Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 05-01-2007
AMcB's Avatar
AMcB AMcB is offline
Why you gotta be so mean?
AMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond reputeAMcB has a reputation beyond repute
Piano/Keyboard Help
I'm mastering a cd with: 2 guitars, bass, piano, drums, voval...... I usally pan the guitars hard left and hard right, but I'm not sure what to do with the keyboard. It's in mono, only had one out. Should I center it or center one of the guitars, or what? When it's in the center it kinda makes everything sound bad. Any help would be awesome!
Thanks,
Aaron
Old 05-01-2007
RightOnMusic's Avatar
RightOnMusic RightOnMusic is offline
asshat
RightOnMusic has a reputation beyond reputeRightOnMusic has a reputation beyond reputeRightOnMusic has a reputation beyond reputeRightOnMusic has a reputation beyond reputeRightOnMusic has a reputation beyond reputeRightOnMusic has a reputation beyond reputeRightOnMusic has a reputation beyond reputeRightOnMusic has a reputation beyond reputeRightOnMusic has a reputation beyond reputeRightOnMusic has a reputation beyond reputeRightOnMusic has a reputation beyond repute
well if everything sounds bad when it's panned to the center, then i think you answered your own question.
Old 05-01-2007
AMcB's Avatar
But I don't know what to do, should i bring the keyboard to right right with the rhythm guitar? Should I center the rythm and put the piano in the right?
Old 05-01-2007
asshat
without having the session ourselves, it would be impossible for anyone on here to give you a perfect solution, but maybe pan the guitars hard left and right and bring the piano to like 2:00 or something, and the bass over to 10:00. experiment. if it doesn't work, try something else. maybe some eq might be called for if you have too much happening in the same panning space. like i said, i have no idea what any of this sounds like so i'd have a hard time giving you any hard, fast advice...
Old 05-01-2007
fraserhutch's Avatar
fraserhutch fraserhutch is offline
Flypaper for freaks
fraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond repute
What you are doing is mixing
If everything centered sounds bad, then I think your issues lies in EQ, not panning. As mentioned by others, it's impossible to give you an authoritative answer, but we can guess, and it soulnds to me that the piano is fighting for space with the other instruments. Try cutting the lows to see if it is fighting with the kick and bass, maybe cut some mids to see if it is fighting with the guuitars/vocals.
Generally, I try to make my stuff sound good all panned to center before I start panning. Then I know I have taken a step towards a reasonable mix.
The fact that no one understands you doesn't mean you're an artist...
Old 05-01-2007
AMcB's Avatar
I'll work with it... Thanks
What Piano/keyboard do you use? Scruffy Murphy Keyboards and Sound Modules 13 04-02-2006 17:53
Lil Help with beginner elec piano/keyboard purchase weighted keys daav Keyboards and Sound Modules 1 02-18-2005 17:15
9th and 13th chords on piano/keyboard Whyte Ice Songwriting, Singing & Vocals 8 12-19-2002 19:35
