TDK or Maxell or Sony?
Which brand of cassette tape is the absolute best to use with my 424MKII?
huh huh? Been using Maxell. Thanks, Tucci
Tucci |
Yo Tucci:When I was using tape, I liked the Sony Pro cassettes; however, I don't know if they are still available; might find some on E-Bay or it still may be in "someone's" store. Green Hornet ![]()
THE GREEN HORNET |
Yes! (Type II only!)
a.k.a. Davemania! Beatles and other Classic Rock covers!! Yeah, Yeah, Yeah!!! 637 songs by 191 bands.
I you really want the best sound possible, go for:
TDK SA-X. But, as reel said: any old Type II will do... |
I like to use maxell, but, out of a case of 25 I usually get about 3 bad tapes.
http://www.krom8.net |
Senior needs advice on tape transferrals
As a classical singer, I made many recordings on several cassettes, going back to the 60's. Then, over the years, made copies which now NEED to be transferred onto CD's. My dilemma is that there are too many individual solos
on 14 tapes which I would have to single out, and it would be too confusing for me to try and go directly onto CD's, so I want to make a final cassette copy and go from there. Please tell me the best type of tape to use, and whether any unwanted noise or hiss can be removed after the transfers are made. I was thinking of taking my finished CD's to a professional for this. Many thanx! |
I have used Maxell for the entire time I've used Tascam Portastudios, nearly 20 years. They always sound great and are very reliable.
Singer/songwriter/guitarist, TG girl and proud owner of a Tascam DP-01FXCD, Tascam Digital Portastudio 564, Tascam Midistudio 688, Tascam 424 Mk I and nearly 40 Apple Macintosh computers. |
Ya, Maxell type II 60 minute cassettes. The 60's have thicker tape, which resists deforming better than the longer 120’s or 90’s. On the other hand, the longer tapes are more flexible which may contribute to better head contact. Your call.
"Gorty's Tunes" |
This tape you are talking about,.....is it tapeworm?
"Gorty's Tunes" |
#12
Masking tape. Anyone visiting this site should start using masking tape. It works much better than ordinary recording tape. All the big time pros use it. The recordings ‘stick’ much better. Ordinary recording tape is slippery. The sounds just slip off after a few weeks.
#13
"Gorty's Tunes" |
#14
Yes, and wear your "digital" headphones while recording.
#15
What is this "cassette tape" of which you speak?
Some relic from the long-forgotten past? ![]()
Zaphod B Two-Headed President of the Galaxy (in exile) Tunes at http://www.soundclick.com/cowtowntommyboy "I have educated. I know what asshole is. "
#16
I would only attemp doing the cassette compilation yourself if you have a good quality, maintained deck that can do Dolby B or C. Although your best bet if you are willing to pay a pro, is to just cue up all your tapes for the engineer and record them straight digital. A lot of things can go wrong doing it yourself if you don't fully know what you are doing... Cassette tape hiss isn't as easy to remove in digital as you might think.
http://www.nationalaudiocompany.com |
#17
I second this. As hard as it may be for you, Zana, I'd go staight to digital, if at all possible. There's just too much degradation going from slow speed cassette to cassette, especially when you don't have an up to spec deck.
#18
check your pm's |
#19
the past 20 or so yrs., and some metals. I even have old Sarex tapes from the early 60's. By keeping them in tin cans, the tapes lasted longer, especially Sarex. Sarex - please come back! Thanks everyone, for your help. |
#20
automatic tape select function, plus Dolby HX-Pro headroom extension system, and bias adjustment. My other deck is a JVC TD-W354BK with compu calibration, Dolby B & C, HX PRO and automatic tape select function, but includes full logic mechanism and compu link. Could you please tell me which of these decks is best? because I haven't mastered transferring directly to digital equipment yet; thanks. |
#21
You can do a simple but effective test by recording a set of (steady) frequencies, from the bottom to the top, noting what the decks were originally factory spec'd to (from the manual), listenning to how faithfully each of the recorders reproduces those (vs the original signal) and pick the one, as your "master recorder / reproducer", which does a better job. (Prior to the tests, clean the tape path). |
