets to make a diamond booth) |
Not worried about portability.
Tim,
I love simple, and yours looks very simple and low maintenance. Unfortunately, for voice over projects that take a lot of time, I have to have an isolated space (or pretty isolated) that will keep the sound of my dog, wife, 14 year old son, trucks...and such from sneaking into the recording. I have tried to record long projects in the basement space with just some absorber panels. It get's very frustrating when things are going well and 20 minutes into a narration that is going well, some thump or phone ring or car with heavy base messes it up. I want to move more into audio book/narrations, so the isolation will mean that I can eliminate those types of mess ups. Once it is assembled, it won't move, but that is okay for now. Having it closed off also gives the advantage of a separated area where visiting kids won't see and want to play with my gear. Your sound blankets though, I was thinking of using those instead of acoustic foam for the interior treatment, how much? Quote:
Sorry, but if you have trucks, animals and kids already bleeding in, neither of these solutions is going to work for you. Sound absorbtion is a tweak, but soundPROOFING takes MASS and lots of it.
Studios spend million$ to completely isolate with rooms-within-rooms and special materials. You're just not going to get that with a cheap DIY project. More info over on www.ethanwiner.com for you to scan through... |
--Ethan
The acoustic treatment experts |
| isolation booth doors | garbagelarge | Studio Building & Display | 4 | 06-01-2006 14:06 |
| Heavy solid fire doors vs. patio doors | conan | Studio Building & Display | 0 | 11-02-2005 09:09 |
| MM - Vocal Booth Wiring | frederic | Studio Building & Display | 3 | 02-21-2005 13:18 |
| It's ghetto, but turning a closet into a vocal booth? | anppilot1 | Studio Building & Display | 21 | 11-27-2003 22:45 |
