Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 05-13-2007
FloydBenson FloydBenson is offline
Newbie
FloydBenson is on a distinguished road
Weird "heartbeat" noise with Shure SM58s!
Hi everyone, I'm running Cubase SX and I've got a strange problem.
I have a couple of Shure SM58s and I use an Edirol UA-25 audio interface.
When I try to record with either of the SM58s, Cubase records onto the track this strange regular 'pulse' sound that closely resembles a heartbeat, indeed the waveform looks like a medical AKG report!
This only happens when I acually press the record button, and does not happen with line instruments or even a crappy cheapo mic I tried.
I've tested both the SM58s in Sound Forge, and they work fine, clear as crystal.
I'd be very grateful if someone could post a suggestion, is there perhaps some known non compatibility issue with Cubase and Shure SM58s?
Thanks a lot
Lyle
Old 05-13-2007
TripleJ's Avatar
TripleJ TripleJ is offline
Senior Member
TripleJ has a reputation beyond reputeTripleJ has a reputation beyond reputeTripleJ has a reputation beyond reputeTripleJ has a reputation beyond reputeTripleJ has a reputation beyond reputeTripleJ has a reputation beyond reputeTripleJ has a reputation beyond reputeTripleJ has a reputation beyond reputeTripleJ has a reputation beyond reputeTripleJ has a reputation beyond reputeTripleJ has a reputation beyond repute
That's quite bizarre. Theres obviously no compatability issues seeing as how it's just a voltage running through your interface. There's no identifier or anything.
Old 05-13-2007
boogle boogle is offline
Junior Member
boogle is infamous around these partsboogle is infamous around these partsboogle is infamous around these partsboogle is infamous around these partsboogle is infamous around these partsboogle is infamous around these partsboogle is infamous around these partsboogle is infamous around these partsboogle is infamous around these partsboogle is infamous around these partsboogle is infamous around these parts
There is something else, what you described is not possible. If the noise is regular than that almost guarantees that the problem is digital, I would suspect the interface.
Is the sound noise or is it crackling. (If you put a frequency analyzer on the noise does it look like it is pretty much all frequencies or is it a peak in just one frequency band?
Old 05-13-2007
Newbie
It really does sound like a heartbeat, it's not crackly or poppy.
Here's a screenshot of the audio with the mic plugged in http://www.flickr.com/photos/8340238@N08/496388421/
and here's one with the mic unplugged, but the cable still plugged in
http://www.flickr.com/photos/8340238@N08/496388425/
On the on without the mic plugged in you can still see little pulses, so Im presuming it's a problem with the cable and have ordered a new one.
I just don't understand why I dont get this when I record on Sound Forge with the same mics and cable.
The interface is fine with other mics or line instruments too, it can't be a fault with that.
Old 05-13-2007
Junior Member
I am not so sure that is a cable issue, looks to regular. Can you record about 20 sec. and post it somewhere where I can hear it?
And if you do keep it in .wav or something, I do not need it streamed, just to be able to download it.
Old 05-24-2007
Bass Jas's Avatar
Bass Jas Bass Jas is offline
[insert brilliance]
Bass Jas has a reputation beyond reputeBass Jas has a reputation beyond reputeBass Jas has a reputation beyond reputeBass Jas has a reputation beyond reputeBass Jas has a reputation beyond reputeBass Jas has a reputation beyond reputeBass Jas has a reputation beyond reputeBass Jas has a reputation beyond reputeBass Jas has a reputation beyond reputeBass Jas has a reputation beyond reputeBass Jas has a reputation beyond repute
What other programs are running in the background?
I see in your picture you have firefox running and you are
browsing this forum which auto updates every few seconds?
Just a thought, and do you have any antivirus programs running?
What other devices are plugged into the same outlet or circuit?
weird noise dirtyp Newbies 5 03-10-2007 00:02
1982 Ovation Pickup Noise Cure? soundchaser59 Guitars and Basses 2 03-13-2006 23:46
DSD Vs PCM from the Head Engineer at Phillips BigRay Other Equipment and Reviews 0 12-08-2005 09:00
weird noise between punches in cubase UserWho? Cubase User Forum 0 02-09-2005 23:35
