Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 04-26-2007
sjfoote sjfoote is offline
Newbie
sjfoote has a reputation beyond reputesjfoote has a reputation beyond reputesjfoote has a reputation beyond reputesjfoote has a reputation beyond reputesjfoote has a reputation beyond reputesjfoote has a reputation beyond reputesjfoote has a reputation beyond reputesjfoote has a reputation beyond reputesjfoote has a reputation beyond reputesjfoote has a reputation beyond reputesjfoote has a reputation beyond repute
12-string plug-in effect?
Does anybody know of a free plug-in that will add a 12-string effect to a standard guitar track?
no better, just older
Old 04-26-2007
giraffe's Avatar
giraffe giraffe is offline
i love negative rep
giraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond repute
it's..............
chorus!!! TA DA!
though it'll never sound like the real thing, that's the one.
audio?
seriously, give me negative rep.
Old 04-26-2007
danny.guitar
Guest
Posts: n/a
I'd imagine most 12-string plugins would just use pitch shifting and maybe chorus with it. But pitch shifting +12 semitones is going to sound bad. So chorus is probably your best bet.
Or track the guitar part once then use a capo and track it again. This can work when playing in some keys.
With that said, even cheap $100 12 strings can sound good, especially Yamahas. So you're best off getting one of those.
Old 04-26-2007
Robert D Robert D is offline
Close to the Edge
Robert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond reputeRobert D has a reputation beyond repute
You may also want to play around with the high strung or Nashville tuning.
Regards,
RD
http://www.myspace.com/twentysevenmoons
Old 04-26-2007
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
Low pass the track at around 1kHz, then pitch shift up an octave, and blend to taste with the original track (around -6dB, max), slightly delayed.
Old 04-26-2007
fishkarma's Avatar
fishkarma fishkarma is offline
Resident Hippie
fishkarma has a reputation beyond reputefishkarma has a reputation beyond reputefishkarma has a reputation beyond reputefishkarma has a reputation beyond reputefishkarma has a reputation beyond reputefishkarma has a reputation beyond reputefishkarma has a reputation beyond reputefishkarma has a reputation beyond reputefishkarma has a reputation beyond reputefishkarma has a reputation beyond reputefishkarma has a reputation beyond repute
you may also check what form of plug i.e. RTAS VST AU?
Peace
-Josh
Old 04-26-2007
RAMI's Avatar
RAMI RAMI is offline
www.ramirami.com
RAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond repute
I just did a tune where I needed a 12-string type sound. I just played the part low and then played the part high, keeping in mind which notes would be played by wound strings, etc....
Old 04-27-2007
Newbie
Thanks all..
some good ideas for me to try. As far as type of plug-in needed, I use a Cakewalk program that supports VST and DirectX (?) ...
Apples to apples, Taylors to Martins HapiCmpur Guitars and Basses 23 01-13-2006 19:32
5 string bass Jack Real Guitars and Basses 10 04-28-2005 17:20
Nashville Tuning Whyte Ice Guitars and Basses 36 01-09-2005 10:19
Guitar intonation mentil69 Guitars and Basses 30 03-30-2003 11:50
