Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 04-22-2007
djclueveli djclueveli is offline
Dedicated Member
djclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond reputedjclueveli has a reputation beyond repute
is this unity gain on this mixer?
ok i found and old mixer in a box (peavey 500 unity series) and it's faders are not the ones u slide up and down. they are the ones u turn (o' clock) faders. the master fader is labeled from 0 (being the lowest) all the way to 10 (being the highest) and it's also labeled like that for the channel level and gain faders. so where would unity gain be on the master and channel level fader be because when they are set to 0 no sound comes out of the mixer. help please and explain where unity gain is on mixers with the o clock knobs.
Old 04-22-2007
IronFlippy's Avatar
IronFlippy IronFlippy is offline
Dedicated To My Member
IronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond repute
On my mixer there is a mark at 3 o'clock indicating unity. Not sure what to say other than check Peavey's site. They have an archive of manuals for old gear.
I can't listen to that much Wagner. I start getting the urge to conquer Poland.
Old 04-22-2007
Dedicated Member
let me guess do you have the yamaha mg 10/2?
Old 04-22-2007
Dedicated Member
if so, how far (o clock wise) do u turn the channel gain to reach -18dbfs and do u use the rca REC OUT to capture the sound?
Old 04-22-2007
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Unless you can find a manual that tells you or have a calibrated test signal, you'll just have to guess. 3 o'clock would make sense, but it's just a guess.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 04-22-2007
Dedicated Member
farview can u explain to me how to do the calibrated test? and does it matter what my sound card line in level is set to (does it have to be set to 0 right)?
Old 04-22-2007
Farview's Avatar
You would have to have a test signal that was line level.
Plug that in to the line input. Hit solo on that channel and set the trim so the meter reads 0.
Route that channel to a buss, solo the buss. Now turn up the channel fader until the meter reads 0.
Now raise the master fader until the meter reads 0.
You have now found unity on all the faders and trim controls.
Jay Walsh
Old 04-22-2007
Dedicated Member
farview i don't have a solo on my mixer. and when u say turn the fader up till it reaches 0 do you mean 0 on the mixer while singin into the mic?
Old 04-23-2007
Farview's Avatar
If you don't have a solo button, you're screwed.
I didn't say anything about singing into a mic, you have to have a test signal that you know is line level in order to calibrate anything. Without the solo button, the meter won't read the channel volume so you're out of luck.
Jay Walsh
Old 04-24-2007
Dedicated Member
what exactly does the solo button do? what if i only have one channel being used which is the mic preamp can that count as solo since i'm only occupyin 1 channel
effects loop mixer problem?....HELP! kensington The Rack 0 07-01-2004 09:27
Amp and mixer question....What comes first in a live setup? sjaguar13 Other Equipment and Reviews 15 09-18-2003 03:07
Setting gain control on mixer with different mics randyfromde Microphones 1 09-01-2003 16:15
Help! How to route my mixer so I can monitor effects using my computer kelitupu Newbies 3 05-10-2002 01:38
my recording setup - NEEDS HELP sykotic Digital Recording & Computers 12 10-06-2001 17:26
