Bass guitar DI clipping
I have a friend whose recording chain for bass is as follows:
Ric bass > Sansamp Bass Driver > Presonus Firebox He would like to record a parallel clean direct bass signal together with the effected Sansamp XLR output. The Sansamp has a parallel output that works for this, but it overloads his Presonus inputs even with the gains all the way down. If it were my studio, I'd just engage a pad and be done with it, but his Presonus has no pad. I suppose one possible solution is to buy an additional DI box with a pad. Any other ideas of how to tame these levels? Many thanks |
Has he tried simply turning the volume down on the bass itself?
G. |
Is the SansAmp putting out a line level signal? Is he trying to run it through a mic preamp?
Additionally, the SansAmp has both a drive and an output level control. If the signal is coming too hot out of the SansAmp, which it sounds like it definitely is, the you gotta ask the question of where in the gain structure is the signal becoming too hot? If it's simply the ooutput level on the SA, then that has to come down. If it's the drive into the SA, then that has to come down, if it's the signal coming out of the bass itself, then that has to come down. If the only way he can get "tone" is to run it too hot out of the bass, then it's eather more of an ear problem than a gear problem, or it's that he doesn't know how to set the SA properly. But 99 times out of 100 there should not be a good reason that he needs two DIs in one chain. G. |
The Sansamp has a parallel uneffected output intended to be sent to an amp so it should be a near duplicate of what is coming right out of the bass. He gets the same thing when plugging the bass directly into the instrument input of the Firebox, i.e. bypassing the Sansamp.
I think he is using everything correctly. I've had basses plugged directly into the instrument input of a preamp and had to use the pad due to big string slaps. The Firebox doesn't have a pad, though the gain knobs go down to -10. If he buys a DI, I'll probably have him put it first in the chain so he gets the cleanest possible signal. He wants me to reamp the bass and the Sansamp effected track will probably be a throwaway. |
It sounds to me that the problem is at the source.........
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F. |
What about the bass or the playing could do this? It's a mid 90s Rick 4003 bass. He doesn't use a pick. Has a strong attack, but doesn't do pop&slap style. I guess I'd say Geezer Butlerish in general. |
#12
As far as what could be going wrong, If the bass is clipping an instrument input with no gain on it, then the issue has to lie with the bass or the player. If the bass has really hot active pickups, then that is a problem with the bass itself. If the player uses technique that creates too much output then that is a problem with the player. It is not the gears fault if someone feeds it more than it is rated for. In the end, you either have to change the bass, change the way it is played or add another process inline that will bring you down to a respectable level. If you do not want to do the first two, then a DI with a pad or even an inline pad is an excellent solution.
Dealer for Peluso Microphones, Blue Microphones and CBI cables.... http://www.myspace.com/xstaticstudios |
#13
Thanks for this thoughtful response. I fully agree that putting the DI first would work best. Since I'll probably be reamping his clean signal, the effected Sansamp track is probably a throwaway. The bass is an old Rickenbacker, so the pickups are passive. Maybe the strings are hitting the pickups or something. Unfortunately he's not recording in front of me so I don't know. |
#14
i see what your saying about order xstatic, makes sense to have the clean one first.
and i think some people are confused a bit, he's not clipping the sans amp, the signal is passing thru the sans amp totally uneffected and going into a pre amp with no built in di which would normally step the bass down 10db (or more, allong with the impedence matching) and then there'd be no clipping. try taking a bass, and plugging it into a modded cord that goes from 1/4 inch to xlr sometime if you want to see the output in bass vs. mic terms. a bass just puts out more juice, and a di usually steps it down, and you never notice. |
#15
I thought he mentioned that they had also tried it in an instrument input with the same problem. It is quite possible for an instrument to put out to much at full volume for an instrument input. It happens all the time which is why we have to pad DI's on occasion. If the pickups are going out or are not setup well this could certainly affect the output volume in all sorts of ways.
#16
I suspect not having a pad is just one of those design compromises of the Firebox. It seems to be a decent unit overall though. |
#17
Can you address the Fireboxes levels from some sort of Firebox control panel? If so you may be able to variate the gain from there to keep the input signal from overloading.
| New Rep Point Thread. | DJL | Prime Time | 114410 | 51 Minutes Ago 05:09 |
| POD bass tones... better than PODxt for guitar? | Superhuman | Guitars and Basses | 2 | 11-20-2006 14:16 |
| Recording Bass guitar; Post sound files | frank_1 | Recording Techniques | 0 | 01-31-2003 22:01 |
| Spectral analyzers and mixing | Chris Fallen | Mixing / Mastering | 21 | 03-02-2002 19:02 |
