Decibel monitoring off?
I use FL Studio for production/mixing.
Voxengo Span says my db is -6 db. FL Studio's own DB meter says +6 db. FL Studio says 0 db. Voxengo says -10. So what's up with that? And I can hear distortion too, so it seems FL Studio is correct and Voxengo is wrong. |
I have no clue what you're talking about....
but it sounds like you're confusing VU and digital peak meters. So both are right! Just two different metering systems.
www.redlabaudio.com |
Isn't VU analog metering?
I'm talking about the metering in FL Studio not being consistent with the metering of the VST plugin Voxengo Span. Hope that clears it up. |
Is there anything effecting volume/gain between FL and the plugin? Is the plugin applying gain? (I don't know what that plugin does).
as for the outputs it could be as danny guitar said and be the plug adding gain. think like a parametric eq if you boost the eq loads then the gain going out is hotter hence you may have had fine levels before but after the plug its hotter and you get clipping ect. does that make sense?
Peace -Josh |
Vu is a scale/meter ballistics standard. You normally see it on analog gear, but you can have a digital VU meter.
The other possiblity is the voxengo is reading RMS levels and your other meters are reading peak. Check the setup of the voxengo.
| US-122 - Direct Monitoring - I Need Help! | KiFF BluEs | TASCAM User Forum | 13 | 05-16-2006 20:02 |
| How to detemine actual decibel rating of monitoring environment? | fritzmusic | Mixing / Mastering | 20 | 02-28-2006 09:41 |
| NEWBIES using stereo sound cards Article on how to set up your monitoring. | manning1 | Newbies | 10 | 01-08-2004 05:19 |
| Monitoring equipment: some unconventional wisdom | jeffree | Other Equipment and Reviews | 16 | 10-27-2003 18:57 |
| Monitoring settings via delta soundcard | frist44 | Cubase User Forum | 0 | 12-04-2001 16:43 |
