Help - recommend budget 8 port preamp please!
Hi All,
I've got an M-Audio 1814 audio interface and need a mixer/pre-amp to feed the channells to pro tools. Any advice appreciated! basically just need 8 ports with pre amp and phantom power to mic drums and feed to the 1814. Any help appreciated! Thanks, Aidan..
Anybody used the SM PRO AUDIO PR 8 E,
8 channel microphone preamplifier, individual gain control per channel, Peak Light indicator per channel, Phantom On/Off per channel, Phantom power light indicator per channel, 8 x Balanced XLR/TRS inputs, 8 x TRS Balanced/Unbalanced outputs @+4dB, Distortion < .05% 20Hz- 20kHz, external power supply http://www.thomann.de/ie/sm_pro_audio_pr_8_e.htm Any thoughts? anyone used one?
I recall SM Pro gear being regarded as barely a step above Behringer..........whether that has changed with time I can't say. Check out Studio Projects http://www.studioprojectsusa.com/ as they have an 8 channel thingy that may be suitable and they generally have a good reputation.
--- Humans are analogue beings --- --- Digital information lasts forever......or maybe five years...............................Which ever comes first. --- |
I've ordered this anyway, saw some good reviews... I'll post up results when I get it going..
It will pass signal and make that signal louder. AS long as you keep your expectations in that range you should be fine. You paid about 19 Euros a channel for that. Their build costs are obviously far below that, and include the case, the power supply, knobs and paint job. The preamps in that unit probably cost in the area of pennies each to make. As I mentioned before, it will amplify your mics, but keep your expectations low.
http://www.misterpotts.com |
| no preamp vs cheap preamp | billmcdonald | The Rack | 89 | 07-09-2009 04:00 |
| Preamp for Marshall MXL V57M? | crossroads | Newbies | 1 | 12-30-2005 16:53 |
| External preamp benefits? | GmanJeff | Microphones | 4 | 02-03-2005 17:55 |
| Anyone Recommend a good value mic preamp? | Jedman | Mixing / Mastering | 7 | 03-12-2003 09:22 |
| 2channel preamp. | brandon.w | Microphones | 7 | 02-26-2003 20:12 |
