Old 05-26-2007
King_Cobra King_Cobra is offline
Junior Member
King_Cobra can only hope to improve
Optional Acoustic Panels
The other day I was given a few office panels.
http://modernoffice.stores.yahoo.net/propanels.html
Two are 24x24x2 and Four are 36x36x2 thick. Not sure what material they're made form, but they look very similar to this:
http://www.atsacoustics.com/cat--ATS...nels--100.html
Just wondering if I can use them as acoustic panels?
I only have the internal panels. They did not come with the metal tracks. Seen on the website. The metal tracks where damaged so the company was getting rid of them. Under the panel's fabic it looks like three boards layered and clued together. I plan to use them in the control room. The control room does not have acoustic treatment. I plan to change the fabic and maybe get an installtion kit.
http://www.atsacoustics.com/cat--Accessories--103.html
Is there more I can do to modify their performance? Or is fiberglass boards the best choice?
Need help?
Your Guide To Frequency
Old 05-26-2007
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
always the better choice...
I doubt those dividers will do much help. Especially if you say under the fabric they are just boards?? Rigid boards?
Don't cheat on acoustic treatment...get something that will actually benefit you. You wouldn't record an album with a $5 guitar from Walmart would you?
www.redlabaudio.com
Old 05-26-2007
danny.guitar
Guest
Posts: n/a
I think they'd reflect more than they'd absorb, or at the least, not do much of anything at all.
The site you linked to (ATS Acoustics) has very good prices for pre-built panels. Do yourself a HUGE favor and just buy those. It kind of sucks spending money on fiberglass, but not only will it make your studio LOOK better it will also sound better, and probably be easier and more fun to work in. It's the first thing I'm going to do once I buy a new geetar.
Old 05-28-2007
bilco bilco is offline
Senior Member
bilco has a reputation beyond reputebilco has a reputation beyond reputebilco has a reputation beyond reputebilco has a reputation beyond reputebilco has a reputation beyond reputebilco has a reputation beyond reputebilco has a reputation beyond reputebilco has a reputation beyond reputebilco has a reputation beyond reputebilco has a reputation beyond reputebilco has a reputation beyond repute
Give them a try, I think they will at least help absorb flutter echo in your room. Record something without them in the room and then repeat with them in the room. Those things usually do have have some kind of sound absorbing material in them.
bilco
Old 05-28-2007
mrface2112 mrface2112 is offline
Thread Killer
mrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond repute
they'll work pretty decently as gobos--for separating acoustic instrumentalists playing "live", electric guitar amps, mitigating some drum bleed in a live room, that sort of thing.......but don't mistake them for "acoustic treatment".
cheers,
wade
Old 05-28-2007
Junior Member
Wow.. thanks for the advice guy!
Need help?
Old 05-29-2007
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
... I plan to change the fabic and maybe get an installtion kit.
..Is there more I can do to modify their performance? Or is fiberglass boards the best choice?
As was mentioned before they likely won't do acoustic treatment. If these happen to have at least an inch of fiber they would absorb some highs which might qualify for gobos. (Although a free flexing panel can absorb lows.)
There's two things going on here; Solid' reflects and/or isolates, fiberglass absorbs.
If you're going to re-wrap them why not add a 2-3" layer to each side
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
Old 05-29-2007
Nameless Nameless is offline
Newbie
Nameless has a reputation beyond reputeNameless has a reputation beyond reputeNameless has a reputation beyond reputeNameless has a reputation beyond reputeNameless has a reputation beyond reputeNameless has a reputation beyond reputeNameless has a reputation beyond reputeNameless has a reputation beyond reputeNameless has a reputation beyond reputeNameless has a reputation beyond reputeNameless has a reputation beyond repute
Maybe attach some auralex to one side and a 1/4" to 3/4" piece of plywood on the other. And hang them on the walls to absorb some highs.
Or add 2" to 4" OC 703/705 to one side (would be easier with this because it's more rigid than mineral wool) and a piece of plywood to the other and use them as gobos.
As they are now I don't think they would do much for gobos. Or anything, really. But they will serve a purpose if you attach something to them that WILL do something, like rigid fiberglass or auralex foam.
Old 05-29-2007
yeah, but then you pretty much don't need the office panels. I mean, if you're going to make some 703 or auralex attached to plywood...might as well just forget the office panels then. No point to them anymore, imo.
www.redlabaudio.com
Old 05-30-2007
Robert D Robert D is offline
Close to the Edge
Robert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond repute
Actually, a lot of office partition construction these days is optimized for sound absorption, so don't necessarily discount these as having no real acoustical properties. I would suggest you mix them with some of the good stuff rather than just saying toss them.
Regards,
RD
http://www.myspace.com/twentysevenmoons
Old 05-30-2007
Newbie
In a home recording-on-a-budget, use-what-you-can-find situation, I think they're a good find. And they do have a use as something to attach foam or something else to.
And if they DO happen to have some sort of sound absorption properties then they might be worth something but I doubt much.
Obviously just buying 703 panels would be the best option, but in a guerrilla recording situation I think they might have a purpose.
For all I know, the poster could have plenty of money for 703 though, if that's the case then dump them or give them away or something and get some/build some 703 panels.
$10 DIY Wall Mounts for your Owens-Corning-703 Acoustic Panels homestudioguy Studio Building & Display 3 05-03-2007 08:32
$10 DIY Wall Mount for your Owens-Corning 703 Acoustic Panels homestudioguy Studio Building & Display 0 05-02-2007 13:42
Acoustic Panels = Bass Traps? Gear_Junky Studio Building & Display 39 04-07-2006 13:50
Rigid edges on accoustic panels Innovations Studio Building & Display 5 11-24-2004 09:13
New Acoustic Panels with OC 703: Any Health Concerns? Cuzin B Studio Building & Display 13 01-28-2004 13:55
