Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 04-22-2007
ikijapan ikijapan is offline
Senior Member
ikijapan has a reputation beyond reputeikijapan has a reputation beyond reputeikijapan has a reputation beyond reputeikijapan has a reputation beyond reputeikijapan has a reputation beyond reputeikijapan has a reputation beyond reputeikijapan has a reputation beyond reputeikijapan has a reputation beyond reputeikijapan has a reputation beyond reputeikijapan has a reputation beyond reputeikijapan has a reputation beyond repute
why are these different
Crap, maybe I should have posted this in the newbie section...but here goes.
So, I finally got my system running ncie and smooth, I can put all kinds of effects on there without popping and whatnot thanks to some advice from Farview.
Here's something I don't understand though: I thought I understood how send effects work versus insert effects, until I did this: I have 6 acoustic guitar tracks that I want to compress exactly the same way. They are actually just 3 takes of stereo guitar. I don't want to bounce them because I have already done a lot with automation and whatnot and think it will just be easier to keep them where they are at this point. OK, fine, so I figured that rather than inserting 6 VST comps (which I usually do), I will just create a send effect with my VST comp. I set it EXACTLY the same as the comp I had inserted before and then removed the insert one and turn on the send one.
But the send one is WAY louder. I mean, I had make up gain on...umm, about 4 db, but now I don't know what I'm doing. Should I not be doing a comp this way?? I also noticed that depending on how much I slide the send effect over, the louder it gets (I think that is the wet/dry ratio??). Are you only supposed to use a comp as an insert effect?
Old 04-22-2007
FALKEN's Avatar
FALKEN FALKEN is offline
FALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond repute
send it all to a bus and put the comp on the bus.
Old 04-22-2007
Senior Member
What is happening by me doing it as a send effect? Let me try the bus thing right now too
Old 04-22-2007
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
Typically an aux send is a split-off of the normal signal path. Unless you kill the original path you have the sum of both.
http://homerecording.com/bbs/showthr...light=parallel
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
