Old 05-02-2007
sixteenbars sixteenbars is offline
Newbie
sixteenbars is on a distinguished road
Active Monitors for Travel
I just bought a laptop and I'm now a mobile producer. I'm looking for a small pair of active monitors to travel with. I was leaning toward the KRK RP 5. Are they very heavy? Small? Any other options?
Old 05-02-2007
UGMastermind UGMastermind is offline
Sinister South
UGMastermind has a reputation beyond reputeUGMastermind has a reputation beyond reputeUGMastermind has a reputation beyond reputeUGMastermind has a reputation beyond reputeUGMastermind has a reputation beyond reputeUGMastermind has a reputation beyond reputeUGMastermind has a reputation beyond reputeUGMastermind has a reputation beyond reputeUGMastermind has a reputation beyond reputeUGMastermind has a reputation beyond reputeUGMastermind has a reputation beyond repute
I have a pair of rp5s they are pretty heavy I wouldn't want to lug them around. They are not very tall or wide but they are deep. If I was you I would get some good headphones and do final mixing back at your studio or where ever you have your monitors.
Old 05-02-2007
Sinister South
There 16lbs each. guess not too heavy.
Old 05-02-2007
jabulani jonny jabulani jonny is offline
Senior Member
jabulani jonny has a reputation beyond reputejabulani jonny has a reputation beyond reputejabulani jonny has a reputation beyond reputejabulani jonny has a reputation beyond reputejabulani jonny has a reputation beyond reputejabulani jonny has a reputation beyond reputejabulani jonny has a reputation beyond reputejabulani jonny has a reputation beyond reputejabulani jonny has a reputation beyond reputejabulani jonny has a reputation beyond reputejabulani jonny has a reputation beyond repute
I also specialize in mobile recording and if I'm not using headphones, I'll take along a pair of Roland micro monitors. You wouldn't want to mix a full project on these probably, but they do a great job getting you close until you get home on a decent set of monitors. I don't think they make them anymore, but Edirol (owned by Roland) puts out two different sets of micro monitors. The larger of the two can be found here: http://www.musiciansfriend.com/produ...8&src=3SOSWXXA
and the smaller here:
http://www.musiciansfriend.com/produ...ors?sku=603677
For mobile monitors I think that's about as small as you will find at a decent price with decent performance. Good luck on your hunt!
Old 05-02-2007
timboZ's Avatar
timboZ timboZ is offline
Band-Aid®
timboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond reputetimboZ has a reputation beyond repute
I have a set of the Edirol MA-10. They are a size between the 2 posted above. I only use them to plug for my mp3 player. I never tried mixing on them.
I think the could be usable for monitoring but would not mix on them.
WARNING:
THIS POST DOESN'T CONTAIN ANYTHING HELPFUL
http://www.myspace.com/veritasrs
__________________________________________________________________________________________________
Old 05-03-2007
scrouch scrouch is offline
Senior Member
scrouch has a reputation beyond reputescrouch has a reputation beyond reputescrouch has a reputation beyond reputescrouch has a reputation beyond reputescrouch has a reputation beyond reputescrouch has a reputation beyond reputescrouch has a reputation beyond reputescrouch has a reputation beyond reputescrouch has a reputation beyond reputescrouch has a reputation beyond reputescrouch has a reputation beyond repute
Make sure you listen to the krks before you buy them. I tested the rokit 5s and they sound very anemic if you're mixing anything with bass in it. The 6s are far better in that respect and also have a flatter response, but they're too big to take with you. As long as you're seriously mixing anything you could use some good headphones, but for monitoring there are a lot of optons that are the same size or smaller than the rokit 5s (maybe even check out the krk v2-series), but they are much more expensive. The RP5s have a pretty clean sound overal but you can't use them if you're mixing certain types of music.
Selling a mackie 1604 VLZ mixer and Alesis M1 Active monitors picostudios Free Ads for Music / Recording Equipment 0 04-02-2005 16:24
Active monitors with sound system Jack Real Other Equipment and Reviews 5 11-26-2004 07:10
160 watt active monitors new £49 rizla Other Equipment and Reviews 8 03-29-2004 17:06
Alesis M1 active monitors? sparkmonkey Mixing / Mastering 0 08-12-2002 16:35
Get active or passive monitors? Fantastic_Mad The Rack 4 07-17-2002 18:33
