Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 04-25-2007
dickiefunk's Avatar
dickiefunk dickiefunk is offline
Force of Nature
dickiefunk has a reputation beyond reputedickiefunk has a reputation beyond reputedickiefunk has a reputation beyond reputedickiefunk has a reputation beyond reputedickiefunk has a reputation beyond reputedickiefunk has a reputation beyond reputedickiefunk has a reputation beyond reputedickiefunk has a reputation beyond reputedickiefunk has a reputation beyond reputedickiefunk has a reputation beyond reputedickiefunk has a reputation beyond repute
Decent Mike Leads
Hi. I'm looking to get some new mic leads to upgrade my old Proel leads. Which would you recommend as being excellent quality for studio audio recording?
Echo Layla 3G, SM Pro Audio M Patch 2
Focusrite ISA One, M Audio Tampa, M Audio DMP3
Oktava MK-319, MXL V67g, Rode NT1a, Studio Projects B1,
Tannoy Reveal 8D's
Carillon Audio PC
Cubase SX3.1
Old 04-26-2007
MadMax MadMax is offline
Dedicated Member
MadMax has a reputation beyond reputeMadMax has a reputation beyond reputeMadMax has a reputation beyond reputeMadMax has a reputation beyond reputeMadMax has a reputation beyond reputeMadMax has a reputation beyond reputeMadMax has a reputation beyond reputeMadMax has a reputation beyond reputeMadMax has a reputation beyond reputeMadMax has a reputation beyond reputeMadMax has a reputation beyond repute
There's no difference between good and excellent when it comes to cable. Look for cables that have good connectors on them. That's where the real difference is.
Old 04-26-2007
Adam P Adam P is offline
stuck in the money pit
Adam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond repute
I'd look for Mogami, Canare or Belden cable, with connectors by Neutrik or Switchcraft. If it comes down to it, make your own. Well worth the effort in my opinion.
The Flight | Odd Number Recording
Old 04-27-2007
hairylarry hairylarry is offline
Force of Nature
hairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond reputehairylarry has a reputation beyond repute
Gls
Hi,
Get on ebay and search for GLS mic cables. I've got one and I use it all the time. Excellent quality and extremely cheap to buy. Plus unlike most ebay purchases they are satisfaction guaranteed.
The female connectors may be tight on some mics but I have always got mine to fit.
Thanks,
Hairy Larry
http://deltaboogie.com/hll/72_hairy_larry_wild.jpg
I've been making a video a day - http://archive.org/details/vidpods
Promote your act at Delta Boogie - http://deltaboogie.com
Share your media at MixRemix - http://mixremix.com
Old 04-28-2007
Paj Paj is offline
Force of Nature
Paj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond reputePaj has a reputation beyond repute
I think that this is the least expensive exceptional cable (and not an easy DIY):
http://www.8thstreet.com/product.asp...ory=Microphone
No matter who you get the cable from, test it with a cable tester. A multimeter is OK and tells you certain thins, but a cable tester with an "intermittant" function is hard to beat. I'm surprised at the failure rate/time for some current name brand cables and connectors. I know that "sh*t happens", but I'm still using a mic cables on stage that are about 30-years old---because they're in perfect working order, have never failed, and show now signs of failing. Out of the last 30 assorted mic cables I bought in the past two years, one failed with minimum use, one female connector (a name-brand mentioned above) had that d*mn-near-impossible-to-replace barrel screw* that holds the connector together disappear on another cable, and two worked fine with dynamic mics but hummed scarily with a phantom-powered condenser. Inspect and test your cables before you need them and still have time to redeeem them.
I have had no problems at all with GLS, Mogami, and Stdio Projects stuff.
Paj
8^)
*now widely substitutable with machine screws available in assortment at a hardware or dollar store near you. Not flush, but firm and functional.
8^)
Looking for cheap, decent digital drum kit + keyboard KJI Newbies 3 11-16-2006 18:40
Phantom again - can it waste a condenser mike? Dr.Rubber Microphones 3 10-27-2004 01:51
Are RCA leads and Phono Leads one and the same? badgerer Newbies 5 03-17-2003 15:39
Mike "Shootout" web page MarkW Microphones 8 03-11-2000 12:57
