Soundproofing a finished room?
Where to start, let me see pics of your room and what your thoughts and ideas are...also what you wished you had done. I need to reduce the amount of volume escaping the room. Thank you gentleman!
Installing seals around doors, and sealing up any gaps will help isolation.
Isolation requires mass and no air-leakage. The most efficient use of mass is through a mass-air-mass system. If your room is finished, you probably wont want to install a second, decoupled, room within. So you will have to seal up any gaps, sort your weak links, and be happy with it. Weak links can include, doors, windows, roofs, etc. |
The door trim isn't put on on the inside of the room. What should I fill it with to insulate it?
Stuff with standard insulation and then install the door trim to cover the gap and provide some mass over the opening. Caulk behind if you want.
Bryan |
| Please Help Noob (me) Switch from Plug-in Reverb to Hardware | undermind | The Rack | 24 | 01-19-2007 10:20 |
| Leslie sound more watery | walters | Mixing / Mastering | 26 | 07-28-2005 20:46 |
| Making my bad room sound good (help!) | Gunther | Studio Building & Display | 7 | 02-15-2003 08:32 |
| Tracking room floors | Michael Jones | Studio Building & Display | 54 | 02-07-2003 07:05 |
| Temporary soundproofing (dorm room) | joshwa | Studio Building & Display | 3 | 09-22-2000 01:27 |
