Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 04-27-2007
tmix tmix is offline
1K Silver Member
tmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond reputetmix has a reputation beyond repute
Help MSHilarious! or ? mic hummmmmmm
Hey guys! have a small problem I hope you have an answer for.
I have recently bought some EV n/d 406 or 408s (i cant remember).
They are the dynamic mics that are egg shaped and are suspended on a yolk of sorts.
They sound excellent except for the fact there is a verrrryyyy slight hum reminicent of a single coil guitar pickup.
As soon as you touch the mic the hum sound disappears and is wonderful. Problem is... it is hard to play drums and touch the mics at the same time...
Is it some sort of ground issue within the mics? All three exhibit the same noise.
I am wondering what the fix is?
Thanks!
Tom
Tom Menikos
T-Mix Studios
Mansfield Texas
WWW.tmixstudio.com
Old 04-27-2007
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
The 468, maybe? I don't know much about it, but I would guess you are getting induced noise, maybe from the cable from the capsule to body. That shouldn't be the case if it is a shielded cable, but I dunno what else to guess. But the noise has to come from somewhere, so you might look around your house for noise sources--flourescent lights, dimmer switches, electric heaters, etc., and see if turning something off helps.
Another thing that confuses me is the mic's self-noise spec of 14dBA. A dynamic mic shouldn't have self-noise; there is a bit of thermal noise but that should be way less than 14dBA. Like 40dB less Unless they knew the mic was suspectible to interference, and put the self-noise spec in to CTA Compare this to the specs for the RE20, where there is no self-noise spec (typical for a dynamic mic), but they show "hum pickup level" at -130dBm.
Sorry, just wild guesses from these quarters . . .
Old 04-27-2007
TheHunter TheHunter is offline
Senior Member
TheHunter has a reputation beyond reputeTheHunter has a reputation beyond reputeTheHunter has a reputation beyond reputeTheHunter has a reputation beyond reputeTheHunter has a reputation beyond reputeTheHunter has a reputation beyond reputeTheHunter has a reputation beyond reputeTheHunter has a reputation beyond reputeTheHunter has a reputation beyond reputeTheHunter has a reputation beyond reputeTheHunter has a reputation beyond repute
Is your system grounded? Most of this common problem is fix by running a ground wire.
Let your ears teach your fingers.
Old 04-27-2007
1K Silver Member
As far as I know all things in our system are grounded except the rolling racks dont have a direct ground.
The funny thing is no other mic dynamic or otherwise has this problem, and I have a pretty huge selection from different manufacturers.
It may be what MS suspects... inherent in the mic or design of the mic.
hmmmm
I may try opening the mic body up and see if there is a good connection from the capsule wire to the mic body or xlr connector.
Thanks!
Tom Menikos
T-Mix Studios
Mansfield Texas
WWW.tmixstudio.com
Old 04-27-2007
Faithful Departed
hmmmm
Thanks!
You know, looking at the mic again, it could be a simple shielding problem. If the mic capsule is totally surrounded by steel mesh, it is only partially shielded, something like 30% or so. Try an experiment; find something metal to surround the grille, and connect it to the case, and see if the problem goes away.
Old 04-27-2007
1K Silver Member
Good Idea.
I'll try an aluminum can first. I have a test lead with some alligator clips on it to make the jumper.
If I can't find a way to make them quieter, I'll have to off them on EBAYor something.
Shame though... They basically sound really nice.. better than a sm57.
Tom Menikos
T-Mix Studios
Mansfield Texas
WWW.tmixstudio.com
Old 04-27-2007
boingoman boingoman is offline
moldin' oldie
boingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond repute
Make sure to give the connectors a good cleaning in addition to whatever resoldering you do. I have four I use all the time, the only time I have had a hum problem turned out to be a tired XLR connector.
Old 04-27-2007
1K Silver Member
COOL!
That would be really excellent if that is all the problem is.
Tom Menikos
T-Mix Studios
Mansfield Texas
WWW.tmixstudio.com
Old 04-27-2007
big country's Avatar
big country big country is offline
Senior Member
big country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond reputebig country has a reputation beyond repute
a dimmer light switch can also make noise
is it just those mics that make noise?
and other mics sound fine...
Old 04-27-2007
1K Silver Member
It is just those (3) mics out of the 30 some odd mics I have.
I dont have fluorecent lights , dimmers, or the like, but the last place I used them was in my old studio which was in my garage, so just maybe something was putting off something evil near by. I have not tried them since I moved into my new studio which is a stand alone structure.
I'll experiment with them and see if the problem still exists.
Tom Menikos
T-Mix Studios
Mansfield Texas
WWW.tmixstudio.com
Some General Mic Information. Hope It Helps Out The Beginners. karma101 Newbies 34 09-13-2006 14:59
Advice On Recording Vocals! rnb259 DJ & Hip Hop Production 8 04-28-2006 13:31
nanocomp better than art tube mic pre? trdn1 Other Equipment and Reviews 2 03-11-2006 12:22
What mic would mshilarious choose for distorted vocals? nuemes Microphones 1 10-25-2005 14:48
